QtxBackgroundTool Class Reference
Implementation of the widget managing background data. More...
#include <QtxBackgroundTool.h>
Inheritance diagram for QtxBackgroundTool:
 QtxBackgroundTool (QWidget *=0)
 QtxBackgroundTool (Qt::Orientation, QWidget *=0)
virtual ~QtxBackgroundTool ()
Qtx::BackgroundData data () const
 Get background data from the widget. More...
void setData (const Qtx::BackgroundData &)
 Set background data from the widget. More...
void gradients (QStringList &, QIntList &) const
 Get allowed two-color gradients to the widget. More...
void setGradients (const QStringList &, const QIntList &=QIntList())
 Set allowed two-color gradients to the widget. More...
bool isModeAllowed (Qtx::BackgroundMode) const
 Check if specific background mode is allowed. More...
void setModeAllowed (Qtx::BackgroundMode, bool=true)
 Enable / disable specific background mode. More...
bool isTextureModeAllowed (Qtx::TextureMode) const
 Check if specific texture mode is allowed. More...
void setTextureModeAllowed (Qtx::TextureMode, bool=true)
 Enable / disable specific texture mode. More...
bool isTextureAllowed () const
 Check if texture controls are allowed (shown) More...
void setTextureAllowed (bool=true)
 Enable / disable texture controls. More...
QString imageFormats () const
 Get allowed image formats. More...
void setImageFormats (const QString &)
 Set allowed image formats. More...
Qt::Orientation orientation () const
 Get widget editor orientation. More...
void setOrientation (Qt::Orientation)
 Change widget orientation. More...
Private Types
enum  { Color , Gradient }
enum  { TypeRole = Qt::UserRole , IdRole }
Private Slots
void updateState ()
 Update widget state. More...
void browse ()
 Called when "Browse..." button is pressed. More...
void init (Qt::Orientation)
 Perform internal initialization. More...
void internalUpdate ()
 Initialization: fill in the widget with items according to the available modes. More...
QComboBox * myModeCombo
QStackedWidget * myCContainer
QWidget * myTContainer
QCheckBox * myTextureCheck
QLineEdit * myFileName
QPushButton * myBrowseBtn
QComboBox * myTextureMode
QtxColorButton * myFirstColor
QtxColorButton * mySecondColor
QStringList myGradients
QIntList myGradientsIds
bool myTextureAllowed
QMap< int, bool > myTypesAllowed
QMap< int, bool > myTextureTypesAllowed
QString myImageFormats
int myLastGradient
The background data can be specified as:
  • image (by assigning the file name to be used as background texture)
  • single color (by assigning any color)
  • simple two-color gradient (with the gradient type id and two colors)
  • complex gradient (by assigning arbitrary gradient data) (NOT IMPLEMENTED YET)
To enable / disable any background type, setModeAllowed() function can be used. Widget's orientation can be specified via the constructor parameter of changed with setOrientation() function.
To specify two-color gradient modes, use setGradient() function. By default, no gradient modes are provided by the widget.
Arbitrary gradient mode is not implemented yet, it is remaining for future improvement.
Typical usage can be as follows:
// create tool widget
// assign gradients types
QStringList sl;
sl << "Horizontal" << "Vertical" << "First diagonal" << "Second diagonal";
tool->setGradients(sl);
// disable image texture and custom gradient modes
tool->setModeAllowed(Qtx::ImageBackground, false);
// initialize widget with the some background data
tool->setData( bgData );
@ Vertical
Vertical orientation.
Definition: SalomePyQt.h:149
Definition: QtxBackgroundTool.h:40
void setGradients(const QStringList &, const QIntList &=QIntList())
Definition: QtxBackgroundTool.cxx:283
void setData(const Qtx::BackgroundData &)
Definition: QtxBackgroundTool.cxx:222
QtxBackgroundTool(QWidget *=0)
Definition: QtxBackgroundTool.cxx:82
void setModeAllowed(Qtx::BackgroundMode, bool=true)
Definition: QtxBackgroundTool.cxx:310
@ CustomGradientBackground
Definition: Qtx.h:140
Todo:
Complete support of custom gradient (QLinearGradient, QRadialGradient, QConicalGradient).
See also
Qtx::BackgroundData, QtxBackgroundDialog, Qtx::stringToBackground(), Qtx::backgroundToString()
◆ anonymous enum
anonymous enum
Color
Gradient
◆ anonymous enum
anonymous enum
TypeRole
IdRole
◆ QtxBackgroundTool() [1/2]
QtxBackgroundTool::QtxBackgroundTool ( QWidget *  parent = 0)
Creates a background data widget with horizontal orientation.
parentparent widget
References Horizontal, and init().
◆ QtxBackgroundTool() [2/2]
QtxBackgroundTool::QtxBackgroundTool ( Qt::Orientation  o,
Creates a background data widget with specified orientation.
owidget orientation
parentparent widget
References init().
