SalomeApp_Engine_i Class Reference
#include <SalomeApp_Engine_i.h>
Inheritance diagram for SalomeApp_Engine_i:
typedef std::vector< std::string > ListOfFiles
typedef std::map< int, ListOfFiles > MapOfFiles
 SalomeApp_Engine_i (const char *theComponentName)
 ~SalomeApp_Engine_i ()
SALOMEDS::TMPFile * Save (SALOMEDS::SComponent_ptr theComponent, const char *theURL, bool isMultiFile)
CORBA::Boolean Load (SALOMEDS::SComponent_ptr theComponent, const SALOMEDS::TMPFile &theFile, const char *theURL, bool isMultiFile)
ListOfFiles GetListOfFiles (int)
void SetListOfFiles (int, const ListOfFiles &theListOfFiles)
SALOMEDS::TMPFile * SaveASCII (SALOMEDS::SComponent_ptr, const char *, bool)
CORBA::Boolean LoadASCII (SALOMEDS::SComponent_ptr, const SALOMEDS::TMPFile &, const char *, bool)
void Close (SALOMEDS::SComponent_ptr)
char * ComponentDataType ()
char * IORToLocalPersistentID (SALOMEDS::SObject_ptr, const char *, CORBA::Boolean, CORBA::Boolean)
char * LocalPersistentIDToIOR (SALOMEDS::SObject_ptr, const char *, CORBA::Boolean, CORBA::Boolean)
bool CanPublishInStudy (CORBA::Object_ptr)
SALOMEDS::SObject_ptr PublishInStudy (SALOMEDS::SObject_ptr, CORBA::Object_ptr, const char *)
CORBA::Boolean CanCopy (SALOMEDS::SObject_ptr)
SALOMEDS::TMPFile * CopyFrom (SALOMEDS::SObject_ptr, CORBA::Long &)
CORBA::Boolean CanPaste (const char *, CORBA::Long)
SALOMEDS::SObject_ptr PasteInto (const SALOMEDS::TMPFile &, CORBA::Long, SALOMEDS::SObject_ptr)
bool keepFiles () const
void keepFiles (bool keep)
char * getVersion ()
static std::string EngineIORForComponent (const char *theComponentName, bool toCreate)
static SalomeApp_Engine_i * GetInstance (const char *theComponentName, bool toCreate)
static CORBA::Object_ptr EngineForComponent (const char *theComponentName, bool toCreate)
static CORBA::ORB_var orb ()
static PortableServer::POA_var poa ()
static SALOME_NamingService_Abstract * namingService ()
MapOfFiles myListOfFiles
bool myKeepFiles
QString myComponentName
◆ ListOfFiles
typedef std::vector<std::string> SalomeApp_Engine_i::ListOfFiles
◆ MapOfFiles
◆ SalomeApp_Engine_i()
SalomeApp_Engine_i::SalomeApp_Engine_i ( const char *  theComponentName)
Constructor
References myComponentName.
◆ ~SalomeApp_Engine_i()
SalomeApp_Engine_i::~SalomeApp_Engine_i ( )
Destructor
◆ CanCopy()
CORBA::Boolean SalomeApp_Engine_i::CanCopy ( SALOMEDS::SObject_ptr  )
◆ CanPaste()
CORBA::Boolean SalomeApp_Engine_i::CanPaste ( const char *  ,
CORBA::Long
◆ CanPublishInStudy()
bool SalomeApp_Engine_i::CanPublishInStudy ( CORBA::Object_ptr  )
◆ Close()
void SalomeApp_Engine_i::Close ( SALOMEDS::SComponent_ptr  )
◆ ComponentDataType()
char * SalomeApp_Engine_i::ComponentDataType ( )
Component data type string for this instance of the engine
◆ CopyFrom()
SALOMEDS::TMPFile * SalomeApp_Engine_i::CopyFrom ( SALOMEDS::SObject_ptr  ,
CORBA::Long &
◆ DumpPython()
Engines::TMPFile * SalomeApp_Engine_i::DumpPython ( CORBA::Boolean  isPublished,
DumpPython implementation for light modules
References GetListOfFiles(), and myComponentName.
