SUIT_ShortcutTabWidget Class Reference
Main element of Shotcut Editor GUI. Each tab presents a shortcut tree of a module. More...
#include <SUIT_ShortcutEditor.h>
Inheritance diagram for SUIT_ShortcutTabWidget:
 SUIT_ShortcutTabWidget (const std::set< QString > &theIDsOfModulesToShow, std::shared_ptr< SUIT_ShortcutContainer > theContainer=std::shared_ptr< SUIT_ShortcutContainer >(), QWidget *theParent=nullptr)
SUIT_ShortcutTabWidget & operator= (const SUIT_ShortcutTree &)=delete
virtual ~SUIT_ShortcutTabWidget ()
void setShortcutsFromManager ()
 Copies shortcuts from ShortcutMgr. (Re)displays shortcuts of myModuleIDs. More...
void setDefaultShortcuts ()
 Copies shortcuts from resources, user files are not accounted. (Re)displays shortcuts of myModuleIDs. More...
void applyChangesToShortcutMgr ()
 Applies pending changes to ShortcutMgr. Updates other instances of SUIT_ShortcutTabWidget. More...
std::shared_ptr< const SUIT_ShortcutContainer > shortcutContainer () const
void onTreeItemDoubleClicked (SUIT_ShortcutTree *theTree, SUIT_ShortcutTreeItem *theItem)
Public Attributes
const std::set< QString > myModuleIDs
 Keeps IDs of modules, which will are shown on setShortcutsFromManager(). More...
void jumpToTreeItem (const QString &theModuleID, const QString &theInModuleID)
std::pair< QString, bool > getConfirmedKeySequence (const QString &theModuleID, const QString &theInModuleActionID) const
void updateTabs (bool theHighlightModifiedTreeItems, bool theUpdateSyncTabWidgets)
const std::shared_ptr< SUIT_ShortcutContainer > myShortcutContainer
 Allows to modify plenty of shortcuts and then apply them to SUIT_ShortcutMgr as a batch. More...
SUIT_FindActionWidget * myFindActionWidget
std::map< QString, SUIT_ShortcutTree * > myModuleTrees
 {moduleID, SUIT_ShortcutTree}. More...
SUIT_EditKeySequenceDialog * myEditDialog
bool myIsPopulated
Static Private Attributes
static std::map< SUIT_ShortcutContainer *, std::set< SUIT_ShortcutTabWidget * > > instances
 Ensures that, if several SUIT_ShortcutTab instances coexist, all of them are updated when one of them applies pending changes to SUIT_ShortcutMgr. More...
Friends
class SUIT_ShortcutTree
◆ SUIT_ShortcutTabWidget()
SUIT_ShortcutTabWidget::SUIT_ShortcutTabWidget ( const std::set< QString > &  theIDsOfModulesToShow,
std::shared_ptr< SUIT_ShortcutContainer >  theContainer = std::shared_ptr<SUIT_ShortcutContainer>(),
QWidget *  theParent = nullptr
theContainerShare the same container between several trees, to edit them synchronously even without exchange of changes with SUIT_ShortcutMgr. Pass nullptr to create non-synchronized tab widget.
References SUIT_ShortcutMgr::ROOT_MODULE_ID.
◆ ~SUIT_ShortcutTabWidget()
SUIT_ShortcutTabWidget::~SUIT_ShortcutTabWidget ( )
References instances, and myShortcutContainer.
◆ applyChangesToShortcutMgr()
void SUIT_ShortcutTabWidget::applyChangesToShortcutMgr ( )
References SUIT_ShortcutMgr::get(), instances, and myShortcutContainer.
◆ getConfirmedKeySequence()
std::pair< QString, bool > SUIT_ShortcutTabWidget::getConfirmedKeySequence ( const QString &  theModuleID,
const QString &  theInModuleActionID
Key sequence from the tree and true, if it differs from a keysequence in ShortcutMgr (applied key sequence).
References SUIT_ShortcutMgr::get(), SUIT_ShortcutMgr::getKeySequence(), myModuleTrees, and SUIT_ShortcutMgr::splitIntoTokens().
◆ jumpToTreeItem()
void SUIT_ShortcutTabWidget::jumpToTreeItem ( const QString &  theModuleID,
const QString &  theInModuleID
◆ onTreeItemDoubleClicked()
◆ operator=()
SUIT_ShortcutTabWidget & SUIT_ShortcutTabWidget::operator= ( const SUIT_ShortcutTree &  )
delete
◆ setDefaultShortcuts()
void SUIT_ShortcutTabWidget::setDefaultShortcuts ( )
References SUIT_ShortcutMgr::fillContainerFromPreferences(), myShortcutContainer, and updateTabs().
◆ setShortcutsFromManager()
void SUIT_ShortcutTabWidget::setShortcutsFromManager ( )
References SUIT_ShortcutMgr::get(), SUIT_ShortcutMgr::getShortcutContainer(), myShortcutContainer, and updateTabs().
◆ shortcutContainer()
std::shared_ptr< const SUIT_ShortcutContainer > SUIT_ShortcutTabWidget::shortcutContainer ( ) const
References myShortcutContainer.
◆ updateTabs()
void SUIT_ShortcutTabWidget::updateTabs ( bool  theHighlightModifiedTreeItems,
◆ SUIT_ShortcutTree
friend class SUIT_ShortcutTree
friend
◆ instances
std::map< SUIT_ShortcutContainer *, std::set< SUIT_ShortcutTabWidget * > > SUIT_ShortcutTabWidget::instances
staticprivate
Initial value:
std::map<SUIT_ShortcutContainer*, std::set<SUIT_ShortcutTabWidget*>>()
Sharing of SUIT_ShortcutContainer allows to keep trees in tabs synchronized even without applying changes to SUIT_ShortcutMgr. Why? See SUIT_PagePrefShortcutTreeItem.
Access is not synchronized in assumption, that all instances live in the same thread.
◆ myEditDialog
SUIT_EditKeySequenceDialog* SUIT_ShortcutTabWidget::myEditDialog
◆ myFindActionWidget
SUIT_FindActionWidget* SUIT_ShortcutTabWidget::myFindActionWidget
◆ myIsPopulated
bool SUIT_ShortcutTabWidget::myIsPopulated
◆ myModuleIDs
const std::set<QString> SUIT_ShortcutTabWidget::myModuleIDs
◆ myModuleTrees
std::map<QString, SUIT_ShortcutTree*> SUIT_ShortcutTabWidget::myModuleTrees
All tabs share the same SUIT_ShortcutContainer.
◆ myShortcutContainer
const std::shared_ptr<SUIT_ShortcutContainer> SUIT_ShortcutTabWidget::myShortcutContainer
Never nullpt.
