compo_utils.py File Reference
namespace  KERNEL_PY
namespace  KERNEL_PY.kernel
namespace  KERNEL_PY.kernel.parametric
namespace  KERNEL_PY.kernel.parametric.compo_utils
def KERNEL_PY.kernel.parametric.compo_utils.create_input_dict (deterministic_dict, parametric_input)
 This function returns a dictionary containing the input values to be used in the computation code. More...
def KERNEL_PY.kernel.parametric.compo_utils.create_normal_parametric_output (output_dict, parametric_input)
 This function returns a structure describing the output of the computation code in parametric studies. More...
def KERNEL_PY.kernel.parametric.compo_utils.create_error_parametric_output (error_message)
 This function returns a structure describing the output of the computation code in parametric studies in case of error. More...
