QDS_RadioBox Class Reference
#include <QDS_RadioBox.h>
Inheritance diagram for QDS_RadioBox:
Signals
void activated (int)
 The signal is emitted when any radio button is toggled. More...
- Signals inherited from QDS_Datum
void paramChanged ()
 The signal is emitted when the datum value is changed. More...
void paramChanged (QString &)
 QDS_RadioBox (const QString &, QWidget *=0, const int=Control, const QString &=QString())
virtual ~QDS_RadioBox ()
int count (bool=false) const
 Get number of buttons in radio box. More...
void values (QList< int > &, bool=false) const
 Get buttons identifiers. More...
int columns () const
void setColumns (const int)
bool state (const int) const
 Get visibility state of the button specified by id. More...
void setState (const bool, const int, const bool=true)
 Set the visibility state of the button specified by id. More...
void setState (const bool, const QList< int > &, const bool=true)
 Set the visibility state of buttons specified by ids. More...
void setValues (const QList< int > &, const QStringList &)
 Set the custom user buttons into the radio box. More...
void setValues (const QStringList &)
 Set the custom user buttons into the radio box. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.User buttons like standard dictionary buttons will be added into the radio box. This function allows user to customize buttons. More...
virtual QString getString () const
 Get string from the radio box. More...
- Public Member Functions inherited from QDS_Datum
 QDS_Datum (const QString &, QWidget *=0, const int=All, const QString &=QString())
virtual ~QDS_Datum ()
QString id () const
 Get the datum ID. More...
int type () const
 Get the datum value type. More...
QString label () const
 Get the datum label text. More...
QString units () const
 Get the datum units text. More...
QString filter () const
 Get the datum filter string. More...
QString format () const
 Get the datum format string. More...
QString longDescription () const
 Get the datum long description. More...
QString shortDescription () const
 Get the datum short description. More...
QString defaultValue () const
 Get the datum default value. More...
QString minimumValue () const
 Get the datum minimum value. More...
QString maximumValue () const
 Get the datum maximum value. More...
QStringList options () const
 Get the datum options names. More...
 Get datum option specified by name as QVariant. More...
QString optionString (const QString &) const
 Get datum option specified by name as string. More...
double optionDouble (const QString &) const
 Get datum option specified by name as double. More...
int optionInteger (const QString &) const
 Get datum option specified by name as integer. More...
virtual QVariant value () const
 Get the datum value as QVariant. More...
virtual QString stringValue () const
 Get the datum value as string. More...
virtual double doubleValue () const
 Get the datum value as double. More...
virtual int integerValue () const
 Get the datum value as integer. More...
QString text () const
 Get the text data from datum. More...
virtual bool isEmpty () const
 Check if the datum is empty. More...
virtual void reset ()
 Reset datum state and set default value as current. More...
virtual void clear ()
 Clear the control. More...
virtual void setValue (const QVariant &)
 Set datum value from QVariant object. More...
virtual void setStringValue (const QString &)
 Set datum value from string data. More...
virtual void setDoubleValue (const double)
 Set datum value from double data. More...
virtual void setIntegerValue (const int)
 Set datum value from integer data. More...
virtual bool isEnabled (const int=Control) const
 Get 'enabled' state of the specified subwidget. More...
virtual void setEnabled (const bool, const int)
 Enable/disable subwidgets specified by element. More...
void show (const int=All)
 Show subwidgets specified by element. More...
void hide (const int=All)
 Hide subwidgets specified by element. More...
virtual void setShown (const bool, const int=All)
 Show/hide subwidgets specified by flags. More...
QWidget * widget (const int) const
 Get subwidget specified by element. More...
void setFocus ()
 Set the input focus to the control widget. More...
virtual bool isValid (const bool=true, const QString &=QString(), const QString &=QString()) const
 Check if input data is valid. More...
virtual QValidator * validator (const bool=false) const
 Create validator according to the datum type of value. More...
void addTo (QVBoxLayout *)
 Add widgets to the vertical box layout. More...
void addTo (QHBoxLayout *)
 Add widgets to the horizontal box layout. More...
void addTo (QGridLayout *, const int, const int, const bool=false)
 Add widgets to the grid layout. More...
virtual void setAlignment (const int, const int=Label)
 Set the aligment for QDS::Label and/or QDS::Units subwidgets. More...
virtual QString getString () const =0
 Get string value from datum. More...
 Event filter. More...
 operator QWidget * () const
 Overloaded operator used to retrieve main subwidget named QDS::Control. More...
bool isCustomTr () const
 Return state of custom translation. More...
void enableCustomTr (const bool)
 Change state of custom translation. More...
Protected Slots
virtual void onToggled (bool)
 Called when user toggles any radio button. More...
- Protected Slots inherited from QDS_Datum
virtual void onParamChanged ()
 Called when datum value is changed. More...
QButtonGroup * buttonGroup () const
 Get internal button group. More...
