GenericUsesPort.hxx
23// File : GenericUsesPort.hxx
25// Module : KERNEL
26// Modified by : $LastChangedBy$
27// Date : $LastChangedDate: 2007-02-28 15:26:32 +0100 (mer, 28 fév 2007) $
28// Id : $Id$
29//
30#ifndef _GENERIC_USES_PORT_HXX_
31#define _GENERIC_USES_PORT_HXX_
32
34
35#include "uses_port.hxx"
36#include "SALOME_Ports.hh"
37
38#include "DSC_Exception.hxx"
39
40/* #define GENERATE_USES_PORT(dataManip,portType,portName) \
41 const char * _repository_##portType##_name_ = "IDL:Ports/##portType##:1.0"; \
42 GenericUsesPort< dataManip, portType, _repository_##portType##_name_ > portName;
43
44ex : GENERATE_USES_PORT(Ports::Data_Short_Port,data_short_port);*/
45
46template <typename DataManipulator, typename CorbaPortType, char * repositoryName,
47 typename UsesPort=uses_port >
48class GenericUsesPort : public UsesPort
49{
50public :
51 // Type de données manipulés
52 typedef typename DataManipulator::Type DataType;
53 typedef typename DataManipulator::CorbaInType CorbaInDataType;
54
57
58 virtual const char * get_repository_id();
59 template <typename TimeType,typename TagType>
60 void put(CorbaInDataType data, TimeType time, TagType tag);
61
62 virtual void uses_port_changed(Engines::DSC::uses_port * new_uses_port,
63 const Engines::DSC::Message message);
64
65protected :
67};
68
69
70template <typename DataManipulator,typename CorbaPortType, char * repositoryName, typename UsesPort >
72 _my_ports = NULL;
73}
74
75template <typename DataManipulator,typename CorbaPortType, char * repositoryName, typename UsesPort >
77{
78 delete _my_ports;
79}
80
81template <typename DataManipulator,typename CorbaPortType, char * repositoryName, typename UsesPort >
82const char *
84 return repositoryName;
85}
86
87
88template <typename DataManipulator,typename CorbaPortType, char * repositoryName, typename UsesPort >
89template <typename TimeType,typename TagType>
90void
92 TimeType time,
93 TagType tag) {
94 typedef typename CorbaPortType::_var_type CorbaPortTypeVar;
95 if (!_my_ports)
96 throw DSC_Exception(LOC("There is no connected provides port to communicate with."));
97
98 // OLD : PB1 : Cf remarque dans CalciumInterface, si on n'effectue pas de copie
99 // OLD : du buffer !
100 // OLD : PB2 : Si les ports provides auquels on envoie data sont collocalisés
101 // OLD : ils vont partagés le même buffer (à cause de notre optim ds get_data)
102 // OLD : il faut alors effectuer une copie ici.
103 // OLD : Pour l'instant on résoud PB2 en créant une copie de la donnée en cas
104 // OLD : de connexions multiples. Il faudra tester la collocalisation.
105 // OLD : DataType copyOfData; // = data; PB1
106 for(int i = 0; i < (int)_my_ports->length(); i++) { //TODO: mismatch signed/unsigned
107
108 CorbaPortTypeVar port = CorbaPortType::_narrow((*_my_ports)[i]);
109 //if (i) { PB1
110 //OLD : copyOfData = DataManipulator::clone(data);
111 if (SALOME::VerbosityActivated())
112 std::cerr << "-------- GenericUsesPort::put -------- " << std::endl;
113 //} PB1
114 try {
115 port->put(data,time,tag);
116 // OLD : port->put(*copyOfData,time,tag);
117 } catch(const CORBA::SystemException& ex) {
118 //OLD : DataManipulator::delete_data(copyOfData);
119 throw DSC_Exception(LOC(OSS() << "Can't invoke put method on port number "
120 << i << "( i>= 0)"));
121
122 }
123 //if (i) PB1
124 // La séquence est détruite avec le buffer si on n'est pas collocalisé
125 // La séquence est détruite sans son buffer sinon (cf comportement de get_data
126 // appelée dans put (port provides)
127 //OLD : DataManipulator::delete_data(copyOfData);
128 }
129}
130
131
132template <typename DataManipulator, typename CorbaPortType, char * repositoryName, typename UsesPort>
133void
134GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort
135 >::uses_port_changed(Engines::DSC::uses_port * new_uses_port,
136 const Engines::DSC::Message /*message*/)
137{
138 if (_my_ports) delete _my_ports;
139
140 if (SALOME::VerbosityActivated())
141 std::cerr << "GenericUsesPort::uses_port_changed" << std::endl;
142
143 _my_ports = new_uses_port;
144}
145
146#endif
#define LOC(message)
Definition: DSC_Exception.hxx:55
Definition: GenericUsesPort.hxx:49
virtual ~GenericUsesPort()
Definition: GenericUsesPort.hxx:76
GenericUsesPort()
Definition: GenericUsesPort.hxx:71
Definition: GenericUsesPort.hxx:91
This is used by the component to get the CORBA repository id of the uses port.
Definition: GenericUsesPort.hxx:83
Definition: GenericUsesPort.hxx:53
virtual void uses_port_changed(Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)
This method is the uses port's callback to be aware of connections states.
Definition: GenericUsesPort.hxx:135
Engines::DSC::uses_port * _my_ports
Definition: GenericUsesPort.hxx:66
Definition: GenericUsesPort.hxx:52
Class OSS is useful when streaming data through a function that expect a string as parameter.
Definition: DSC_Exception.hxx:65
This class implements a DSC_User uses C++ port.
Definition: uses_port.hxx:44
Message
This enumeration is used when the connection of a port (uses or provides) is changed.
Definition: DSC_Engines.idl:79
sequence< Ports::Port > uses_port
a uses port
Definition: DSC_Engines.idl:73
port
Definition: salome_instance.py:114
Definition: DSC_Exception.hxx:94
double TagType
Definition: testAdjacentPredicate.cxx:53
int TimeType
Definition: testAdjacentPredicate.cxx:52
