SUIT_ShortcutItemAssets Class Reference
May represent not just an action, but also a folder within item tree of a module. May also represent action-folder: an action with nested actions. Each action inModuleID is unique within a tree of assets. More...
#include <SUIT_ShortcutMgr.h>
Inheritance diagram for SUIT_ShortcutItemAssets:
 ~SUIT_ShortcutItemAssets ()=default
int depth () const
SUIT_ShortcutAssets::Type type () const
void merge (const SUIT_ShortcutItemAssets &theOther, bool theOverride)
virtual void merge (SUIT_ShortcutItemAssets &&theOther, bool theOverride)
const QString & bestName (const QString &theLang=QString()) const
const QString & bestPath (const QString theLang=QString()) const
 Composed as <depth_1_item.bestName>/...<depth_N_item.bestName>.../<this->bestName>. Module name is not included. More...
QString description () const
bool isAction () const
bool isFolder () const
std::shared_ptr< SUIT_ShortcutAssets > parent () const
std::shared_ptr< SUIT_ShortcutModuleAssets > module () const
QString actionID () const
 Even if SUIT_ShortcutItemAssets is not action, its ID is composed in the same way. More...
const QIcon & icon () const
- Public Member Functions inherited from SUIT_ShortcutAssets
virtual ~SUIT_ShortcutAssets ()=0
const std::map< QString, std::shared_ptr< SUIT_ShortcutItemAssets > > & children () const
std::shared_ptr< SUIT_ShortcutItemAssets > findDescendantItem (const QString &theRelativeID) const
std::shared_ptr< SUIT_ShortcutItemAssets > descendantItem (const QString &theRelativeID, bool theIsAction=true)
virtual int depth () const =0
virtual SUIT_ShortcutAssets::Type type () const =0
bool fromJSON (const QJsonObject &theJsonObject, bool theParseDescendants=true, const std::set< QString > &theLangs={})
bool fromJSON (const QJsonObject &theJsonObject, const QString &theRelativeID, const std::set< QString > &theLangs={})
 Parses only the branch of descdendants, which leads to the item with theRelativeID. More...
void toJSON (QJsonObject &oJsonObject) const
virtual void merge (const SUIT_ShortcutAssets &theOther, bool theOverride)
virtual void merge (SUIT_ShortcutAssets &&theOther, bool theOverride)
void loadIcon (bool theReload=false)
void forEachDescendant (const std::function< void(SUIT_ShortcutItemAssets &)> &theFunc) const
 Iterates all descendants. *this is not iterated. More...
void forEachDescendant (const std::function< void(const SUIT_ShortcutItemAssets &)> &theFunc) const
void forEachDescendant (const std::function< void(std::shared_ptr< SUIT_ShortcutItemAssets >)> &theFunc) const
void forEachDescendant (const std::function< void(std::shared_ptr< const SUIT_ShortcutItemAssets >)> &theFunc) const
QString toString () const
virtual QString description () const =0
QStringList getLangs () const
void clearAllLangsExcept (const QString &theLang)
const LangDependentAssets * bestLangDependentAssets (QString theLang=QString()) const
virtual const QString & bestName (const QString &theLang=QString()) const =0
virtual const QString & bestToolTip (const QString &theLang=QString()) const
static void loadDefaultIcons ()
Public Attributes
const QString myIDLastToken
const QString myInModuleID
- Public Attributes inherited from SUIT_ShortcutAssets
const QString myModuleID
std::map< QString, LangDependentAssets > myLangDependentAssets
QString myIconPath
QIcon myIcon
Static Public Attributes
static const QString PROP_ID_IS_ACTION = "isAction"
- Static Public Attributes inherited from SUIT_ShortcutAssets
static const QString PROP_ID_LANG_DEPENDENT_ASSETS = "langDependentAssets"
static const QString PROP_ID_ICON_PATH = "iconPath"
static const QString PROP_ID_CHILDREN = "children"
 SUIT_ShortcutItemAssets (std::shared_ptr< SUIT_ShortcutModuleAssets > theModule, const QString &theIDLastToken, bool theIsAction=true)
 Creates root item of module. More...
