QDS_Datum Class Referenceabstract
Base class for all controls using the data dictionary. More...
#include <QDS_Datum.h>
Inheritance diagram for QDS_Datum:
class  Wrapper
 Wrapper for sub widgets. More...
Public Slots
void setEnabled (bool)
 Enable/disable main control subwidget (QDS::Control). More...
Signals
void paramChanged ()
 The signal is emitted when the datum value is changed. More...
void paramChanged (QString &)
 QDS_Datum (const QString &, QWidget *=0, const int=All, const QString &=QString())
virtual ~QDS_Datum ()
QString id () const
 Get the datum ID. More...
int type () const
 Get the datum value type. More...
QString label () const
 Get the datum label text. More...
QString units () const
 Get the datum units text. More...
QString filter () const
 Get the datum filter string. More...
QString format () const
 Get the datum format string. More...
QString longDescription () const
 Get the datum long description. More...
QString shortDescription () const
 Get the datum short description. More...
QString defaultValue () const
 Get the datum default value. More...
QString minimumValue () const
 Get the datum minimum value. More...
QString maximumValue () const
 Get the datum maximum value. More...
QStringList options () const
 Get the datum options names. More...
 Get datum option specified by name as QVariant. More...
QString optionString (const QString &) const
 Get datum option specified by name as string. More...
double optionDouble (const QString &) const
 Get datum option specified by name as double. More...
int optionInteger (const QString &) const
 Get datum option specified by name as integer. More...
virtual QVariant value () const
 Get the datum value as QVariant. More...
virtual QString stringValue () const
 Get the datum value as string. More...
virtual double doubleValue () const
 Get the datum value as double. More...
virtual int integerValue () const
 Get the datum value as integer. More...
QString text () const
 Get the text data from datum. More...
virtual bool isEmpty () const
 Check if the datum is empty. More...
virtual void reset ()
 Reset datum state and set default value as current. More...
virtual void clear ()
 Clear the control. More...
virtual void setValue (const QVariant &)
 Set datum value from QVariant object. More...
virtual void setStringValue (const QString &)
 Set datum value from string data. More...
virtual void setDoubleValue (const double)
 Set datum value from double data. More...
virtual void setIntegerValue (const int)
 Set datum value from integer data. More...
virtual bool isEnabled (const int=Control) const
 Get 'enabled' state of the specified subwidget. More...
virtual void setEnabled (const bool, const int)
 Enable/disable subwidgets specified by element. More...
void show (const int=All)
 Show subwidgets specified by element. More...
void hide (const int=All)
 Hide subwidgets specified by element. More...
virtual void setShown (const bool, const int=All)
 Show/hide subwidgets specified by flags. More...
QWidget * widget (const int) const
 Get subwidget specified by element. More...
void setFocus ()
 Set the input focus to the control widget. More...
virtual bool isValid (const bool=true, const QString &=QString(), const QString &=QString()) const
 Check if input data is valid. More...
virtual QValidator * validator (const bool=false) const
 Create validator according to the datum type of value. More...
void addTo (QVBoxLayout *)
 Add widgets to the vertical box layout. More...
void addTo (QHBoxLayout *)
 Add widgets to the horizontal box layout. More...
void addTo (QGridLayout *, const int, const int, const bool=false)
 Add widgets to the grid layout. More...
virtual void setAlignment (const int, const int=Label)
 Set the aligment for QDS::Label and/or QDS::Units subwidgets. More...
virtual QString getString () const =0
 Get string value from datum. More...
 Event filter. More...
 operator QWidget * () const
 Overloaded operator used to retrieve main subwidget named QDS::Control. More...
bool isCustomTr () const
 Return state of custom translation. More...
void enableCustomTr (const bool)
 Change state of custom translation. More...
static QString unitsToText (const QString &)
 Convert units into text presentation. More...
static QString textToUnits (const QString &)
 Convert text presentation into internal units format. More...
static QString format (const QString &, const QString &, const bool=false)
 Format the specified string as dictionary item value. More...
static QString format (const int, const QString &, const bool=false)
 Format the specified integer as dictionary item value. More...
static QString format (const double, const QString &, const bool=false)
 Format the specified double as dictionary item value. More...
static QString units (const QString &)
 Get displayable units string for specified data dictionary item. More...
