GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort > Class Template Reference
#include <GenericUsesPort.hxx>
Inheritance diagram for GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >:
typedef DataManipulator::Type DataType
typedef DataManipulator::CorbaInType CorbaInDataType
 GenericUsesPort ()
virtual ~GenericUsesPort ()
virtual const char * get_repository_id ()
 This is used by the component to get the CORBA repository id of the uses port. More...
template<typename TimeType , typename TagType >
void put (CorbaInDataType data, TimeType time, TagType tag)
virtual void uses_port_changed (Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message message)
 This method is the uses port's callback to be aware of connections states. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
Engines::DSC::uses_port * _my_ports
PortProperties_i * default_properties
◆ CorbaInDataType
template<typename DataManipulator , typename CorbaPortType , char * repositoryName, typename UsesPort = uses_port>
typedef DataManipulator::CorbaInType GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::CorbaInDataType
◆ DataType
typedef DataManipulator::Type GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::DataType
◆ GenericUsesPort()
template<typename DataManipulator , typename CorbaPortType , char * repositoryName, typename UsesPort >
GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::GenericUsesPort
◆ ~GenericUsesPort()
GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::~GenericUsesPort
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_repository_id()
const char * GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::get_repository_id ( )
It's an abstract method.
port's CORBA repository id.
Implements uses_port.
◆ put()
void GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::put ( CorbaInDataType  data,
TimeType  time,
TagType  tag
References LOC, and salome_instance::port.
◆ uses_port_changed()
void GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::uses_port_changed ( Engines::DSC::uses_port *  new_uses_port,
It's an abstract method. The uses port uses this method to manage the sequence of the DSC_Basic uses port.
new_uses_portnew uses port sequence.
messagemessage associated with this modification.
◆ _my_ports
Engines::DSC::uses_port* GenericUsesPort< DataManipulator, CorbaPortType, repositoryName, UsesPort >::_my_ports
◆ default_properties
PortProperties_i* base_port::default_properties