 SUIT_ShortcutItemAssets (std::shared_ptr< SUIT_ShortcutItemAssets > theParentItem, const QString &theIDLastToken, bool theIsAction=true)
 Creates nested item within item tree of module. More...
 SUIT_ShortcutItemAssets (const SUIT_ShortcutItemAssets &)=delete
SUIT_ShortcutItemAssets & operator= (const SUIT_ShortcutItemAssets &)=delete
bool fromJSONOtherProps (const QJsonObject &theJsonObject)
 Parses properties of SUIT_ShortcutAssets subclasses. More...
void toJSONVirtual (QJsonObject &oJsonObject) const
static std::shared_ptr< SUIT_ShortcutItemAssets > create (std::shared_ptr< SUIT_ShortcutAssets > theParentItemOrModule, const QString &theIDLastToken, bool theIsAction=true)
std::weak_ptr< SUIT_ShortcutAssets > myParent
bool myIsAction
const int myDepth
std::map< QString, QString > myBestPaths
 {lang, bestPath}[] More...
Static Private Attributes
static QIcon DEFAUT_ICON_ACTION = QIcon()
static QIcon DEFAUT_ICON_FOLDER = QIcon()
static QIcon DEFAUT_ICON_FOLDER_ACTION = QIcon()
Friends
class SUIT_ShortcutAssets
- Public Types inherited from SUIT_ShortcutAssets
enum class  Type { Module , Item }
- Protected Member Functions inherited from SUIT_ShortcutAssets
 SUIT_ShortcutAssets (const QString &theModuleID)
◆ SUIT_ShortcutItemAssets() [1/3]
SUIT_ShortcutItemAssets::SUIT_ShortcutItemAssets ( std::shared_ptr< SUIT_ShortcutModuleAssets >  theModule,
const QString &  theIDLastToken,
bool  theIsAction = true
theModulemust not be nullptr.
theIDLastTokenis also a inModuleID.
◆ SUIT_ShortcutItemAssets() [2/3]
SUIT_ShortcutItemAssets::SUIT_ShortcutItemAssets ( std::shared_ptr< SUIT_ShortcutItemAssets >  theParentItem,
theParentmust not be nullptr.
◆ SUIT_ShortcutItemAssets() [3/3]
SUIT_ShortcutItemAssets::SUIT_ShortcutItemAssets ( const SUIT_ShortcutItemAssets &  )
privatedelete
◆ ~SUIT_ShortcutItemAssets()
SUIT_ShortcutItemAssets::~SUIT_ShortcutItemAssets ( )
default
◆ actionID()
QString SUIT_ShortcutItemAssets::actionID ( ) const
References myInModuleID, SUIT_ShortcutAssets::myModuleID, and TOKEN_SEPARATOR.
◆ bestName()
const QString & SUIT_ShortcutItemAssets::bestName ( const QString &  theLang = QString()) const
theLangIf empty, current language is requested.
Requested name or name in EN, if requested language is absent. If EN is absent - inModuleID.
Implements SUIT_ShortcutAssets.
References SUIT_ShortcutAssets::bestLangDependentAssets(), and myIDLastToken.
◆ bestPath()
const QString & SUIT_ShortcutItemAssets::bestPath ( const QString  theLang = QString()) const
References actionID(), bestName(), SUIT_ShortcutMgr::currentLang(), depth(), SUIT_ShortcutAssets::Item, myBestPaths, myInModuleID, parent(), SUIT_ShortcutMgr::splitIntoTokens(), TOKEN_SEPARATOR, and Warning().
◆ create()
std::shared_ptr< SUIT_ShortcutItemAssets > SUIT_ShortcutItemAssets::create ( std::shared_ptr< SUIT_ShortcutAssets >  theParentItemOrModule,
staticprivate
◆ depth()
int SUIT_ShortcutItemAssets::depth ( ) const
References myDepth.
