SUIT_ActionSearcher Class Reference
Searches in data, provided in action asset files and shortcut preferences. More...
#include <SUIT_ShortcutMgr.h>
class  AssetsAndSearchData
enum  MatchField { ID , Name , ToolTip , KeySequence }
 SUIT_ActionSearcher ()
 SUIT_ActionSearcher (const SUIT_ActionSearcher &)=delete
SUIT_ActionSearcher & operator= (const SUIT_ActionSearcher &)=delete
virtual ~SUIT_ActionSearcher ()
bool setIncludedModuleIDs (std::set< QString > theIncludedModuleIDs, bool doNotUpdateResults=false)
bool includeDisabledActions (bool theOn, bool doNotUpdateResults=false)
bool areDisabledActionsIncluded () const
bool setFieldsToMatch (const std::set< SUIT_ActionSearcher::MatchField > &theFields, bool doNotUpdateResults=false)
std::pair< bool, bool > setKeySequenceGetter (const std::function< QString(const QString &, const QString &)> &theKeySequenceGetter=std::function< QString(const QString &, const QString &)>(), bool doNotUpdateResults=false)
bool setCaseSensitive (bool theOn, bool doNotUpdateResults=false)
bool setQuery (const QString &theQuery)
const QString & getQuery () const
const std::map< QString, std::map< QString, SUIT_ActionSearcher::AssetsAndSearchData > > & getSearchResults () const
static double matchKeySequenceString (const QString &theQuery, const QString &theKeySequence)
std::pair< bool, bool > filter ()
 Applies filter to all actions, provided in asset files for SUIT_ShortcutMgr. More...
std::pair< bool, bool > filterResults ()
 Applies filter to search results only. More...
bool extendResults ()
 Applies filter only to actions, which are not in search results. More...
double matchAction (const SUIT_ShortcutItemAssets &theAssets)
QString toString () const
std::set< QString > myIncludedModuleIDs
bool myIncludeDisabledActions
std::set< SUIT_ActionSearcher::MatchField > myFieldsToMatch
::SUIT_tools::SUIT_SentenceMatcher * myMatcher
std::function< QString(const QString &, const QString &)> myKeySequenceGetter
std::map< QString, std::map< QString, SUIT_ActionSearcher::AssetsAndSearchData > > mySearchResults
◆ MatchField
ID
Name
ToolTip
KeySequence
◆ SUIT_ActionSearcher() [1/2]
SUIT_ActionSearcher::SUIT_ActionSearcher ( )
Default config: Included modules' IDs = { ROOT_MODULE_ID }; Include disabled actions = false; Fields to match = { Name, Tooltip }; Case sensitive = false; Fuzzy matching = true; Query = ""; // matches nothing.
References SUIT_ShortcutMgr::get(), SUIT_ShortcutMgr::getKeySequence(), myFieldsToMatch, myIncludeDisabledActions, myIncludedModuleIDs, myKeySequenceGetter, myMatcher, SUIT_ShortcutMgr::ROOT_MODULE_ID, SUIT_tools::SUIT_SentenceMatcher::setCaseSensitive(), SUIT_tools::SUIT_SentenceMatcher::setUseExactWordOrder(), and SUIT_tools::SUIT_SentenceMatcher::setUseFuzzyWords().
◆ SUIT_ActionSearcher() [2/2]
SUIT_ActionSearcher::SUIT_ActionSearcher ( const SUIT_ActionSearcher &  )
delete
◆ ~SUIT_ActionSearcher()
SUIT_ActionSearcher::~SUIT_ActionSearcher ( )
References myMatcher.
◆ areDisabledActionsIncluded()
bool SUIT_ActionSearcher::areDisabledActionsIncluded ( ) const
◆ extendResults()
bool SUIT_ActionSearcher::extendResults ( )
True, if set of results is extended.
References SUIT_ShortcutMgr::get(), matchAction(), myIncludedModuleIDs, mySearchResults, ShCutDbg(), and TOKEN_SEPARATOR.
◆ filter()
std::pair< bool, bool > SUIT_ActionSearcher::filter ( )
{ true, _ } if set of results is changed; { _ , true } if matching metrics is changed for at least one result.