- Static Public Member Functions inherited from QDS
static bool load (const QString &)
 Load datum definitions from XML file dictPath to the dictionary. More...
static QString unitSystemLabel (const QString &, const QString &=QString())
 Get the label of unit system sys. More...
static QString activeUnitSystem (const QString &=QString())
 Get the name of active unit system from the specified component comp. More...
static void setActiveUnitSystem (const QString &, const QString &=QString())
 Set the active unit system. More...
static QString toQString (const TCollection_AsciiString &)
 Convert the OpenCascade ASCII string to Qt string. More...
static QString toQString (const TCollection_ExtendedString &)
 Convert the OpenCascade Unicode string to Qt string. More...
static QString toQString (const Handle(TCollection_HAsciiString)&)
static QString toQString (const Handle(TCollection_HExtendedString)&)
static TCollection_AsciiString toAsciiString (const QString &)
 Convert the Qt string to OpenCascade ASCII string. More...
static TCollection_AsciiString toAsciiString (const TCollection_ExtendedString &)
 Convert the OpenCascade Unicode string to OpenCascade ASCII string. More...
static TCollection_AsciiString toAsciiString (const Handle(TCollection_HExtendedString)&)
static TCollection_ExtendedString toExtString (const QString &)
 Convert the Qt string to OpenCascade Unicode string. More...
static TCollection_ExtendedString toExtString (const TCollection_AsciiString &)
 Convert the OpenCascade ASCII string to OpenCascade Unicode string. More...
Protected Slots
virtual void onParamChanged ()
 Called when datum value is changed. More...
QLabel * labelWidget () const
 Get QDS::Label widget. More...
QLabel * unitsWidget () const
 Get QDS::Units widget. More...
QWidget * controlWidget () const
 Get QDS::Control widget. More...
 Handle (DDS_DicItem) dicItem() const
void setDicItem (const Handle(DDS_DicItem)&)
int flags () const
 Get datum flags. More...
void invalidateCache ()
 Reset the numeric value cache. More...
virtual QLabel * createLabel (QWidget *)
 Create QDS::Label widget. More...
virtual QLabel * createUnits (QWidget *)
 Create QDS::Units widget. More...
virtual QWidget * createControl (QWidget *)=0
 Create QDS::Control widget. More...
virtual void setString (const QString &)=0
virtual bool validate (const QString &) const
 Validate the specified string. More...
QString prefix () const
 Get prefix string from format. More...
QString suffix () const
 Get suffix string from format. More...
virtual QString minValue () const
 Get minimum value. More...
virtual QString maxValue () const
 Get maximum value. More...
virtual void unitSystemChanged (const QString &)
 Process notification about active units system changing. More...
void initDatum () const
 Perform initialization if it needed. More...
static QString format (const QString &, const int, const int)
 Format the given value according to the data dictionary item type. More...
static QString format (const QString &, const int, const double)
static QString format (const QString &, const int, const QString &)
static QString sprintf (const QString &, const int)
 Wrapper around the standard sprintf() function. More...
static QString sprintf (const QString &, const double)
 Wrapper around the standard sprintf() function. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.Process some non standard flags from format string. More...
static QString sprintf (const QString &, const QString &)
- Static Protected Member Functions inherited from QDS
static void insertDatum (QDS_Datum *)
 Register given datum datum in the global list. More...
static void removeDatum (QDS_Datum *)
 Remove given datum datum from the global list. More...
Private Types
typedef QPointer< QLabel > GuardedLabel
typedef QPointer< QWidget > GuardedWidget
Private Slots
void onInitDatum ()
 Perform delayed initialization. More...
void onDestroyed (QObject *)
 Called when child subwidget is destroued. More...
void initialize ()
 Initialize datum. More...
Wrapper * wrapper (QWidget *) const
 Get wrapper for specified subwidget. More...
Wrapper * wrapper (const int) const
int wrapperType (Wrapper *) const
 Get subwidget type for specified wrapper. More...
