SALOME_CorbaLongNCSender_i Class Reference
Servant class for CORBA sender for int* when no copy of array _tabToSend is required, that is to say int and CORBA::Long are binary equal. More...
#include <SALOME_Comm_i.hxx>
Inheritance diagram for SALOME_CorbaLongNCSender_i:
 SALOME_CorbaLongNCSender_i (const int *tabToSend, long lgrTabToSend, bool ownTabToSend=false)
 ~SALOME_CorbaLongNCSender_i ()
CORBA::ULong getSize ()
SALOME::vectorOfLong * sendPart (CORBA::ULong offset, CORBA::ULong length)
SALOME::vectorOfLong * send ()
SALOME::TypeOfDataTransmitted getTypeOfDataTransmitted ()
SALOME::SenderInt_ptr buildOtherWithProtocol (SALOME::TypeOfCommunication type)
 Return a new sender of the same array but with an another protocol. More...
const void * getData (long &size) const
 Return the C++ data associated to the array to transmit. More...
int getSizeOf () const
 Return the sizeof() of each component of the generic array. More...
void setOwnerShip (bool own)
 To force ownerShip status. More...
bool getOwnerShip () const
void release ()
 Method for the remote destroy of the current servant. More...
static SALOME_SenderInt_i * find (SALOME::SenderInt_ptr pCorba)
 Method to establish if the CORBA object referred by pCorba is colocalized. More...
const void * _tabToSend
 Pointer to the generic array to transmit. More...
long _lgrTabToSend
 Length of the generic array to transmit. More...
int _sizeOf
 it represents the sizeof() of each component of the generic array:
Practically in terms of bytes the size to be transmitted is _lgrTabToSend*_sizeOf More...
bool _ownTabToSend
 Indicates if _tabToSend has to be deallocated. More...
◆ SALOME_CorbaLongNCSender_i()
SALOME_CorbaLongNCSender_i::SALOME_CorbaLongNCSender_i ( const int *  tabToSend,
long  lgrTabToSend,
bool  ownTabToSend = false
◆ ~SALOME_CorbaLongNCSender_i()
SALOME_CorbaLongNCSender_i::~SALOME_CorbaLongNCSender_i ( )
◆ buildOtherWithProtocol()
SALOME::SenderInt_ptr SALOME_SenderInt_i::buildOtherWithProtocol ( SALOME::TypeOfCommunication  type)
References SenderFactory::buildSender().
◆ find()
SALOME_SenderInt_i * SALOME_SenderInt_i::find ( SALOME::SenderInt_ptr  pCorba)
If it is, the pointer to the servant that incarnates the CORBA object is returned.
References TestKernelHelpers::ret.
◆ getData()
const void * SALOME_Sender_i::getData ( long &  size) const
Used when sender and receiver are colocalized.
References SALOME_Sender_i::_lgrTabToSend, and SALOME_Sender_i::_tabToSend.
Referenced by SenderFactory::buildSender().
◆ getOwnerShip()
bool SALOME_Sender_i::getOwnerShip ( ) const
◆ getSize()
CORBA::ULong SALOME_CorbaLongNCSender_i::getSize ( )
◆ getSizeOf()
int SALOME_Sender_i::getSizeOf ( ) const
References SALOME_Sender_i::_sizeOf.
◆ getTypeOfDataTransmitted()
SALOME::TypeOfDataTransmitted SALOME_SenderInt_i::getTypeOfDataTransmitted ( )
◆ release()
void SALOME_Sender_i::release ( )
This method is used by the receiver to destroy the sender when the transfert is complete.
◆ send()
SALOME::vectorOfLong * SALOME_CorbaLongNCSender_i::send ( )
◆ sendPart()
SALOME::vectorOfLong * SALOME_CorbaLongNCSender_i::sendPart ( CORBA::ULong  offset,
CORBA::ULong  length
◆ setOwnerShip()
void SALOME_Sender_i::setOwnerShip ( bool  own)
References SALOME_Sender_i::_ownTabToSend.
◆ _lgrTabToSend
long SALOME_Sender_i::_lgrTabToSend
◆ _ownTabToSend
bool SALOME_Sender_i::_ownTabToSend
◆ _sizeOf
int SALOME_Sender_i::_sizeOf
Referenced by SALOME_Sender_i::getSizeOf().
◆ _tabToSend