QGroupBox * groupBox () const
 Get internal group box widget. More...
virtual QWidget * createControl (QWidget *)
 Get radio button group box widget. More...
void buttons (QList< QRadioButton * > &) const
 Get all the radio buttons from the radio box. More...
virtual void setString (const QString &)
 Set the string value to the radio box widget. More...
virtual void unitSystemChanged (const QString &)
 Process notification about active units system changing. More...
- Protected Member Functions inherited from QDS_Datum
QLabel * labelWidget () const
 Get QDS::Label widget. More...
QLabel * unitsWidget () const
 Get QDS::Units widget. More...
QWidget * controlWidget () const
 Get QDS::Control widget. More...
 Handle (DDS_DicItem) dicItem() const
void setDicItem (const Handle(DDS_DicItem)&)
int flags () const
 Get datum flags. More...
void invalidateCache ()
 Reset the numeric value cache. More...
virtual QLabel * createLabel (QWidget *)
 Create QDS::Label widget. More...
virtual QLabel * createUnits (QWidget *)
 Create QDS::Units widget. More...
virtual QWidget * createControl (QWidget *)=0
 Create QDS::Control widget. More...
virtual void setString (const QString &)=0
virtual bool validate (const QString &) const
 Validate the specified string. More...
QString prefix () const
 Get prefix string from format. More...
QString suffix () const
 Get suffix string from format. More...
virtual QString minValue () const
 Get minimum value. More...
virtual QString maxValue () const
 Get maximum value. More...
void initDatum () const
 Perform initialization if it needed. More...
Private Types
typedef QMap< int, QString > IdValueMap
typedef QMap< int, bool > IdStateMap
void updateRadioBox ()
 Update radio box. More...
IdValueMap myValue
IdStateMap myState
QIntList myDataIds
QIntList myUserIds
QStringList myUserNames
QButtonGroup * myButtonGroup
- Public Types inherited from QDS
enum  DatumFlags {
  None = 0x00 , Label = 0x01 , Control = 0x02 , Units = 0x04 ,
  NotFormat = 0x08 , NotAccel = 0x10 , NotConvert = 0x20 , UnitsWithLabel = 0x40 ,
  All = Label | Control | Units
 Enum describes bit flags of the Qt datum view and behaviour. More...
- Public Slots inherited from QDS_Datum
void setEnabled (bool)
 Enable/disable main control subwidget (QDS::Control). More...
- Static Public Member Functions inherited from QDS_Datum
static QString unitsToText (const QString &)
 Convert units into text presentation. More...
static QString textToUnits (const QString &)
 Convert text presentation into internal units format. More...
static QString format (const QString &, const QString &, const bool=false)
 Format the specified string as dictionary item value. More...
static QString format (const int, const QString &, const bool=false)
 Format the specified integer as dictionary item value. More...
static QString format (const double, const QString &, const bool=false)
 Format the specified double as dictionary item value. More...
static QString units (const QString &)
 Get displayable units string for specified data dictionary item. More...
static bool load (const QString &)
 Load datum definitions from XML file dictPath to the dictionary. More...
static QString unitSystemLabel (const QString &, const QString &=QString())
 Get the label of unit system sys. More...
static QString activeUnitSystem (const QString &=QString())
 Get the name of active unit system from the specified component comp. More...
static void setActiveUnitSystem (const QString &, const QString &=QString())
 Set the active unit system. More...
static QString toQString (const TCollection_AsciiString &)
 Convert the OpenCascade ASCII string to Qt string. More...
static QString toQString (const TCollection_ExtendedString &)
 Convert the OpenCascade Unicode string to Qt string. More...
static QString toQString (const Handle(TCollection_HAsciiString)&)
static QString toQString (const Handle(TCollection_HExtendedString)&)
static TCollection_AsciiString toAsciiString (const QString &)
 Convert the Qt string to OpenCascade ASCII string. More...
static TCollection_AsciiString toAsciiString (const TCollection_ExtendedString &)
 Convert the OpenCascade Unicode string to OpenCascade ASCII string. More...
static TCollection_AsciiString toAsciiString (const Handle(TCollection_HExtendedString)&)
static TCollection_ExtendedString toExtString (const QString &)
 Convert the Qt string to OpenCascade Unicode string. More...
static TCollection_ExtendedString toExtString (const TCollection_AsciiString &)
 Convert the OpenCascade ASCII string to OpenCascade Unicode string. More...
- Static Protected Member Functions inherited from QDS_Datum
static QString format (const QString &, const int, const int)
 Format the given value according to the data dictionary item type. More...
static QString format (const QString &, const int, const double)
static QString format (const QString &, const int, const QString &)
static QString sprintf (const QString &, const int)
 Wrapper around the standard sprintf() function. More...
static QString sprintf (const QString &, const double)
 Wrapper around the standard sprintf() function. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.Process some non standard flags from format string. More...
static QString sprintf (const QString &, const QString &)
static void insertDatum (QDS_Datum *)
 Register given datum datum in the global list. More...
static void removeDatum (QDS_Datum *)
 Remove given datum datum from the global list. More...