◆ EngineForComponent()
CORBA::Object_ptr SalomeApp_Engine_i::EngineForComponent ( const char *  theComponentName,
bool  toCreate
Internal method, creates a CORBA engine for a light SALOME module with the given "component data type" string, activates it and registers in SALOME naming service with /SalomeAppEngine/comp_data_type path. If the engine is already in the naming service, simply returns and object reference to it.
theComponentName- synthetic "component data type" used to identify a given light module
Object reference to the CORBA engine
References CAM_Application::moduleTitle(), namingService(), poa(), and SalomeApp_Engine_i().
◆ EngineIORForComponent()
std::string SalomeApp_Engine_i::EngineIORForComponent ( const char *  theComponentName,
bool  toCreate
IOR string for the CORBA engine for a light SALOME module with the given "component data type" string
See also
GetInstance( const char* theComponentName )
References EngineForComponent(), and orb().
◆ GetInstance()
SalomeApp_Engine_i * SalomeApp_Engine_i::GetInstance ( const char *  theComponentName,
bool  toCreate
A pointer to corresponding C++ engine instance, null means some internal problems.
See also
EngineIORForComponent( const char* theComponentName )
References EngineForComponent(), and poa().
◆ GetListOfFiles()
SalomeApp_Engine_i::ListOfFiles SalomeApp_Engine_i::GetListOfFiles ( int  type)
References myListOfFiles.
◆ getVersion()
◆ IORToLocalPersistentID()
char * SalomeApp_Engine_i::IORToLocalPersistentID ( SALOMEDS::SObject_ptr  ,
const char *  ,
CORBA::Boolean  ,
CORBA::Boolean
◆ keepFiles() [1/2]
bool SalomeApp_Engine_i::keepFiles ( ) const
◆ keepFiles() [2/2]
void SalomeApp_Engine_i::keepFiles ( bool  keep)
◆ Load()
CORBA::Boolean SalomeApp_Engine_i::Load ( SALOMEDS::SComponent_ptr  theComponent,
const SALOMEDS::TMPFile &  theFile,
const char *  theURL,
bool  isMultiFile
< TODO: conversion from size_t to int
References keepFiles(), myComponentName, and SetListOfFiles().
◆ LoadASCII()
CORBA::Boolean SalomeApp_Engine_i::LoadASCII ( SALOMEDS::SComponent_ptr  ,
const SALOMEDS::TMPFile &  ,
const char *  ,
bool
◆ LocalPersistentIDToIOR()
char * SalomeApp_Engine_i::LocalPersistentIDToIOR ( SALOMEDS::SObject_ptr  ,
const char *  ,
CORBA::Boolean  ,
CORBA::Boolean
◆ namingService()
SALOME_NamingService_Abstract * SalomeApp_Engine_i::namingService ( )
staticprivate
◆ orb()
CORBA::ORB_var SalomeApp_Engine_i::orb ( )
staticprivate
◆ PasteInto()
SALOMEDS::SObject_ptr SalomeApp_Engine_i::PasteInto ( const SALOMEDS::TMPFile &  ,
CORBA::Long  ,
◆ poa()
PortableServer::POA_var SalomeApp_Engine_i::poa ( )
staticprivate
References orb().
◆ PublishInStudy()
SALOMEDS::SObject_ptr SalomeApp_Engine_i::PublishInStudy ( SALOMEDS::SObject_ptr  ,
CORBA::Object_ptr  ,
const char *
◆ Save()
SALOMEDS::TMPFile * SalomeApp_Engine_i::Save ( SALOMEDS::SComponent_ptr  theComponent,
bool  isMultiFile
◆ SaveASCII()
SALOMEDS::TMPFile * SalomeApp_Engine_i::SaveASCII ( SALOMEDS::SComponent_ptr  ,
const char *  ,
bool
◆ SetListOfFiles()
void SalomeApp_Engine_i::SetListOfFiles ( int  type,
const ListOfFiles &  theListOfFiles
◆ myComponentName
QString SalomeApp_Engine_i::myComponentName
◆ myKeepFiles
bool SalomeApp_Engine_i::myKeepFiles
◆ myListOfFiles
MapOfFiles SalomeApp_Engine_i::myListOfFiles
