LifeCycleCORBA.ResourceDefinition Class Reference
Inheritance diagram for LifeCycleCORBA.ResourceDefinition:
def __init__ (self, name="", hostname="", protocol="rsh", username="", applipath="", componentList=None, mode="interactive", OS="", mem_mb=1, cpu_clock=1, nb_node=1, nb_proc_per_node=1, batch="", mpiImpl="", iprotocol="rsh", type="single_machine", can_launch_batch_jobs=False, can_run_containers=False, working_directory="")
Data Fields
string name
 name More...
string hostname
 hostname More...
string type
 Type of the resource ("cluster" or "single_machine") More...
string protocol
 protocol to connect to the resource and to start a remote container Possible values: "rsh" : uses rsh and rcp "ssh" : uses ssh and scp "rsync" : uses ssh and rsync More...
string username
 login name to use to start a remote container More...
string applipath
 salome application to use to start a remote container More...
CompoList componentList
 list of available components. More...
string OS
 operating system More...
long mem_mb
 memory size per node More...
long cpu_clock
 frequency More...
long nb_node
 number of node More...
long nb_proc_per_node
 number of proc per node More...
string batch
 batch system More...
string mpiImpl
 MPI implementation. More...
string iprotocol
 if the resource is a cluster: internal protocol to use to start a remote container (ssh or rsh) on the cluster More...
boolean can_launch_batch_jobs
 Specify if the resource can launch batch jobs. More...
boolean can_run_containers
 Specify if the resource can run containers. More...
string working_directory
 Predefined working directory on the resource. More...
◆ __init__()
def LifeCycleCORBA.ResourceDefinition.__init__ (   self,
  name = "",
  hostname = "",
  protocol = "rsh",
  username = "",
  applipath = "",
  componentList = None,
  mode = "interactive",
  OS = "",
  mem_mb = 1,
  cpu_clock = 1,
  nb_node = 1,
  nb_proc_per_node = 1,
  batch = "",
  mpiImpl = "",
  iprotocol = "rsh",
  type = "single_machine",
  can_launch_batch_jobs = False,
  can_run_containers = False,
  working_directory = ""
◆ applipath
string Engines::ResourceDefinition::applipath
Referenced by resourceDefinition_CORBAtoCPP(), BatchTest::test(), and BatchTest::test_appli().
◆ batch
string Engines::ResourceDefinition::batch
◆ can_launch_batch_jobs
boolean Engines::ResourceDefinition::can_launch_batch_jobs
Referenced by resourceDefinition_CORBAtoCPP().
◆ can_run_containers
boolean Engines::ResourceDefinition::can_run_containers
◆ componentList
CompoList Engines::ResourceDefinition::componentList
An empty list means every component is available.
◆ cpu_clock
long Engines::ResourceDefinition::cpu_clock
frequency
◆ hostname
◆ iprotocol
string Engines::ResourceDefinition::iprotocol
◆ mem_mb
long Engines::ResourceDefinition::mem_mb
◆ mpiImpl
string Engines::ResourceDefinition::mpiImpl
◆ name
◆ nb_node
long Engines::ResourceDefinition::nb_node
number of node
Referenced by main(), and resourceDefinition_CORBAtoCPP().
◆ nb_proc_per_node
long Engines::ResourceDefinition::nb_proc_per_node
◆ OS
string Engines::ResourceDefinition::OS
operating system
◆ protocol
string Engines::ResourceDefinition::protocol
◆ type
string Engines::ResourceDefinition::type
◆ username
◆ working_directory
string Engines::ResourceDefinition::working_directory