 Handle (DDS_DicItem) myDicItem
static QString removeAccel (const QString &)
 Remove the acceleartor tags '&' from specified label string src. More...
static bool isDoubleFormat (const QString &)
 Check if given format specified doube value. More...
static QString canonicalFormat (const QString &)
 Get the canonical sprintf() format. More...
static QString canonicalFormat (const QString &, QString &)
 Get the canonical sprintf() format and non standard flags. More...
QString myId
int myFlags
QMap< int, Wrapper * > myWrapper
GuardedLabel myLabel
GuardedLabel myUnits
GuardedWidget myControl
QString mySourceValue
QString myTargetValue
bool myInitialised
bool myTr
Friends
class QDS
- Public Types inherited from QDS
enum  DatumFlags {
  None = 0x00 , Label = 0x01 , Control = 0x02 , Units = 0x04 ,
  NotFormat = 0x08 , NotAccel = 0x10 , NotConvert = 0x20 , UnitsWithLabel = 0x40 ,
  All = Label | Control | Units
 Enum describes bit flags of the Qt datum view and behaviour. More...
Datum is successor of QObject (not QWidget). This object can have up to three sub widgets named as QDS::Label, QDS::Control and QDS::Units. User can prevent creation of any of them by setting corresponding subwidgets IDs in the parameter flags of the constructor. QDS::Label widget displays label of datum, QDS::Control widget allows entering the value and QDS::Units widget displays measure units in the active units system.
These widgets are constructed under the parent widget of the datum. The sub widgets are layouted in the parent widget in the following order: first widget is QDS::Label, it is followed by QDS::Control, and in the end is QDS::Units. User can add these widgets to layout manually using method addTo(). Method widget() can be used to retrieve desired widget and place it into layout.
When QGroupBox is used as parent widget for datum object, all subwidgets are arranged automatically by the group box according to the column and orientation properties of the QGroupBox.
Example:
QGroupBox* box = new QGroupBox( 3, Qt::Horizontal, "datum box" );
QDS_Datum* d1 = new QDS_Datum( "datum_1", box, All );
QDS_Datum* d2 = new QDS_Datum( "datum_2", box, All );
QDS_Datum* d3 = new QDS_Datum( "datum_3", box, All );
@ Horizontal
Horizontal orientation.
Definition: SalomePyQt.h:148
Definition: QDS_Datum.h:41
QDS_Datum(const QString &, QWidget *=0, const int=All, const QString &=QString())
Definition: QDS_Datum.cxx:200
@ All
Create all subwidgets.
Definition: QDS.h:64
In this example we create the QGroupBox with 3 horizontal columns. All the created datum widgets will be placed automatically in 3 rows. Datums will be placed from top to bottom one by one and aligned in he grid.
Datum value is stored as string. User can get/set this value:
User can enable/disable datum subwidgets with setEnabled() method, show/hide them with show()/hide() methods, set input focus to datum with setFocus(), set widgets alignment with setAlignment(), etc.
◆ GuardedLabel
typedef QPointer<QLabel> QDS_Datum::GuardedLabel
◆ GuardedWidget
typedef QPointer<QWidget> QDS_Datum::GuardedWidget
◆ QDS_Datum()
QDS_Datum::QDS_Datum ( const QString &  id,
QWidget *  parent = 0,
const int  flags = All,
const QString &  comp = QString()
Create datum object with datum identifier id and parent widget parent.
Parameter flags defines behaviour of datum and set of created subwidgets. Default value of this parameter is QDS::All.
Parameter comp specifies the component name which will be used when searching the dictionary item.
Datum is self-registered in the global list by QDS::insertDatum().
iddatum identifier
parentparent widget
flagsdatum flags
compcomponent
References QDS::Control, Handle(), QDS::insertDatum(), QDS::Label, myFlags, myWrapper, onDestroyed(), onInitDatum(), setDicItem(), QDS::toAsciiString(), and QDS::Units.
◆ ~QDS_Datum()
QDS_Datum::~QDS_Datum ( )
Destroy all subwidget. Datum is unregistered from the global list by QDS::removeDatum().
References myControl, myLabel, myUnits, and QDS::removeDatum().
◆ addTo() [1/3]
void QDS_Datum::addTo ( QGridLayout *  theLay,
const int  theRow,
const int  theCol,
const bool  vertical = false
theLaylayout
theRowlayout row index
theCollayout column index
verticalif true subwidgets are layouted vertically, otherwise - horizontally
References QDS::Control, initDatum(), QDS::Label, QDS::Units, and wrapper().
