SUIT_ShortcutModuleAssets Class Reference
GUI-related module assets. More...
#include <SUIT_ShortcutMgr.h>
Inheritance diagram for SUIT_ShortcutModuleAssets:
 ~SUIT_ShortcutModuleAssets ()=default
int depth () const
SUIT_ShortcutAssets::Type type () const
const QString & bestName (const QString &theLang=QString()) const
QString description () const
- Public Member Functions inherited from SUIT_ShortcutAssets
virtual ~SUIT_ShortcutAssets ()=0
const std::map< QString, std::shared_ptr< SUIT_ShortcutItemAssets > > & children () const
std::shared_ptr< SUIT_ShortcutItemAssets > findDescendantItem (const QString &theRelativeID) const
std::shared_ptr< SUIT_ShortcutItemAssets > descendantItem (const QString &theRelativeID, bool theIsAction=true)
virtual int depth () const =0
virtual SUIT_ShortcutAssets::Type type () const =0
bool fromJSON (const QJsonObject &theJsonObject, bool theParseDescendants=true, const std::set< QString > &theLangs={})
bool fromJSON (const QJsonObject &theJsonObject, const QString &theRelativeID, const std::set< QString > &theLangs={})
 Parses only the branch of descdendants, which leads to the item with theRelativeID. More...
void toJSON (QJsonObject &oJsonObject) const
virtual void merge (const SUIT_ShortcutAssets &theOther, bool theOverride)
virtual void merge (SUIT_ShortcutAssets &&theOther, bool theOverride)
void loadIcon (bool theReload=false)
void forEachDescendant (const std::function< void(SUIT_ShortcutItemAssets &)> &theFunc) const
 Iterates all descendants. *this is not iterated. More...
void forEachDescendant (const std::function< void(const SUIT_ShortcutItemAssets &)> &theFunc) const
void forEachDescendant (const std::function< void(std::shared_ptr< SUIT_ShortcutItemAssets >)> &theFunc) const
void forEachDescendant (const std::function< void(std::shared_ptr< const SUIT_ShortcutItemAssets >)> &theFunc) const
QString toString () const
virtual QString description () const =0
QStringList getLangs () const
void clearAllLangsExcept (const QString &theLang)
const LangDependentAssets * bestLangDependentAssets (QString theLang=QString()) const
virtual const QString & bestName (const QString &theLang=QString()) const =0
virtual const QString & bestToolTip (const QString &theLang=QString()) const
static std::shared_ptr< SUIT_ShortcutModuleAssets > create (const QString &theModuleID)
 SUIT_ShortcutModuleAssets (const QString &theModuleID)
 SUIT_ShortcutModuleAssets (const SUIT_ShortcutModuleAssets &)=delete
SUIT_ShortcutModuleAssets & operator= (const SUIT_ShortcutModuleAssets &)=delete
- Public Types inherited from SUIT_ShortcutAssets
enum class  Type { Module , Item }
- Public Attributes inherited from SUIT_ShortcutAssets
const QString myModuleID
std::map< QString, LangDependentAssets > myLangDependentAssets
QString myIconPath
QIcon myIcon
- Static Public Attributes inherited from SUIT_ShortcutAssets
static const QString PROP_ID_LANG_DEPENDENT_ASSETS = "langDependentAssets"
static const QString PROP_ID_ICON_PATH = "iconPath"
static const QString PROP_ID_CHILDREN = "children"
- Protected Member Functions inherited from SUIT_ShortcutAssets
 SUIT_ShortcutAssets (const QString &theModuleID)
◆ SUIT_ShortcutModuleAssets() [1/2]
SUIT_ShortcutModuleAssets::SUIT_ShortcutModuleAssets ( const QString &  theModuleID)
◆ SUIT_ShortcutModuleAssets() [2/2]
SUIT_ShortcutModuleAssets::SUIT_ShortcutModuleAssets ( const SUIT_ShortcutModuleAssets &  )
privatedelete
◆ ~SUIT_ShortcutModuleAssets()
SUIT_ShortcutModuleAssets::~SUIT_ShortcutModuleAssets ( )
default
◆ bestName()
const QString & SUIT_ShortcutModuleAssets::bestName ( const QString &  theLang = QString()) const
theLangIf empty, current language is requested.
Requested name or name in EN, if requested language is absent. If EN is absent - moduleID.
Implements SUIT_ShortcutAssets.
References SUIT_ShortcutAssets::bestLangDependentAssets(), and SUIT_ShortcutAssets::myModuleID.
◆ create()
std::shared_ptr< SUIT_ShortcutModuleAssets > SUIT_ShortcutModuleAssets::create ( const QString &  theModuleID)
◆ depth()
int SUIT_ShortcutModuleAssets::depth ( ) const
◆ description()
QString SUIT_ShortcutModuleAssets::description ( ) const
◆ operator=()
SUIT_ShortcutModuleAssets & SUIT_ShortcutModuleAssets::operator= ( const SUIT_ShortcutModuleAssets &  )
privatedelete
◆ type()
SUIT_ShortcutAssets::Type SUIT_ShortcutModuleAssets::type ( ) const