◆ IdStateMap
typedef QMap<int, bool> QDS_RadioBox::IdStateMap
◆ IdValueMap
typedef QMap<int, QString> QDS_RadioBox::IdValueMap
◆ QDS_RadioBox()
QDS_RadioBox::QDS_RadioBox ( const QString &  id,
QWidget *  parent = 0,
const int  flags = Control,
const QString &  comp = QString()
Create radio button box datum object with datum identifier id and parent widget parent.
Parameter flags defines behaviour of datum and set of created subwidgets. Default value of this parameter is QDS::All.
Parameter comp specifies the component name which will be used when searching the dictionary item.
iddatum identifier
parentparent widget
flagsdatum flags
compcomponent
◆ ~QDS_RadioBox()
QDS_RadioBox::~QDS_RadioBox ( )
◆ activated
void QDS_RadioBox::activated ( int  id)
signal
idbutton ID
◆ buttonGroup()
QButtonGroup * QDS_RadioBox::buttonGroup ( ) const
pointer to the QButtonGroup object
References myButtonGroup.
◆ buttons()
void QDS_RadioBox::buttons ( QList< QRadioButton * > &  lst) const
lstreturned list of radio buttons
References buttonGroup().
◆ columns()
int QDS_RadioBox::columns ( ) const
◆ count()
int QDS_RadioBox::count ( bool  total = false) const
If total is false, only visible buttons are taken into account; otherwise total number of buttons is returned
totalget number of visible buttons if true and total number of buttons if false
requested number of items
References buttons(), and myValue.
◆ createControl()
QWidget * QDS_RadioBox::createControl ( QWidget *  parent)
Implements QDS_Datum.
◆ getString()
QString QDS_RadioBox::getString ( ) const
String which contains identifier of the currently selected button is returned.
identifier of the current button converted to string
◆ groupBox()
QGroupBox * QDS_RadioBox::groupBox ( ) const
pointer to the QGroupBox widget
References QDS_Datum::controlWidget().
◆ onToggled
void QDS_RadioBox::onToggled ( bool  on)
protectedvirtualslot
onnew radio button state
References getString(), QDS_Datum::onParamChanged(), and QDS_Datum::paramChanged().
◆ setColumns()
void QDS_RadioBox::setColumns ( const int  )
◆ setState() [1/2]
void QDS_RadioBox::setState ( const bool  on,
const int  id,
const bool  append = true
If id is -1 then specified state will be set to all buttons.
If append is set to true, keep current status for other buttons, otherwise status of other buttons is cleared.
onnew visibility state
idbutton ID
appendif true, keep original status for other buttons
References myState, and setState().
◆ setState() [2/2]
const QList< int > &  ids,
If append is set to true, keep the current status for other buttons, otherwise status of other buttons is cleared.
idsbuttons IDs list
References myState, and updateRadioBox().
◆ setString()
void QDS_RadioBox::setString ( const QString &  txt)
Button with the identifier from specified string txt becomes selected in the radio box.
txtstring value
References activated(), buttonGroup(), buttons(), getString(), QDS_Datum::onParamChanged(), and QDS_Datum::paramChanged().
◆ setValues() [1/2]
void QDS_RadioBox::setValues ( const QList< int > &  ids,
const QStringList &  names
User items like standard dictionary buttons will be added into the radio box. This function allows user to customize buttons.
idsbuttons IDs
namesbuttons names
References myUserIds, and myUserNames.
◆ setValues() [2/2]
void QDS_RadioBox::setValues ( const QStringList &  names)
Uses (0, 1, 2 ... ) as buttons IDs.
namesbuttons names
References setValues().
◆ state()
bool QDS_RadioBox::state ( const int  id) const
idbutton ID
item visibility state
References QDS_Datum::id(), myState, and state().
◆ unitSystemChanged()
void QDS_RadioBox::unitSystemChanged ( const QString &  system)
Update radio box contents.
systemnew active units system
Reimplemented from QDS_Datum.
References groupBox(), QDS_Datum::Handle(), QDS_Datum::id(), QDS_Datum::label(), myDataIds, myState, myUserIds, myUserNames, myValue, QDS::toQString(), QDS_Datum::unitSystemChanged(), and updateRadioBox().
◆ updateRadioBox()
void QDS_RadioBox::updateRadioBox ( )
◆ values()
void QDS_RadioBox::values ( QList< int > &  ids,
bool  total = false
idsreturned list of buttons IDs
totaltake into account only visible buttons if true and all buttons if false
References myDataIds, and myState.
◆ myButtonGroup
QButtonGroup* QDS_RadioBox::myButtonGroup
◆ myDataIds
QIntList QDS_RadioBox::myDataIds
◆ myState
IdStateMap QDS_RadioBox::myState
◆ myUserIds
QIntList QDS_RadioBox::myUserIds
◆ myUserNames
QStringList QDS_RadioBox::myUserNames
◆ myValue
IdValueMap QDS_RadioBox::myValue
