SALOME_CorbaDoubleCSender_i Class Reference
Servant class for CORBA sender for double* when copy of array _tabToSend is required, that is to say double and CORBA::Double are NOT binary equal. More...
#include <SALOME_Comm_i.hxx>
Inheritance diagram for SALOME_CorbaDoubleCSender_i:
 SALOME_CorbaDoubleCSender_i (const double *tabToSend, long lgrTabToSend, bool ownTabToSend=false)
 ~SALOME_CorbaDoubleCSender_i ()
CORBA::ULong getSize ()
SALOME::vectorOfDouble * sendPart (CORBA::ULong offset, CORBA::ULong length)
SALOME::TypeOfDataTransmitted getTypeOfDataTransmitted ()
SALOME::SenderDouble_ptr buildOtherWithProtocol (SALOME::TypeOfCommunication type)
 Return a new sender of the same array but with an another protocol and delegates to the returned sender the ownership of array. More...
const void * getData (long &size) const
 Return the C++ data associated to the array to transmit. More...
int getSizeOf () const
 Return the sizeof() of each component of the generic array. More...
void setOwnerShip (bool own)
 To force ownerShip status. More...
bool getOwnerShip () const
void release ()
 Method for the remote destroy of the current servant. More...
static SALOME_SenderDouble_i * find (SALOME::SenderDouble_ptr pCorba)
 Method to establish if the CORBA object referred by pCorba is colocalized. More...
const void * _tabToSend
 Pointer to the generic array to transmit. More...
long _lgrTabToSend
 Length of the generic array to transmit. More...
int _sizeOf
 it represents the sizeof() of each component of the generic array:
Practically in terms of bytes the size to be transmitted is _lgrTabToSend*_sizeOf More...
bool _ownTabToSend
 Indicates if _tabToSend has to be deallocated. More...
◆ SALOME_CorbaDoubleCSender_i()
SALOME_CorbaDoubleCSender_i::SALOME_CorbaDoubleCSender_i ( const double *  tabToSend,
long  lgrTabToSend,
bool  ownTabToSend = false
◆ ~SALOME_CorbaDoubleCSender_i()
SALOME_CorbaDoubleCSender_i::~SALOME_CorbaDoubleCSender_i ( )
◆ buildOtherWithProtocol()
SALOME::SenderDouble_ptr SALOME_SenderDouble_i::buildOtherWithProtocol ( SALOME::TypeOfCommunication  type)
References SenderFactory::buildSender().
◆ find()
SALOME_SenderDouble_i * SALOME_SenderDouble_i::find ( SALOME::SenderDouble_ptr  pCorba)
If it is, the pointer to the servant that incarnates the CORBA object is returned.
References TestKernelHelpers::ret.
◆ getData()
const void * SALOME_Sender_i::getData ( long &  size) const
Used when sender and receiver are colocalized.
References SALOME_Sender_i::_lgrTabToSend, and SALOME_Sender_i::_tabToSend.
Referenced by SenderFactory::buildSender().
◆ getOwnerShip()
bool SALOME_Sender_i::getOwnerShip ( ) const
◆ getSize()
CORBA::ULong SALOME_CorbaDoubleCSender_i::getSize ( )
◆ getSizeOf()
int SALOME_Sender_i::getSizeOf ( ) const
References SALOME_Sender_i::_sizeOf.
◆ getTypeOfDataTransmitted()
SALOME::TypeOfDataTransmitted SALOME_SenderDouble_i::getTypeOfDataTransmitted ( )
◆ release()
void SALOME_Sender_i::release ( )
This method is used by the receiver to destroy the sender when the transfert is complete.
◆ sendPart()
SALOME::vectorOfDouble * SALOME_CorbaDoubleCSender_i::sendPart ( CORBA::ULong  offset,
CORBA::ULong  length
◆ setOwnerShip()
void SALOME_Sender_i::setOwnerShip ( bool  own)
References SALOME_Sender_i::_ownTabToSend.
◆ _lgrTabToSend
◆ _ownTabToSend
bool SALOME_Sender_i::_ownTabToSend
◆ _sizeOf
int SALOME_Sender_i::_sizeOf
Referenced by SALOME_Sender_i::getSizeOf().
◆ _tabToSend