References SUIT_ShortcutMgr::get(), matchAction(), SUIT_ActionSearcher::AssetsAndSearchData::matchMetrics(), SUIT_ActionSearcher::AssetsAndSearchData::myAssets, myIncludedModuleIDs, mySearchResults, SUIT_ActionSearcher::AssetsAndSearchData::setMatchMetrics(), and ShCutDbg().
◆ filterResults()
std::pair< bool, bool > SUIT_ActionSearcher::filterResults ( )
{ true, _ } if set of results is shrunk; { _ , true } if matching metrics is changed for at least one result.
References matchAction(), SUIT_ActionSearcher::AssetsAndSearchData::matchMetrics(), SUIT_ActionSearcher::AssetsAndSearchData::myAssets, mySearchResults, and SUIT_ActionSearcher::AssetsAndSearchData::setMatchMetrics().
◆ getQuery()
const QString & SUIT_ActionSearcher::getQuery ( ) const
◆ getSearchResults()
const std::map< QString, std::map< QString, SUIT_ActionSearcher::AssetsAndSearchData > > & SUIT_ActionSearcher::getSearchResults ( ) const
References mySearchResults.
◆ includeDisabledActions()
bool SUIT_ActionSearcher::includeDisabledActions ( bool  theOn,
bool  doNotUpdateResults = false
true, if set of results is changed.
doNotUpdateResultsSet to true to initialize the instance without unnececessary computations.
References extendResults(), filterResults(), myIncludeDisabledActions, ShCutDbg(), and toString().
◆ matchAction()
◆ matchKeySequenceString()
double SUIT_ActionSearcher::matchKeySequenceString ( const QString &  theQuery,
const QString &  theKeySequence
◆ operator=()
SUIT_ActionSearcher & SUIT_ActionSearcher::operator= ( const SUIT_ActionSearcher &  )
delete
◆ setCaseSensitive()
bool SUIT_ActionSearcher::setCaseSensitive ( bool  theOn,
References extendResults(), filterResults(), SUIT_tools::SUIT_SentenceMatcher::isCaseSensitive(), myMatcher, SUIT_tools::SUIT_SentenceMatcher::setCaseSensitive(), ShCutDbg(), and toString().
◆ setFieldsToMatch()
bool SUIT_ActionSearcher::setFieldsToMatch ( const std::set< SUIT_ActionSearcher::MatchField > &  theFields,
References extendResults(), filter(), filterResults(), myFieldsToMatch, mySearchResults, ShCutDbg(), and toString().
◆ setIncludedModuleIDs()
bool SUIT_ActionSearcher::setIncludedModuleIDs ( std::set< QString >  theIncludedModuleIDs,
References SUIT_ShortcutMgr::get(), SUIT_ShortcutMgr::getModuleAssets(), matchAction(), myIncludedModuleIDs, mySearchResults, ShCutDbg(), and toString().
◆ setKeySequenceGetter()
std::pair< bool, bool > SUIT_ActionSearcher::setKeySequenceGetter ( const std::function< QString(const QString &, const QString &)> &  theKeySequenceGetter = std::function<QString(const QString&, const QString&)>(),
theKeySequenceGettergetKeySequence(theModuleID, theInModuleActionID). If empty, a default getter, retrieving key sequence from ShortcutMgr, is set.
References filter(), SUIT_ShortcutMgr::get(), SUIT_ShortcutMgr::getKeySequence(), and myKeySequenceGetter.
◆ setQuery()
bool SUIT_ActionSearcher::setQuery ( const QString &  theQuery)
◆ toString()
QString SUIT_ActionSearcher::toString ( ) const
◆ myFieldsToMatch
std::set<SUIT_ActionSearcher::MatchField> SUIT_ActionSearcher::myFieldsToMatch
◆ myIncludeDisabledActions
bool SUIT_ActionSearcher::myIncludeDisabledActions
◆ myIncludedModuleIDs
std::set<QString> SUIT_ActionSearcher::myIncludedModuleIDs
◆ myKeySequenceGetter
std::function<QString(const QString&, const QString&)> SUIT_ActionSearcher::myKeySequenceGetter
◆ myMatcher
::SUIT_tools::SUIT_SentenceMatcher* SUIT_ActionSearcher::myMatcher
◆ mySearchResults
std::map<QString, std::map<QString, SUIT_ActionSearcher::AssetsAndSearchData> > SUIT_ActionSearcher::mySearchResults