◆ addTo() [2/3]
void QDS_Datum::addTo ( QHBoxLayout *  l)
llayout
◆ addTo() [3/3]
void QDS_Datum::addTo ( QVBoxLayout *  l)
llayout
◆ canonicalFormat() [1/2]
QString QDS_Datum::canonicalFormat ( const QString &  fmt)
staticprivate
fmtstring format
References canonicalFormat(), and flags().
◆ canonicalFormat() [2/2]
QString QDS_Datum::canonicalFormat ( const QString &  fmt,
QString &  flags
staticprivate
fmtstring format
flagsformat flags
References flags(), and rx.
◆ clear()
void QDS_Datum::clear ( )
◆ controlWidget()
QWidget * QDS_Datum::controlWidget ( ) const
control widget
References initDatum(), and myControl.
◆ createControl()
QWidget * QDS_Datum::createControl ( QWidget *  parent)
protectedpure virtual
This method should be implemented in the successor classes.
parentparent widget
control widget
Implemented in QDS_CheckBox, QDS_ComboBox, QDS_LineEdit, QDS_RadioBox, QDS_SpinBox, QDS_SpinBoxDbl, and QDS_TextEdit.
◆ createLabel()
QLabel * QDS_Datum::createLabel ( QWidget *  parent)
parentparent widget
label widget
◆ createUnits()
QLabel * QDS_Datum::createUnits ( QWidget *  parent)
parentparent widget
units widget
◆ defaultValue()
QString QDS_Datum::defaultValue ( ) const
default value
References initDatum(), prefix(), suffix(), and QDS::toQString().
◆ doubleValue()
double QDS_Datum::doubleValue ( ) const
The value is converted according to the measure units in the active units system to measure units in "SI" units system.
datum value converted to double
Reimplemented in QDS_ComboBox.
References flags(), getString(), initDatum(), mySourceValue, myTargetValue, and QDS::NotConvert.
◆ enableCustomTr()
void QDS_Datum::enableCustomTr ( const bool  on)
Custom translation means that text labels of datums are translated with help of standard Qt mechanism of internationalization. In this case special records should be placed into *.ts files under context "QDS". For example, if label has name "myLabel", the corresponding translation should be written: <context> <name>QDS</name> <message> <source>myLabel</source> <translation>myLabel translation</translation> </message> ...
If custom translation mechanism is deactivated, then labels will be shown with text got from xml data dictionary file
By default, the custom translation is deactivated
on- if it is true, custom translation is activated, otherwise, deactivated
References label(), labelWidget(), and myTr.
◆ eventFilter()
bool QDS_Datum::eventFilter ( QObject *  o,
QEvent *  e
Event filter.
Perform delayed initialisation. Reimplemented for internal reasons.
oevent reciever object
eevent
true if event should be filtered
References initDatum().
◆ filter()
QString QDS_Datum::filter ( ) const
filter string
References initDatum(), and QDS::toQString().
◆ flags()
int QDS_Datum::flags ( ) const
Get datum flags.
datum flags (QDS::DatumFlags)
References myFlags.
◆ format() [1/7]
QString QDS_Datum::format ( ) const
format string
◆ format() [2/7]
QString QDS_Datum::format ( const double  num,
const QString &  id,
const bool  convert = false
numdouble value being formatted
iddata dictionary ID
convertif true, perform conversion from "SI" units system
formatted value
References format(), Handle(), QDS::toAsciiString(), QDS::toQString(), and DDS_DicItem::Unknown.
◆ format() [3/7]
QString QDS_Datum::format ( const int  num,
const QString &  id,
numinteger value being formatted
formatted value
◆ format() [4/7]
QString QDS_Datum::format ( const QString &  aFormat,
const int  aType,
const double  aValue
staticprotected
aFormatformat string
aTypedata dictionary item type
aValuedouble value being formatted
formatted value
References DDS_DicItem::Float, DDS_DicItem::Integer, and DDS_DicItem::String.
◆ format() [5/7]
const int  aType,
const int  aValue
staticprotected
aValueinteger value being formatted
formatted value
References DDS_DicItem::Float, DDS_DicItem::Integer, sprintf(), and DDS_DicItem::String.
