QtxBackgroundDialog Class Reference
Dialog box that can be used to set-up the background data. More...
#include <QtxBackgroundTool.h>
Inheritance diagram for QtxBackgroundDialog:
 QtxBackgroundDialog (QWidget *=0)
 QtxBackgroundDialog (const Qtx::BackgroundData &, QWidget *=0)
virtual ~QtxBackgroundDialog ()
void setData (const Qtx::BackgroundData &)
 Set background data. More...
Qtx::BackgroundData data () const
 Get background data. More...
void setGradients (const QStringList &, const QIntList &=QIntList())
 Set allowed two-color gradients to the widget. More...
void setModeAllowed (Qtx::BackgroundMode, bool=true)
 Enable / disable specific background mode. More...
void setTextureAllowed (bool=true)
 Enable / disable texture controls. More...
void setTextureModeAllowed (Qtx::TextureMode, bool=true)
 Enable / disable specific texture mode. More...
void setImageFormats (const QString &)
 Set allowed image formats. More...
- Public Member Functions inherited from QtxDialog
 QtxDialog (QWidget *=0, bool=false, bool=false, const int=Standard, Qt::WindowFlags=0)
virtual ~QtxDialog ()
void setDialogFlags (const int)
 Set specified dialog box flags. More...
void clearDialogFlags (const int)
 Clear specified the dialog flags. More...
bool testDialogFlags (const int) const
 Test specified dialog flags. More...
void setButtonFlags (const int)
 Add specified control button(s) to the dialog box. More...
void clearButtonFlags (const int)
 Remove specified control button(s) from the dialog box. More...
bool testButtonFlags (const int) const
 Test specified buttons. More...
int buttonPosition (const int) const
 Get specified control button position. More...
void setButtonPosition (const int, const int=-1)
 Set the specified control button(s) position. More...
void setPlacePosition (const int, const int)
 Set button position for all buttons in specified area. More...
int placePolicy (const int) const
 Get buttons layouting policy for the specified area. More...
void setPlacePolicy (const int, const int)
 set buttons layouting policy for the specified area. More...
void setButtonPlace (const int, const int)
 Move specified button(s) into specified area. More...
QString buttonText (const int)
 Get specified button's text. More...
void setButtonText (const int, const QString &text)
 Set specified button's text. More...
void setButtonFocus (const int)
 Sets the keyboard focus to the specified button. More...
bool hasButtonFocus (const int) const
 Check if specified button has keyboard focus. More...
bool isButtonEnabled (const int) const
 Get "enabled" status of the specified button(s). More...
void setButtonEnabled (const bool, const int)
 Enable/disable specified button(s). More...
bool isBorderEnabled (const int) const
 Check if border is enabled. More...
void setBorderEnabled (const bool, const int)
 Show/hide border for the specified button area. More...
void removeButton (const int)
 Remove user button. More...
int insertButton (const QString &, const int=BottomArea)
 Add user button to the dialog box. More...
QIntList userButtonIds () const
 Get all user button IDs. More...
QAbstractButton * userButton (const int) const
 Get user button by the specified id. More...
uint setAlignment (uint align)
 Sets alignment policy. More...
static Qtx::BackgroundData getBackground (const Qtx::BackgroundData &=Qtx::BackgroundData(), QWidget *=0, bool=true, bool=true, bool=true, bool=true, const QStringList &=QStringList(), const QIntList &=QIntList(), const QString &=QString())
 This is a convenience static function that returns an background data selected by the user. If the user presses Cancel, it returns an invalid background data. More...
static Qtx::BackgroundData getBackground (const Qtx::BackgroundData &, QWidget *, const QIntList &, bool=true, bool=true, bool=true, bool=true, const QStringList &=QStringList(), const QIntList &=QIntList(), const QString &=QString())
- Static Public Member Functions inherited from QtxDialog
static void setUnits (QLabel *, const QString &)
 Set measure units to the specified label. More...
void init ()
 Perform internal initialization. More...
