SalomeSDSClt.Caller Class Reference
def __init__ (self, varPtr, meth)
def __call__ (self, *args)
Static Public Attributes
dictionary PyHandlerTypeMap = {int:Int,float:Float,str:String,list:List,tuple:Tuple,dict:Dict}
 _var_ptr
 _meth
◆ __init__()
def SalomeSDSClt.Caller.__init__ (   self,
  varPtr,
  meth
◆ __call__()
◆ _meth
SalomeSDSClt.Caller._meth
◆ _var_ptr
SalomeSDSClt.Caller._var_ptr
Referenced by SALOMEGlobalVarHelper.Caller.__call__(), SalomeSDSClt.Caller.__call__(), SALOMEGlobalVarHelper.List.__del__(), SALOMEGlobalVarHelper.Tuple.__del__(), SALOMEGlobalVarHelper.Int.__del__(), SALOMEGlobalVarHelper.Dict.__del__(), SalomeSDSClt.WrappedType.__del__(), SalomeSDSClt.List.__delitem__(), SalomeSDSClt.Dict.__delitem__(), SALOMEGlobalVarHelper.List.__getitem__(), SALOMEGlobalVarHelper.Tuple.__getitem__(), SALOMEGlobalVarHelper.Dict.__getitem__(), SalomeSDSClt.List.__getitem__(), SalomeSDSClt.Dict.__getitem__(), SalomeSDSClt.Tuple.__getitem__(), SALOMEGlobalVarHelper.Int.__iadd__(), SALOMEGlobalVarHelper.Int.__isub__(), SALOMEGlobalVarHelper.List.__setitem__(), SALOMEGlobalVarHelper.Tuple.__setitem__(), SALOMEGlobalVarHelper.Dict.__setitem__(), SalomeSDSClt.List.__setitem__(), SalomeSDSClt.Dict.__setitem__(), SALOMEGlobalVarHelper.List.append(), SalomeSDSClt.List.append(), SALOMEGlobalVarHelper.List.assign(), SALOMEGlobalVarHelper.Tuple.assign(), SALOMEGlobalVarHelper.Int.assign(), SALOMEGlobalVarHelper.Dict.assign(), SalomeSDSClt.WrappedType.assign(), SalomeSDSClt.Dict.clear(), SalomeSDSClt.List.extend(), SalomeSDSClt.Dict.get(), SalomeSDSClt.List.insert(), SalomeSDSClt.InvokatorPossibleStyle.invokePythonMethodOn(), SalomeSDSClt.Dict.items(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SalomeSDSClt.List.pop(), SalomeSDSClt.Dict.pop(), SalomeSDSClt.Dict.popitem(), SalomeSDSClt.InvokatorStyle.ptr(), SalomeSDSClt.WrappedType.ptr(), SalomeSDSClt.List.remove(), SalomeSDSClt.List.reverse(), SalomeSDSClt.Dict.setdefault(), SalomeSDSClt.List.sort(), SalomeSDSClt.Dict.update(), and SalomeSDSClt.Dict.values().
◆ PyHandlerTypeMap
dictionary SalomeSDSClt.Caller.PyHandlerTypeMap = {int:Int,float:Float,str:String,list:List,tuple:Tuple,dict:Dict}