◆ format() [6/7]
const int  aType,
const QString &  aValue
staticprotected
aValuestring value being formatted
formatted value
◆ format() [7/7]
QString QDS_Datum::format ( const QString &  str,
const QString &  id,
strstring value being formatted
formatted value
◆ getString()
QString QDS_Datum::getString ( ) const
pure virtual
datum string value
◆ Handle() [1/2]
QDS_Datum::Handle ( DDS_DicItem  ) const
◆ Handle() [2/2]
◆ hide()
void QDS_Datum::hide ( const int  element = All)
Possible values of element: QDS::Label, QDS::Control, QDS::Units or their ORed combinations.
elementORed subwidget flags (QDS::DatumFlags)
See also
show(), setShown()
References setShown().
◆ id()
QString QDS_Datum::id ( ) const
Get the datum ID.
datum ID
References initDatum(), and myId.
◆ initDatum()
void QDS_Datum::initDatum ( ) const
References initialize(), and myInitialised.
◆ initialize()
void QDS_Datum::initialize ( )
Initialize datum.
Retrieve information from data dictionary and create subwidgets using virtual mechanism.
Virtual mechanism doesn't work in the constructor, therefore this method should be called outside the constructor.
References QDS::Control, controlWidget(), createControl(), createLabel(), createUnits(), flags(), Handle(), QDS::Label, labelWidget(), longDescription(), myControl, myLabel, myUnits, QDS::NotAccel, QDS_Datum::Wrapper::setWidget(), shortDescription(), QDS::toQString(), QDS::Units, unitSystemChanged(), and wrapper().
◆ integerValue()
int QDS_Datum::integerValue ( ) const
datum value converted to integer
◆ invalidateCache()
void QDS_Datum::invalidateCache ( )
References myTargetValue.
◆ isCustomTr()
bool QDS_Datum::isCustomTr ( ) const
true if custom translation is enabled
References myTr.
◆ isDoubleFormat()
bool QDS_Datum::isDoubleFormat ( const QString &  theFormat)
staticprivate
theFormatformat string
true if theFormat has specificator for double values
◆ isEmpty()
bool QDS_Datum::isEmpty ( ) const
false if datum control has value entered
References stringValue().
◆ isEnabled()
bool QDS_Datum::isEnabled ( const int  element = Control) const
true if all subwidgets specified by element are enabled
See also
setEnabled()
References QDS::Control, controlWidget(), initDatum(), QDS::Label, labelWidget(), QDS::Units, and unitsWidget().
◆ isValid()
bool QDS_Datum::isValid ( const bool  msgBox = true,
const QString &  extMsg = QString(),
const QString &  extLabel = QString()
If data is invalid and msgBox is true, the warning message box is shown.
msgBoxif true, show warning message box if input is invalid
extMsgwarning message
extLabeloptional name of the variable (if QDS::Label control is not used)
true if input data is valid
References controlWidget(), DDS_DicItem::Float, format(), getString(), initDatum(), DDS_DicItem::Integer, isDoubleFormat(), isEmpty(), label(), maxValue(), minValue(), DDS_DicItem::String, QDS::toQString(), type(), and validate().
◆ label()
QString QDS_Datum::label ( ) const
label text
References flags(), initDatum(), myTr, QDS::NotAccel, removeAccel(), and QDS::toQString().
◆ labelWidget()
QLabel * QDS_Datum::labelWidget ( ) const
label widget
References initDatum(), and myLabel.
◆ longDescription()
QString QDS_Datum::longDescription ( ) const
◆ maximumValue()
QString QDS_Datum::maximumValue ( ) const
maximum value
References format(), initDatum(), DDS_DicItem::MaxValue, and type().
◆ maxValue()
QString QDS_Datum::maxValue ( ) const
Get maximum value.
maximum value
References maximumValue(), prefix(), and suffix().
◆ minimumValue()
QString QDS_Datum::minimumValue ( ) const
minimum value
References format(), initDatum(), DDS_DicItem::MinValue, and type().
◆ minValue()
QString QDS_Datum::minValue ( ) const
Get minimum value.
minimum value
References minimumValue(), prefix(), and suffix().