QtxBackgroundTool * myTool
- Public Types inherited from QtxDialog
enum  PlacePolicy { Position , Expand , Uniform }
 Buttons alignment type. More...
enum  ButtonArea { TopArea , BottomArea , LeftArea , RightArea }
 Buttons area. More...
enum  ButtonPosition {
  Left , Right , Center , Top = Left ,
  Bottom = Right
 Button position. More...
enum  ButtonFlags {
  None = 0x00000000 , OK = 0x00000001 , Apply = 0x00000002 , Cancel = 0x00000004 ,
  Yes = 0x00000008 , No = 0x00000010 , Close = 0x00000020 , Help = 0x00000040 ,
  OKCancel = OK | Cancel , YesNo = Yes | No , Standard = OK | Cancel | Help , All = Standard | YesNo | Apply | Close
 Button ID flags. More...
enum  DialogFlags { Accept = 0x000001 , Reject = 0x000002 , AlignOnce = 0x000004 , SetFocus = 0x000008 }
 Dialog box flags. More...
- Public Slots inherited from QtxDialog
void update ()
 Update dialog box. More...
virtual void setVisible (bool)
 Show/hide dialog box, set keyboard focus to the dialog. More...
- Signals inherited from QtxDialog
void dlgButton (int)
 Emitted when the user button is clicked. More...
void dlgParamChanged ()
 This signal can be used in successor classes to signalize about some dialog parameter changing. More...
void dlgHelp ()
 Emitted when the "Help" button is clicked. More...
void dlgApply ()
 Emitted when the "Apply" button is clicked. More...
void dlgOk ()
 Emitted when the "OK" button is clicked. More...
void dlgNo ()
 Emitted when the "No" button is clicked. More...
void dlgYes ()
 Emitted when the "Yes" button is clicked. More...
void dlgClose ()
 Emitted when the "Close" button is clicked. More...
void dlgCancel ()
 Emitted when the "Cancel" button is clicked. More...
- Protected Types inherited from QtxDialog
typedef QMap< int, QAbstractButton * > ButtonMap
 button map More...
- Protected Slots inherited from QtxDialog
virtual void accept ()
 Accept the dialog box. More...
virtual void reject ()
 Reject the dialog box. More...
- Protected Member Functions inherited from QtxDialog
QFrame * mainFrame () const
 Get dialog box main frame widget. More...
virtual bool acceptData () const
 Check if data entered by the user is valid. More...
virtual bool rejectData () const
 Check if dialog box can be cancelled. More...
virtual QAbstractButton * createButton (QWidget *)
 Create new user button. More...
QAbstractButton * button (const int) const
 Get button by the specified ID. More...
ButtonMap buttons (const int=All) const
 Get buttons by the specified IDs. More...
int buttonId (const QAbstractButton *) const
 Get specified button's identifier. More...
int buttonPosition (QAbstractButton *) const
 Get position of specified button. More...
virtual void showEvent (QShowEvent *)
 Align this dialog according to the parent widget and alignment policy before the dialog box is shown. More...
virtual void hideEvent (QHideEvent *)
 Process all existing events when dialog box is hidden. More...
virtual void closeEvent (QCloseEvent *)
 Called when user closes dialog box. More...
virtual void childEvent (QChildEvent *)
 Update dialog box layout when the size grip is added. More...
virtual void keyPressEvent (QKeyEvent *)
 Process key pressing event. More...
Usage example:
// create dialog box
QtxBackgroundDialog dlg( this );
// assign gradients types
QStringList sl;
sl << "Horizontal" << "Vertical" << "First diagonal" << "Second diagonal";
dlg.setGradients(sl);
// disable image texture and custom gradient modes
dlg.setModeAllowed(Qtx::ImageBackground, false);
dlg.setModeAllowed(Qtx::CustomGradientBackground, false);
// initialize dialog box with the some background data
dlg.setData(backgroundData);
// execute dialog box and obtain result background data
if ( dlg.exec() ) {
Qtx::BackgroundData bgData = dlg.getBackgroundData();
Definition: QtxBackgroundTool.h:100
Stores background data.
Definition: Qtx.h:178
@ CustomGradientBackground
Definition: Qtx.h:140
Also it is possible to use static function:
if ( bgData.isValid() )
doSomething( bgData );
static Qtx::BackgroundData getBackground(const Qtx::BackgroundData &=Qtx::BackgroundData(), QWidget *=0, bool=true, bool=true, bool=true, bool=true, const QStringList &=QStringList(), const QIntList &=QIntList(), const QString &=QString())
This is a convenience static function that returns an background data selected by the user....
