SALOME_Sender_i Class Reference
Generic servant class for senders that factorizes all the common methods and attributes necessary to senders. More...
#include <SALOME_Comm_i.hxx>
Inheritance diagram for SALOME_Sender_i:
const void * getData (long &size) const
 Return the C++ data associated to the array to transmit. More...
int getSizeOf () const
 Return the sizeof() of each component of the generic array. More...
void setOwnerShip (bool own)
 To force ownerShip status. More...
bool getOwnerShip () const
void release ()
 Method for the remote destroy of the current servant. More...
virtual ~SALOME_Sender_i ()
 SALOME_Sender_i (const void *tabToSend, long lgrTabToSend, int sizeOf, bool ownTabToSend=false)
 Unique constructor. More...
const void * _tabToSend
 Pointer to the generic array to transmit. More...
long _lgrTabToSend
 Length of the generic array to transmit. More...
int _sizeOf
 it represents the sizeof() of each component of the generic array:
Practically in terms of bytes the size to be transmitted is _lgrTabToSend*_sizeOf More...
bool _ownTabToSend
 Indicates if _tabToSend has to be deallocated. More...
All servant classes for senders have to inheritate from it.
◆ SALOME_Sender_i()
SALOME_Sender_i::SALOME_Sender_i ( const void *  tabToSend,
long  lgrTabToSend,
int  sizeOf,
bool  ownTabToSend = false
Unique constructor.
◆ ~SALOME_Sender_i()
virtual SALOME_Sender_i::~SALOME_Sender_i ( )
◆ getData()
const void * SALOME_Sender_i::getData ( long &  size) const
Used when sender and receiver are colocalized.
References _lgrTabToSend, and _tabToSend.
Referenced by SenderFactory::buildSender().
◆ getOwnerShip()
bool SALOME_Sender_i::getOwnerShip ( ) const
◆ getSizeOf()
int SALOME_Sender_i::getSizeOf ( ) const
References _sizeOf.
◆ release()
void SALOME_Sender_i::release ( )
This method is used by the receiver to destroy the sender when the transfert is complete.
◆ setOwnerShip()
void SALOME_Sender_i::setOwnerShip ( bool  own)
References _ownTabToSend.
◆ _lgrTabToSend
◆ _ownTabToSend
bool SALOME_Sender_i::_ownTabToSend
Referenced by setOwnerShip(), SALOME_SenderDouble_i::~SALOME_SenderDouble_i(), and SALOME_SenderInt_i::~SALOME_SenderInt_i().
◆ _sizeOf
int SALOME_Sender_i::_sizeOf
Referenced by getSizeOf().
◆ _tabToSend
