VTKViewer_MarkerDlg Class Reference
Dialog for specifying of point marker parameters. More...
#include <VTKViewer_MarkerDlg.h>
Inheritance diagram for VTKViewer_MarkerDlg:
 VTKViewer_MarkerDlg (QWidget *=0)
virtual ~VTKViewer_MarkerDlg ()
void setHelpData (const QString &theModuleName, const QString &theHelpFileName)
 Associate documentation page with the dialog box. More...
void setCustomMarkers (const VTK::MarkerMap &)
 Set custom markers data. More...
VTK::MarkerMap customMarkers () const
 Get custom markers data. More...
void addMarker (VTK::MarkerType, const QPixmap &)
 Add standard marker The marker type specified with type must be > VTK::MT_USER. More...
void setMarker (VTK::MarkerType, VTK::MarkerScale)
 Select specified standard marker as current one. More...
void setCustomMarker (int)
 Select specified custom marker as current one. More...
VTK::MarkerType markerType () const
 Get current marker's type. For custom marker, VTK::MT_USER is returned and markerId() function then returns its identifier. More...
VTK::MarkerScale markerScale () const
 Get current marker's scale size. For custom marker return value is undefined. More...
int markerId () const
- Public Member Functions inherited from QtxDialog
 QtxDialog (QWidget *=0, bool=false, bool=false, const int=Standard, Qt::WindowFlags=0)
virtual ~QtxDialog ()
void setDialogFlags (const int)
 Set specified dialog box flags. More...
void clearDialogFlags (const int)
 Clear specified the dialog flags. More...
bool testDialogFlags (const int) const
 Test specified dialog flags. More...
void setButtonFlags (const int)
 Add specified control button(s) to the dialog box. More...
void clearButtonFlags (const int)
 Remove specified control button(s) from the dialog box. More...
bool testButtonFlags (const int) const
 Test specified buttons. More...
int buttonPosition (const int) const
 Get specified control button position. More...
void setButtonPosition (const int, const int=-1)
 Set the specified control button(s) position. More...
void setPlacePosition (const int, const int)
 Set button position for all buttons in specified area. More...
int placePolicy (const int) const
 Get buttons layouting policy for the specified area. More...
void setPlacePolicy (const int, const int)
 set buttons layouting policy for the specified area. More...
void setButtonPlace (const int, const int)
 Move specified button(s) into specified area. More...
QString buttonText (const int)
 Get specified button's text. More...
void setButtonText (const int, const QString &text)
 Set specified button's text. More...
void setButtonFocus (const int)
 Sets the keyboard focus to the specified button. More...
bool hasButtonFocus (const int) const
 Check if specified button has keyboard focus. More...
bool isButtonEnabled (const int) const
 Get "enabled" status of the specified button(s). More...
void setButtonEnabled (const bool, const int)
 Enable/disable specified button(s). More...
bool isBorderEnabled (const int) const
 Check if border is enabled. More...
void setBorderEnabled (const bool, const int)
 Show/hide border for the specified button area. More...
void removeButton (const int)
 Remove user button. More...
int insertButton (const QString &, const int=BottomArea)
 Add user button to the dialog box. More...
QIntList userButtonIds () const
 Get all user button IDs. More...
QAbstractButton * userButton (const int) const
 Get user button by the specified id. More...
uint setAlignment (uint align)
 Sets alignment policy. More...
 Process key press event. More...
- Protected Member Functions inherited from QtxDialog
QFrame * mainFrame () const
 Get dialog box main frame widget. More...
virtual bool acceptData () const
 Check if data entered by the user is valid. More...
virtual bool rejectData () const
 Check if dialog box can be cancelled. More...
virtual QAbstractButton * createButton (QWidget *)
 Create new user button. More...
QAbstractButton * button (const int) const
 Get button by the specified ID. More...
ButtonMap buttons (const int=All) const
 Get buttons by the specified IDs. More...
int buttonId (const QAbstractButton *) const
 Get specified button's identifier. More...
int buttonPosition (QAbstractButton *) const
 Get position of specified button. More...
virtual void showEvent (QShowEvent *)
 Align this dialog according to the parent widget and alignment policy before the dialog box is shown. More...
virtual void hideEvent (QHideEvent *)
 Process all existing events when dialog box is hidden. More...
virtual void closeEvent (QCloseEvent *)
 Called when user closes dialog box. More...
virtual void childEvent (QChildEvent *)
 Update dialog box layout when the size grip is added. More...
virtual void keyPressEvent (QKeyEvent *)
 Process key pressing event. More...
Private Slots
void onHelp ()
 Activate help for the dialog box. More...
