| def | __init__ (self, varPtr, isTemporaryVar=False) |
| def | __del__ (self) |
| def | assign (self, elt) |
| def | __getitem__ (self, *args) |
| def | __setitem__ (self, *args) |
| def | __len__ (self) |
| def | __str__ (self) |
| def | __repr__ (self) |
| def | local_copy (self) |
| def | __reduce__ (self) |
Private Attributes | |
| _var_ptr | |
| _is_temp | |
| def SALOMEGlobalVarHelper.Dict.__init__ | ( | self, | |
| varPtr, | |||
isTemporaryVar = False |
| def SALOMEGlobalVarHelper.Dict.__del__ | ( | self | ) |
References SALOMEGlobalVarHelper.List._var_ptr, SALOMEGlobalVarHelper.Tuple._var_ptr, SALOMEGlobalVarHelper.Int._var_ptr, SALOMEGlobalVarHelper.Dict._var_ptr, SALOMEGlobalVarHelper.Caller._var_ptr, SalomeSDSClt.InvokatorStyle._var_ptr, SalomeSDSClt.WrappedType._var_ptr, SalomeSDSClt.Caller._var_ptr, and SALOME.UnRegister().
| def SALOMEGlobalVarHelper.Dict.__getitem__ | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List._var_ptr, SALOMEGlobalVarHelper.Tuple._var_ptr, SALOMEGlobalVarHelper.Int._var_ptr, SALOMEGlobalVarHelper.Dict._var_ptr, SALOMEGlobalVarHelper.Caller._var_ptr, SalomeSDSClt.InvokatorStyle._var_ptr, SalomeSDSClt.WrappedType._var_ptr, SalomeSDSClt.Caller._var_ptr, and TestKernelHelpers.ret.
| def SALOMEGlobalVarHelper.Dict.__len__ | ( | self | ) |
| def SALOMEGlobalVarHelper.Dict.__reduce__ | ( | self | ) |
| def SALOMEGlobalVarHelper.Dict.__repr__ | ( | self | ) |
References SALOMEGlobalVarHelper.Dict.__repr__(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SALOMEGlobalVarHelper.Dict.__repr__().
| def SALOMEGlobalVarHelper.Dict.__setitem__ | ( | self, | |
| * | args | ||
| def SALOMEGlobalVarHelper.Dict.__str__ | ( | self | ) |
References SALOMEGlobalVarHelper.Dict.__str__(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SALOMEGlobalVarHelper.Dict.__str__().
| def SALOMEGlobalVarHelper.Dict.assign | ( | self, | |
| elt | |||
References SALOMEGlobalVarHelper.List._var_ptr, SALOMEGlobalVarHelper.Tuple._var_ptr, SALOMEGlobalVarHelper.Int._var_ptr, SALOMEGlobalVarHelper.Dict._var_ptr, SALOMEGlobalVarHelper.Caller._var_ptr, SalomeSDSClt.InvokatorStyle._var_ptr, SalomeSDSClt.WrappedType._var_ptr, and SalomeSDSClt.Caller._var_ptr.
| def SALOMEGlobalVarHelper.Dict.local_copy | ( | self | ) |
Referenced by SalomeSDSClt.Float.__add__(), SalomeSDSClt.Int.__add__(), SalomeSDSClt.String.__add__(), SalomeSDSClt.Dict.__contains__(), SalomeSDSClt.Float.__floordiv__(), SalomeSDSClt.Int.__floordiv__(), SalomeSDSClt.String.__getitem__(), SalomeSDSClt.Float.__iadd__(), SalomeSDSClt.Int.__iadd__(), SalomeSDSClt.String.__iadd__(), SalomeSDSClt.Float.__ifloordiv__(), SalomeSDSClt.Int.__ifloordiv__(), SalomeSDSClt.Int.__imod__(), SalomeSDSClt.Float.__imul__(), SalomeSDSClt.Int.__imul__(), SalomeSDSClt.Float.__isub__(), SalomeSDSClt.Int.__isub__(), SalomeSDSClt.Float.__itruediv__(), SalomeSDSClt.Int.__itruediv__(), SALOMEGlobalVarHelper.Dict.__len__(), SalomeSDSClt.List.__len__(), SalomeSDSClt.Dict.__len__(), SalomeSDSClt.Tuple.__len__(), SalomeSDSClt.String.__len__(), SalomeSDSClt.Int.__mod__(), SalomeSDSClt.Float.__mul__(), SalomeSDSClt.Int.__mul__(), SalomeSDSClt.Float.