SUIT_ShortcutAssets Class Referenceabstract
Base class for GUI-related assets of module, action or folder. Used by Shortcut Manager, Find Action Dialog, etc. More...
#include <SUIT_ShortcutMgr.h>
Inheritance diagram for SUIT_ShortcutAssets:
struct  LangDependentAssets
enum class  Type { Module , Item }
virtual ~SUIT_ShortcutAssets ()=0
const std::map< QString, std::shared_ptr< SUIT_ShortcutItemAssets > > & children () const
std::shared_ptr< SUIT_ShortcutItemAssets > findDescendantItem (const QString &theRelativeID) const
std::shared_ptr< SUIT_ShortcutItemAssets > descendantItem (const QString &theRelativeID, bool theIsAction=true)
virtual int depth () const =0
virtual SUIT_ShortcutAssets::Type type () const =0
bool fromJSON (const QJsonObject &theJsonObject, bool theParseDescendants=true, const std::set< QString > &theLangs={})
bool fromJSON (const QJsonObject &theJsonObject, const QString &theRelativeID, const std::set< QString > &theLangs={})
 Parses only the branch of descdendants, which leads to the item with theRelativeID. More...
void toJSON (QJsonObject &oJsonObject) const
virtual void merge (const SUIT_ShortcutAssets &theOther, bool theOverride)
virtual void merge (SUIT_ShortcutAssets &&theOther, bool theOverride)
void loadIcon (bool theReload=false)
void forEachDescendant (const std::function< void(SUIT_ShortcutItemAssets &)> &theFunc) const
 Iterates all descendants. *this is not iterated. More...
void forEachDescendant (const std::function< void(const SUIT_ShortcutItemAssets &)> &theFunc) const
void forEachDescendant (const std::function< void(std::shared_ptr< SUIT_ShortcutItemAssets >)> &theFunc) const
void forEachDescendant (const std::function< void(std::shared_ptr< const SUIT_ShortcutItemAssets >)> &theFunc) const
QString toString () const
virtual QString description () const =0
QStringList getLangs () const
void clearAllLangsExcept (const QString &theLang)
const LangDependentAssets * bestLangDependentAssets (QString theLang=QString()) const
virtual const QString & bestName (const QString &theLang=QString()) const =0
virtual const QString & bestToolTip (const QString &theLang=QString()) const
Public Attributes
const QString myModuleID
std::map< QString, LangDependentAssets > myLangDependentAssets
QString myIconPath
QIcon myIcon
Static Public Attributes
static const QString PROP_ID_LANG_DEPENDENT_ASSETS = "langDependentAssets"
static const QString PROP_ID_ICON_PATH = "iconPath"
static const QString PROP_ID_CHILDREN = "children"
 SUIT_ShortcutAssets (const QString &theModuleID)
bool fromJSONOwnProps (const QJsonObject &theJsonObject, const std::set< QString > &theLangs={})
 Parses everything, except children. More...
virtual bool fromJSONOtherProps (const QJsonObject &theJsonObject)
 Parses properties of SUIT_ShortcutAssets subclasses. More...
virtual void toJSONVirtual (QJsonObject &oJsonObject) const
std::map< QString, std::shared_ptr< SUIT_ShortcutItemAssets > > myChildren
◆ Type
enum class SUIT_ShortcutAssets::Type
strong
Module
Item
◆ SUIT_ShortcutAssets()
SUIT_ShortcutAssets::SUIT_ShortcutAssets ( const QString &  theModuleID)
◆ ~SUIT_ShortcutAssets()
SUIT_ShortcutAssets::~SUIT_ShortcutAssets ( )
pure virtual
◆ bestLangDependentAssets()
const SUIT_ShortcutAssets::LangDependentAssets * SUIT_ShortcutAssets::bestLangDependentAssets ( QString  theLang = QString()) const
theLangIf empty, current language is requested.
Requested assets or assets in EN, if requested language is absent.
References SUIT_ShortcutMgr::currentLang(), DEFAULT_LANG, and myLangDependentAssets.
◆ bestName()
virtual const QString & SUIT_ShortcutAssets::bestName ( const QString &  theLang = QString()) const
pure virtual
◆ bestToolTip()
const QString & SUIT_ShortcutAssets::bestToolTip ( const QString &  theLang = QString()) const
Requested tool tip or tool tip in EN, if requested language is absent. If EN is absent - empty string.
References bestLangDependentAssets().
◆ children()
const std::map< QString, std::shared_ptr< SUIT_ShortcutItemAssets > > & SUIT_ShortcutAssets::children ( ) const
References myChildren.
◆ clearAllLangsExcept()
void SUIT_ShortcutAssets::clearAllLangsExcept ( const QString &  theLang)
References myLangDependentAssets.
◆ depth()
virtual int SUIT_ShortcutAssets::depth ( ) const
pure virtual
◆ descendantItem()
std::shared_ptr< SUIT_ShortcutItemAssets > SUIT_ShortcutAssets::descendantItem ( const QString &  theRelativeID,
bool  theIsAction = true
theRelativeIDIf empty, nullptr is returned.
theIsActionIf true and the descendant is missing, makes the created item action.
Descdendant item with inModuleID = myInModuleID/theRelativeID. If the descendant item does not exist, creates the item and its missing ancestors. All missing ancestors are created as not actions. Module assets effectively have empty myInModuleID.