Definition: QtxBackgroundTool.cxx:679
bool isValid() const
Returns false if background data is not set (invalid)
Definition: Qtx.cxx:1941
◆ QtxBackgroundDialog() [1/2]
QtxBackgroundDialog::QtxBackgroundDialog ( QWidget *  parent = 0)
parentparent widget
References init().
◆ QtxBackgroundDialog() [2/2]
QtxBackgroundDialog::QtxBackgroundDialog ( const Qtx::BackgroundData &  bgData,
bgDatainitial background data
parentparent widget
References init(), and setData().
◆ ~QtxBackgroundDialog()
QtxBackgroundDialog::~QtxBackgroundDialog ( )
◆ data()
Qtx::BackgroundData QtxBackgroundDialog::data ( ) const
background data
References QtxBackgroundTool::data(), and myTool.
◆ getBackground() [1/2]
Qtx::BackgroundData QtxBackgroundDialog::getBackground ( const Qtx::BackgroundData &  bgData,
QWidget *  parent,
const QIntList &  tmList,
bool  enableSolidColor = true,
bool  enableGradient = true,
bool  enableCustom = true,
bool  enableTexture = true,
const QStringList &  gradList = QStringList(),
const QIntList &  idList = QIntList(),
const QString &  formats = QString()
By default:
  • all background modes are enabled
  • texture controls are shown
  • all texture modes are disabled
  • simple gradient types list is empty
  • all image formats are supported
To customize the dialog box behavior, initialize it passing the corresponding options to the function.
parentparent widget
tmListallowed texture modes
enableSolidColor"enable solid colored background mode" flag
enableGradient"enable simple gradient background mode" flag
enableCustom"enable custom gradient background mode" flag
enableTexture"show texture controls" flag
gradListlist of simple gradients names
idListlist of simple gradients identifiers
formatsimage formats
resulting background data chosen by the user or invalid data if users cancels operation
References Qtx::CenterTexture, Qtx::ColorBackground, Qtx::CustomGradientBackground, data(), setData(), setGradients(), setImageFormats(), setModeAllowed(), setTextureAllowed(), setTextureModeAllowed(), Qtx::SimpleGradientBackground, and Qtx::StretchTexture.
◆ getBackground() [2/2]
Qtx::BackgroundData QtxBackgroundDialog::getBackground ( const Qtx::BackgroundData &  bgData = Qtx::BackgroundData(),
QWidget *  parent = 0,
By default:
  • all texture modes are enabled
parentparent widget
References Qtx::ColorBackground, Qtx::CustomGradientBackground, data(), setData(), setGradients(), setImageFormats(), setModeAllowed(), setTextureAllowed(), and Qtx::SimpleGradientBackground.
◆ init()
◆ setData()
void QtxBackgroundDialog::setData ( const Qtx::BackgroundData &  bgData)
bgDatabackground data
References myTool, and QtxBackgroundTool::setData().
◆ setGradients()
void QtxBackgroundDialog::setGradients ( const QStringList &  gradList,
gradientsgradients names
idsoptional gradients identifiers; if not specified, gradients are automatically numbered starting from 0
References myTool, and QtxBackgroundTool::setGradients().
◆ setImageFormats()
void QtxBackgroundDialog::setImageFormats ( const QString &  formats)
References myTool, and QtxBackgroundTool::setImageFormats().
◆ setModeAllowed()
void QtxBackgroundDialog::setModeAllowed ( Qtx::BackgroundMode  mode,
bool  on = true
modebackground mode
onenable / disable flag
References myTool, and QtxBackgroundTool::setModeAllowed().
◆ setTextureAllowed()
void QtxBackgroundDialog::setTextureAllowed ( bool  on = true)
See also
References myTool, and QtxBackgroundTool::setTextureAllowed().
◆ setTextureModeAllowed()
void QtxBackgroundDialog::setTextureModeAllowed ( Qtx::TextureMode  mode,
bool  on = true
modetexture mode
onenable / disable flag (true by default)
See also
setTextureAllowed()
References myTool, and QtxBackgroundTool::setTextureModeAllowed().
◆ myTool
QtxBackgroundTool* QtxBackgroundDialog::myTool