◆ ~QtxBackgroundTool()
QtxBackgroundTool::~QtxBackgroundTool ( )
◆ browse
void QtxBackgroundTool::browse ( )
privateslot
References myFileName, and myImageFormats.
◆ data()
◆ gradients()
void QtxBackgroundTool::gradients ( QStringList &  gradList,
QIntList &  idList
gradientsgradients names are returned via this parameter
idsgradients identifiers are returned via this parameter (empty list can be returned)
References myGradients, and myGradientsIds.
◆ imageFormats()
QString QtxBackgroundTool::imageFormats ( ) const
image formats
See also
setImageFormats()
References myImageFormats.
◆ init()
◆ internalUpdate()
void QtxBackgroundTool::internalUpdate ( )
◆ isModeAllowed()
bool QtxBackgroundTool::isModeAllowed ( Qtx::BackgroundMode  mode) const
modebackground mode
true if specified background mode is enabled or false otherwise
See also
setModeAllowed()
References myTypesAllowed.
◆ isTextureAllowed()
bool QtxBackgroundTool::isTextureAllowed ( ) const
true if texture controls are enabled or false otherwise
See also
setTextureAllowed(), setTextureModeAllowed()
References myTextureAllowed.
◆ isTextureModeAllowed()
bool QtxBackgroundTool::isTextureModeAllowed ( Qtx::TextureMode  mode) const
modetexture mode
true if specified texture mode is enabled or false otherwise
See also
setTextureModeAllowed(), setTextureAllowed()
References myTextureTypesAllowed.
◆ orientation()
Qt::Orientation QtxBackgroundTool::orientation ( ) const
orientation
See also
setOrientation()
References Horizontal, and Vertical.
◆ setData()
void QtxBackgroundTool::setData ( const Qtx::BackgroundData &  bgData)
◆ setGradients()
void QtxBackgroundTool::setGradients ( const QStringList &  gradList,
const QIntList &  idList = QIntList()
idsoptional gradients identifiers; if not specified, gradients are automatically numbered starting from 0
References data(), internalUpdate(), myGradients, myGradientsIds, myLastGradient, and setData().
◆ setImageFormats()
void QtxBackgroundTool::setImageFormats ( const QString &  formats)
formatsimage formats
See also
imageFormats()
◆ setModeAllowed()
void QtxBackgroundTool::setModeAllowed ( Qtx::BackgroundMode  mode,
bool  on = true
modebackground mode
onenable / disable flag (true by default)
See also
isModeAllowed()
References Qtx::CustomGradientBackground, data(), internalUpdate(), isModeAllowed(), myTypesAllowed, and setData().
◆ setOrientation()
void QtxBackgroundTool::setOrientation ( Qt::Orientation  orientation)
orientationnew widget orientation
See also
orientation()
References Horizontal, isTextureAllowed(), myCContainer, myModeCombo, myTContainer, and orientation().
◆ setTextureAllowed()
void QtxBackgroundTool::setTextureAllowed ( bool  on = true)
See also
isTextureAllowed(), setTextureModeAllowed()
References myTextureAllowed, orientation(), and setOrientation().
◆ setTextureModeAllowed()
void QtxBackgroundTool::setTextureModeAllowed ( Qtx::TextureMode  mode,
bool  on = true
modetexture mode
See also
isTextureModeAllowed(), setTextureAllowed()
References data(), internalUpdate(), isTextureModeAllowed(), myTextureTypesAllowed, and setData().
◆ updateState
◆ myBrowseBtn
QPushButton* QtxBackgroundTool::myBrowseBtn
◆ myCContainer
QStackedWidget* QtxBackgroundTool::myCContainer
◆ myFileName
QLineEdit* QtxBackgroundTool::myFileName
◆ myFirstColor
QtxColorButton* QtxBackgroundTool::myFirstColor
◆ myGradients
QStringList QtxBackgroundTool::myGradients
◆ myGradientsIds
QIntList QtxBackgroundTool::myGradientsIds
◆ myImageFormats
QString QtxBackgroundTool::myImageFormats
◆ myLastGradient
int QtxBackgroundTool::myLastGradient
◆ myModeCombo
QComboBox* QtxBackgroundTool::myModeCombo
◆ mySecondColor
QtxColorButton* QtxBackgroundTool::mySecondColor
◆ myTContainer
QWidget* QtxBackgroundTool::myTContainer
◆ myTextureAllowed
bool QtxBackgroundTool::myTextureAllowed
◆ myTextureCheck
QCheckBox* QtxBackgroundTool::myTextureCheck
◆ myTextureMode
QComboBox* QtxBackgroundTool::myTextureMode
◆ myTextureTypesAllowed
QMap<int, bool> QtxBackgroundTool::myTextureTypesAllowed
◆ myTypesAllowed
QMap<int, bool> QtxBackgroundTool::myTypesAllowed