VTKViewer_MarkerWidget * myMarkerWidget
QString myModule
QString myHelpFile
- Public Types inherited from QtxDialog
enum  PlacePolicy { Position , Expand , Uniform }
 Buttons alignment type. More...
enum  ButtonArea { TopArea , BottomArea , LeftArea , RightArea }
 Buttons area. More...
enum  ButtonPosition {
  Left , Right , Center , Top = Left ,
  Bottom = Right
 Button position. More...
enum  ButtonFlags {
  None = 0x00000000 , OK = 0x00000001 , Apply = 0x00000002 , Cancel = 0x00000004 ,
  Yes = 0x00000008 , No = 0x00000010 , Close = 0x00000020 , Help = 0x00000040 ,
  OKCancel = OK | Cancel , YesNo = Yes | No , Standard = OK | Cancel | Help , All = Standard | YesNo | Apply | Close
 Button ID flags. More...
enum  DialogFlags { Accept = 0x000001 , Reject = 0x000002 , AlignOnce = 0x000004 , SetFocus = 0x000008 }
 Dialog box flags. More...
- Public Slots inherited from QtxDialog
void update ()
 Update dialog box. More...
virtual void setVisible (bool)
 Show/hide dialog box, set keyboard focus to the dialog. More...
- Signals inherited from QtxDialog
void dlgButton (int)
 Emitted when the user button is clicked. More...
void dlgParamChanged ()
 This signal can be used in successor classes to signalize about some dialog parameter changing. More...
void dlgHelp ()
 Emitted when the "Help" button is clicked. More...
void dlgApply ()
 Emitted when the "Apply" button is clicked. More...
void dlgOk ()
 Emitted when the "OK" button is clicked. More...
void dlgNo ()
 Emitted when the "No" button is clicked. More...
void dlgYes ()
 Emitted when the "Yes" button is clicked. More...
void dlgClose ()
 Emitted when the "Close" button is clicked. More...
void dlgCancel ()
 Emitted when the "Cancel" button is clicked. More...
- Static Public Member Functions inherited from QtxDialog
static void setUnits (QLabel *, const QString &)
 Set measure units to the specified label. More...
- Protected Types inherited from QtxDialog
typedef QMap< int, QAbstractButton * > ButtonMap
 button map More...
- Protected Slots inherited from QtxDialog
virtual void accept ()
 Accept the dialog box. More...
virtual void reject ()
 Reject the dialog box. More...
◆ VTKViewer_MarkerDlg()
VTKViewer_MarkerDlg::VTKViewer_MarkerDlg ( QWidget *  parent = 0)
parentparent widget
References QtxDialog::dlgHelp(), QtxDialog::mainFrame(), myMarkerWidget, and onHelp().
◆ ~VTKViewer_MarkerDlg()
VTKViewer_MarkerDlg::~VTKViewer_MarkerDlg ( )
◆ addMarker()
void VTKViewer_MarkerDlg::addMarker ( VTK::MarkerType  type,
const QPixmap &  icon
typemarker type
iconmarker icon
References VTKViewer_MarkerWidget::addMarker(), and myMarkerWidget.
◆ customMarkers()
VTK::MarkerMap VTKViewer_MarkerDlg::customMarkers ( ) const
custom marker data
References VTKViewer_MarkerWidget::customMarkers(), and myMarkerWidget.
◆ keyPressEvent()
void VTKViewer_MarkerDlg::keyPressEvent ( QKeyEvent *  e)
ekey press event
Reimplemented from QtxDialog.
References QtxDialog::keyPressEvent(), and onHelp().
◆ markerId()
int VTKViewer_MarkerDlg::markerId ( ) const
\bried Get currently selected custom marker's identifier. For standard markers return value is VTK::MT_NONE.
References VTKViewer_MarkerWidget::markerId(), and myMarkerWidget.
◆ markerScale()
VTK::MarkerScale VTKViewer_MarkerDlg::markerScale ( ) const
currently selected marker scale size
References VTKViewer_MarkerWidget::markerScale(), and myMarkerWidget.
◆ markerType()
VTK::MarkerType VTKViewer_MarkerDlg::markerType ( ) const
currently selected marker type
References VTKViewer_MarkerWidget::markerType(), and myMarkerWidget.
◆ onHelp
void VTKViewer_MarkerDlg::onHelp ( )
privateslot
◆ setCustomMarker()
void VTKViewer_MarkerDlg::setCustomMarker ( int  id)
idcustom marker identifier
References myMarkerWidget, and VTKViewer_MarkerWidget::setCustomMarker().
◆ setCustomMarkers()
void VTKViewer_MarkerDlg::setCustomMarkers ( const VTK::MarkerMap &  markerMap)
markerMapcustom marker data (a map {index:texture})
References myMarkerWidget, and VTKViewer_MarkerWidget::setCustomMarkers().
◆ setHelpData()
void VTKViewer_MarkerDlg::setHelpData ( const QString &  module,
const QString &  helpFile
modulemodule name
helpFilereference help file
References myHelpFile, and myModule.
◆ setMarker()
void VTKViewer_MarkerDlg::setMarker ( VTK::MarkerType  type,
VTK::MarkerScale  scale
typemarker type
scalemarker scale (optional parameter; can be omitted for extended markers)
References myMarkerWidget, and VTKViewer_MarkerWidget::setMarker().
◆ myHelpFile
QString VTKViewer_MarkerDlg::myHelpFile
◆ myMarkerWidget
VTKViewer_MarkerWidget* VTKViewer_MarkerDlg::myMarkerWidget
◆ myModule
QString VTKViewer_MarkerDlg::myModule
