| def | __init__ (self, varPtr, isTemporaryVar=False) |
| def | __getitem__ (self, *args) |
| def | count (self, *args) |
| def | index (self, *args) |
| def | __len__ (self) |
Private Attributes | |
| _wrapped_type | |
| def SalomeSDSClt.Tuple.__init__ | ( | self, | |
| varPtr, | |||
isTemporaryVar = False |
Reimplemented from SalomeSDSClt.WrappedType.
| def SalomeSDSClt.Tuple.__getitem__ | ( | self, | |
| * | args | ||
Reimplemented from SALOMEWrappedStdType.Tuple.
References SALOMEGlobalVarHelper.List._var_ptr, SALOMEGlobalVarHelper.Tuple._var_ptr, SALOMEGlobalVarHelper.Int._var_ptr, SALOMEGlobalVarHelper.Dict._var_ptr, SALOMEGlobalVarHelper.Caller._var_ptr, SalomeSDSClt.InvokatorStyle._var_ptr, SalomeSDSClt.WrappedType._var_ptr, SalomeSDSClt.Caller._var_ptr, and TestKernelHelpers.ret.
| def SalomeSDSClt.Tuple.__len__ | ( | self | ) |
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
| def SalomeSDSClt.Tuple.count | ( | self, | |
| * | args | ||
References SalomeSDSClt.Tuple.count(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.Tuple.count().
| def SalomeSDSClt.Tuple.index | ( | self, | |
| * | args | ||
References SalomeSDSClt.Tuple.index(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.Tuple.index().
private |
Referenced by SalomeSDSClt.WrappedType.__reduce__().