◆ description()
QString SUIT_ShortcutItemAssets::description ( ) const
References actionID(), and myIsAction.
◆ fromJSONOtherProps()
bool SUIT_ShortcutItemAssets::fromJSONOtherProps ( const QJsonObject &  theJsonObject)
privatevirtual
true, if any property is parsed.
Reimplemented from SUIT_ShortcutAssets.
References myIsAction, and PROP_ID_IS_ACTION.
◆ icon()
const QIcon & SUIT_ShortcutItemAssets::icon ( ) const
myIcon, if !myIcon.isNull(). Otherwise returns appropriate default icon.
References SUIT_ShortcutAssets::children(), DEFAUT_ICON_ACTION, DEFAUT_ICON_FOLDER, DEFAUT_ICON_FOLDER_ACTION, SUIT_ShortcutAssets::myIcon, and myIsAction.
◆ isAction()
bool SUIT_ShortcutItemAssets::isAction ( ) const
References myIsAction.
◆ isFolder()
bool SUIT_ShortcutItemAssets::isFolder ( ) const
◆ loadDefaultIcons()
void SUIT_ShortcutItemAssets::loadDefaultIcons ( )
◆ merge() [1/2]
void SUIT_ShortcutItemAssets::merge ( const SUIT_ShortcutItemAssets &  theOther,
bool  theOverride
theOverrideIf true, values of theOther override conflicting values of this.
References SUIT_ShortcutAssets::merge(), myInModuleID, myIsAction, SUIT_ShortcutAssets::myModuleID, TOKEN_SEPARATOR, and Warning().
◆ merge() [2/2]
void SUIT_ShortcutItemAssets::merge ( SUIT_ShortcutItemAssets &&  theOther,
bool  theOverride
◆ module()
std::shared_ptr< SUIT_ShortcutModuleAssets > SUIT_ShortcutItemAssets::module ( ) const
◆ operator=()
SUIT_ShortcutItemAssets & SUIT_ShortcutItemAssets::operator= ( const SUIT_ShortcutItemAssets &  )
privatedelete
◆ parent()
std::shared_ptr< SUIT_ShortcutAssets > SUIT_ShortcutItemAssets::parent ( ) const
References myParent.
◆ toJSONVirtual()
void SUIT_ShortcutItemAssets::toJSONVirtual ( QJsonObject &  oJsonObject) const
privatevirtual
◆ type()
SUIT_ShortcutAssets::Type SUIT_ShortcutItemAssets::type ( ) const
◆ SUIT_ShortcutAssets
friend class SUIT_ShortcutAssets
friend
◆ DEFAUT_ICON_ACTION
QIcon SUIT_ShortcutItemAssets::DEFAUT_ICON_ACTION = QIcon()
staticprivate
◆ DEFAUT_ICON_FOLDER
QIcon SUIT_ShortcutItemAssets::DEFAUT_ICON_FOLDER = QIcon()
staticprivate
◆ DEFAUT_ICON_FOLDER_ACTION
QIcon SUIT_ShortcutItemAssets::DEFAUT_ICON_FOLDER_ACTION = QIcon()
staticprivate
◆ myBestPaths
std::map<QString, QString> SUIT_ShortcutItemAssets::myBestPaths
mutableprivate
{lang, bestPath}[]
◆ myDepth
const int SUIT_ShortcutItemAssets::myDepth
◆ myIDLastToken
const QString SUIT_ShortcutItemAssets::myIDLastToken
◆ myInModuleID
const QString SUIT_ShortcutItemAssets::myInModuleID
◆ myIsAction
bool SUIT_ShortcutItemAssets::myIsAction
◆ myParent
std::weak_ptr<SUIT_ShortcutAssets> SUIT_ShortcutItemAssets::myParent
◆ PROP_ID_IS_ACTION
const QString SUIT_ShortcutItemAssets::PROP_ID_IS_ACTION = "isAction"