References SUIT_ShortcutItemAssets::create(), and SUIT_ShortcutMgr::splitIntoTokens().
◆ description()
virtual QString SUIT_ShortcutAssets::description ( ) const
pure virtual
◆ findDescendantItem()
std::shared_ptr< SUIT_ShortcutItemAssets > SUIT_ShortcutAssets::findDescendantItem ( const QString &  theRelativeID) const
Descdendant item (if exist) with inModuleID = myInModuleID/theRelativeID. Module assets effectively have empty myInModuleID.
References SUIT_ShortcutMgr::splitIntoTokens().
◆ forEachDescendant() [1/4]
void SUIT_ShortcutAssets::forEachDescendant ( const std::function< void(const SUIT_ShortcutItemAssets &)> &  theFunc) const
References forEachDescendant(), and myChildren.
◆ forEachDescendant() [2/4]
void SUIT_ShortcutAssets::forEachDescendant ( const std::function< void(std::shared_ptr< const SUIT_ShortcutItemAssets >)> &  theFunc) const
◆ forEachDescendant() [3/4]
void SUIT_ShortcutAssets::forEachDescendant ( const std::function< void(std::shared_ptr< SUIT_ShortcutItemAssets >)> &  theFunc) const
◆ forEachDescendant() [4/4]
void SUIT_ShortcutAssets::forEachDescendant ( const std::function< void(SUIT_ShortcutItemAssets &)> &  theFunc) const
◆ fromJSON() [1/2]
bool SUIT_ShortcutAssets::fromJSON ( const QJsonObject &  theJsonObject,
bool  theParseDescendants = true,
const std::set< QString > &  theLangs = {}
theLangsIf empty, LangDependentAssets in all available languages are parsed.
true, if any property is parsed.
References SUIT_ShortcutItemAssets::create(), description(), fromJSONOwnProps(), SUIT_ShortcutMgr::isInModuleIDTokenValid(), myChildren, PROP_ID_CHILDREN, and Warning().
◆ fromJSON() [2/2]
theRelativeIDIf empty, no descendants are added/updated.
References SUIT_ShortcutItemAssets::create(), description(), fromJSONOwnProps(), SUIT_ShortcutMgr::isInModuleIDTokenValid(), SUIT_ShortcutMgr::joinIntoRelativeID(), myChildren, PROP_ID_CHILDREN, SUIT_ShortcutMgr::splitIntoTokens(), and Warning().
◆ fromJSONOtherProps()
virtual bool SUIT_ShortcutAssets::fromJSONOtherProps ( const QJsonObject &  theJsonObject)
inlineprivatevirtual
Reimplemented in SUIT_ShortcutItemAssets.
◆ fromJSONOwnProps()
bool SUIT_ShortcutAssets::fromJSONOwnProps ( const QJsonObject &  theJsonObject,
References fromJSONOtherProps(), myIconPath, myLangDependentAssets, PROP_ID_ICON_PATH, and PROP_ID_LANG_DEPENDENT_ASSETS.
◆ getLangs()
QStringList SUIT_ShortcutAssets::getLangs ( ) const
◆ loadIcon()
void SUIT_ShortcutAssets::loadIcon ( bool  theReload = false)
◆ merge() [1/2]
void SUIT_ShortcutAssets::merge ( const SUIT_ShortcutAssets &  theOther,
bool  theOverride
theOverrideIf true, values of theOther override conflicting values of this.
References SUIT_ShortcutItemAssets::create(), loadIcon(), myChildren, myIcon, myIconPath, myLangDependentAssets, myModuleID, and Warning().
◆ merge() [2/2]
void SUIT_ShortcutAssets::merge ( SUIT_ShortcutAssets &&  theOther,
bool  theOverride
References loadIcon(), myChildren, myIcon, myIconPath, myLangDependentAssets, myModuleID, and Warning().
◆ toJSON()
void SUIT_ShortcutAssets::toJSON ( QJsonObject &  oJsonObject) const
◆ toJSONVirtual()
virtual void SUIT_ShortcutAssets::toJSONVirtual ( QJsonObject &  oJsonObject) const
◆ toString()
QString SUIT_ShortcutAssets::toString ( ) const
References toJSON().
◆ type()
virtual SUIT_ShortcutAssets::Type SUIT_ShortcutAssets::type ( ) const
pure virtual
◆ myChildren
std::map<QString, std::shared_ptr<SUIT_ShortcutItemAssets> > SUIT_ShortcutAssets::myChildren
◆ myIcon
QIcon SUIT_ShortcutAssets::myIcon
Not serialized.
◆ myIconPath
QString SUIT_ShortcutAssets::myIconPath
◆ myLangDependentAssets
std::map<QString, LangDependentAssets> SUIT_ShortcutAssets::myLangDependentAssets
◆ myModuleID
const QString SUIT_ShortcutAssets::myModuleID
◆ PROP_ID_CHILDREN
const QString SUIT_ShortcutAssets::PROP_ID_CHILDREN = "children"
◆ PROP_ID_ICON_PATH
const QString SUIT_ShortcutAssets::PROP_ID_ICON_PATH = "iconPath"
◆ PROP_ID_LANG_DEPENDENT_ASSETS
const QString SUIT_ShortcutAssets::PROP_ID_LANG_DEPENDENT_ASSETS = "langDependentAssets"