◆ onDestroyed
void QDS_Datum::onDestroyed ( QObject *  obj)
privateslot
Allows avoiding crash of extra calling of the child subwidget destructor.
objobject being destroyed
References myWrapper, and wrapperType().
◆ onInitDatum
void QDS_Datum::onInitDatum ( )
privateslot
◆ onParamChanged
void QDS_Datum::onParamChanged ( )
protectedvirtualslot
◆ operator QWidget *()
QDS_Datum::operator QWidget * ( ) const
QDS::Control subwidget
◆ option()
QVariant QDS_Datum::option ( const QString &  name) const
the option value or invalid QVariant if the option does not exist
References QDS::toAsciiString(), and QDS::toQString().
◆ optionDouble()
double QDS_Datum::optionDouble ( const QString &  name) const
the option value or 0 if the option does not exist
References option().
◆ optionInteger()
int QDS_Datum::optionInteger ( const QString &  name) const
◆ options()
QStringList QDS_Datum::options ( ) const
datum options
References QDS::toQString().
◆ optionString()
QString QDS_Datum::optionString ( const QString &  name) const
the option value or null QString if the option does not exist
◆ paramChanged [1/2]
void QDS_Datum::paramChanged ( )
signal
◆ paramChanged [2/2]
void QDS_Datum::paramChanged ( QString &  )
signal
◆ prefix()
QString QDS_Datum::prefix ( ) const
current implementation returns null string
◆ removeAccel()
QString QDS_Datum::removeAccel ( const QString &  src)
staticprivate
srcprocessed string
string after removing '&' symbols
◆ reset()
void QDS_Datum::reset ( )
References defaultValue(), format(), getString(), initDatum(), invalidateCache(), myFlags, mySourceValue, QDS::NotFormat, onParamChanged(), paramChanged(), setString(), and type().
◆ setAlignment()
void QDS_Datum::setAlignment ( const int  align,
const int  type = Label
alignalignment type (Qt::Alignment)
typeORed subwidget flags
Reimplemented in QDS_LineEdit.
References initDatum(), QDS::Label, labelWidget(), type(), QDS::Units, and unitsWidget().
◆ setDicItem()
void QDS_Datum::setDicItem ( const Handle(DDS_DicItem)&  )
◆ setDoubleValue()
void QDS_Datum::setDoubleValue ( const double  num)
The value is converted from measure units in "SI" units system to the measure units in the active units system. Format the value using datum format internal if it is required.
numnew value
References flags(), format(), getString(), initDatum(), mySourceValue, myTargetValue, QDS::NotConvert, QDS::NotFormat, onParamChanged(), paramChanged(), setString(), and type().
◆ setEnabled [1/2]
void QDS_Datum::setEnabled ( bool  on)
slot
onnew 'enabled' state
References QDS::Control, and setEnabled().
◆ setEnabled() [2/2]
void QDS_Datum::setEnabled ( const bool  on,
const int  element
See also
isEnabled()
◆ setFocus()
void QDS_Datum::setFocus ( )
References controlWidget(), and initDatum().
◆ setIntegerValue()
void QDS_Datum::setIntegerValue ( const int  num)
The value is converted from measure units in "SI" units system to the measure units in the active units system. Format the value using datum format if it is required.
numnew value
◆ setShown()
void QDS_Datum::setShown ( const bool  visible,
Possible values of flags: QDS::Label, QDS::Control, QDS::Units or their ORed combinations.
visiblenew 'visibility' state
flagsORed subwidget flags (QDS::DatumFlags)
See also
show(), hide()
References flags(), initDatum(), QDS::Units, and widget().
◆ setString()
virtual void QDS_Datum::setString ( const QString &  )
◆ setStringValue()
void QDS_Datum::setStringValue ( const QString &  txt)
txtnew value
References flags(), format(), getString(), initDatum(), mySourceValue, myTargetValue, QDS::NotFormat, onParamChanged(), paramChanged(), setString(), and type().
◆ setValue()
void QDS_Datum::setValue ( const QVariant &  val)
◆ shortDescription()
QString QDS_Datum::shortDescription ( ) const
◆ show()
void QDS_Datum::show ( const int  element = All)
See also
hide(), setShown()
◆ sprintf() [1/3]
QString QDS_Datum::sprintf ( const QString &  fmt,
const double  val
staticprotected
fmtstring format
valvalue
formatted value
References canonicalFormat().
◆ sprintf() [2/3]
const int  val
staticprotected
fmtstring format
valvalue
formatted value
◆ sprintf() [3/3]
const QString &  val
staticprotected
fmtstring format
valvalue
formatted value
References canonicalFormat(), isDoubleFormat(), rx, and sprintf().
◆ stringValue()
QString QDS_Datum::stringValue ( ) const
datum value converted to string
References getString(), initDatum(), mySourceValue, and myTargetValue.
◆ suffix()
QString QDS_Datum::suffix ( ) const
◆ text()
QString QDS_Datum::text ( ) const
Text consists of label, string value and units.
datum text data
References initDatum(), label(), stringValue(), and units().
◆ textToUnits()
QString QDS_Datum::textToUnits ( const QString &  txt)
txttext presentation of units (rich-text)
units value
◆ type()
int QDS_Datum::type ( ) const
datum value type
References initDatum(), and DDS_DicItem::Unknown.
◆ units() [1/2]
QString QDS_Datum::units ( ) const
units text
◆ units() [2/2]
QString QDS_Datum::units ( const QString &  id)
iddata dictionary item ID
units string
References Handle(), QDS::toAsciiString(), QDS::toQString(), and unitsToText().
◆ unitsToText()
QString QDS_Datum::unitsToText ( const QString &  uni)
uniunits to be converted
◆ unitsWidget()
QLabel * QDS_Datum::unitsWidget ( ) const
units widget
References initDatum(), and myUnits.
◆ unitSystemChanged()
void QDS_Datum::unitSystemChanged ( const QString &  )
Update label and units widgets.
unitSystemnew active units system
Reimplemented in QDS_ComboBox, QDS_LineEdit, QDS_RadioBox, QDS_SpinBox, and QDS_SpinBoxDbl.
References flags(), label(), labelWidget(), reset(), units(), unitsToText(), unitsWidget(), and QDS::UnitsWithLabel.
◆ validate()
bool QDS_Datum::validate ( const QString &  txt) const
txtstring to be validated
true if string contains valid data
References format(), isDoubleFormat(), DDS_DicItem::String, type(), DDS_DicItem::Unknown, and validator().
◆ validator()
QValidator * QDS_Datum::validator ( const bool  limits = false) const
limitsif true use minimum and maximum value limits
validator
References canonicalFormat(), filter(), DDS_DicItem::Float, format(), DDS_DicItem::Integer, maxValue(), minValue(), QDS_StringValidator::setLength(), DDS_DicItem::String, and type().
◆ value()
QVariant QDS_Datum::value ( ) const
◆ widget()
QWidget * QDS_Datum::widget ( const int  element) const
Possible values of element: QDS::Label, QDS::Control, QDS::Units.
elementsubwidget
widget
References initDatum(), and wrapper().
◆ wrapper() [1/2]
QDS_Datum::Wrapper * QDS_Datum::wrapper ( const int  id) const
idsubwidget ID
wrapper
References id(), and myWrapper.
◆ wrapper() [2/2]
QDS_Datum::Wrapper * QDS_Datum::wrapper ( QWidget *  wid) const
widsubwidget
wrapper
References myWrapper.
◆ wrapperType()
int QDS_Datum::wrapperType ( QDS_Datum::Wrapper *  wrap) const
wrapwrapper
subwidget ID
◆ QDS
friend class QDS
friend
◆ myControl
GuardedWidget QDS_Datum::myControl
◆ myFlags
int QDS_Datum::myFlags
◆ myId
QString QDS_Datum::myId
◆ myInitialised
bool QDS_Datum::myInitialised
◆ myLabel
GuardedLabel QDS_Datum::myLabel
◆ mySourceValue
QString QDS_Datum::mySourceValue
◆ myTargetValue
QString QDS_Datum::myTargetValue
◆ myTr
bool QDS_Datum::myTr
◆ myUnits
GuardedLabel QDS_Datum::myUnits
◆ myWrapper
QMap<int, Wrapper*> QDS_Datum::myWrapper