__pow__(), SalomeSDSClt.Int.__pow__(), SALOMEGlobalVarHelper.List.__reduce__(), SALOMEGlobalVarHelper.Tuple.__reduce__(), SALOMEGlobalVarHelper.Int.__reduce__(), SALOMEGlobalVarHelper.Dict.__reduce__(), SalomeSDSClt.WrappedType.__reduce__(), SALOMEGlobalVarHelper.List.__repr__(), SALOMEGlobalVarHelper.Tuple.__repr__(), SALOMEGlobalVarHelper.Int.__repr__(), SALOMEGlobalVarHelper.Dict.__repr__(), SalomeSDSClt.WrappedType.__repr__(), SALOMEGlobalVarHelper.List.__str__(), SALOMEGlobalVarHelper.Tuple.__str__(), SALOMEGlobalVarHelper.Int.__str__(), SALOMEGlobalVarHelper.Dict.__str__(), SalomeSDSClt.WrappedType.__str__(), SalomeSDSClt.Float.__sub__(), SalomeSDSClt.Int.__sub__(), SalomeSDSClt.Float.__truediv__(), SalomeSDSClt.Int.__truediv__(), SalomeSDSClt.Float.as_integer_ratio(), SalomeSDSClt.Int.bit_length(), SalomeSDSClt.String.capitalize(), SalomeSDSClt.String.center(), SalomeSDSClt.Float.conjugate(), SalomeSDSClt.Int.conjugate(), SalomeSDSClt.Dict.copy(), SalomeSDSClt.List.count(), SalomeSDSClt.Tuple.count(), SalomeSDSClt.String.count(), SalomeSDSClt.String.decode(), SalomeSDSClt.Int.denominator(), SalomeSDSClt.String.encode(), SalomeSDSClt.String.endswith(), SalomeSDSClt.String.expandtabs(), SalomeSDSClt.String.find(), SalomeSDSClt.String.format(), SalomeSDSClt.Float.fromhex(), SalomeSDSClt.Dict.has_key(), SalomeSDSClt.Float.hex(), SalomeSDSClt.Float.imag(), SalomeSDSClt.Int.imag(), SalomeSDSClt.List.index(), SalomeSDSClt.Tuple.index(), SalomeSDSClt.String.index(), SalomeSDSClt.Float.is_integer(), SalomeSDSClt.String.isalnum(), SalomeSDSClt.String.isalpha(), SalomeSDSClt.String.isdigit(), SalomeSDSClt.String.islower(), SalomeSDSClt.String.isspace(), SalomeSDSClt.String.istitle(), SalomeSDSClt.String.isupper(), SalomeSDSClt.String.join(), SalomeSDSClt.Dict.keys(), SalomeSDSClt.String.ljust(), SalomeSDSClt.String.lower(), SalomeSDSClt.String.lstrip(), SalomeSDSClt.Int.numerator(), SalomeSDSClt.String.partition(), SalomeSDSClt.Float.real(), SalomeSDSClt.Int.real(), SalomeSDSClt.String.replace(), SalomeSDSClt.String.rfind(), SalomeSDSClt.String.rindex(), SalomeSDSClt.String.rjust(), SalomeSDSClt.String.rpartition(), SalomeSDSClt.String.rsplit(), SalomeSDSClt.String.rstrip(), SalomeSDSClt.String.split(), SalomeSDSClt.String.splitlines(), SalomeSDSClt.String.startswith(), SalomeSDSClt.String.strip(), SalomeSDSClt.String.swapcase(), SalomeSDSClt.String.title(), SalomeSDSClt.String.translate(), SalomeSDSClt.String.upper(), and SalomeSDSClt.String.zfill().
private |
private |
Referenced by SALOMEGlobalVarHelper.Caller.__call__(), SalomeSDSClt.Caller.__call__(), SALOMEGlobalVarHelper.List.__del__(), SALOMEGlobalVarHelper.Tuple.__del__(), SALOMEGlobalVarHelper.Int.__del__(), SALOMEGlobalVarHelper.Dict.__del__(), SalomeSDSClt.WrappedType.__del__(), SalomeSDSClt.List.__delitem__(), SalomeSDSClt.Dict.__delitem__(), SALOMEGlobalVarHelper.List.__getitem__(), SALOMEGlobalVarHelper.Tuple.__getitem__(), SALOMEGlobalVarHelper.Dict.__getitem__(), SalomeSDSClt.List.__getitem__(), SalomeSDSClt.Dict.__getitem__(), SalomeSDSClt.Tuple.__getitem__(), SALOMEGlobalVarHelper.Int.__iadd__(), SALOMEGlobalVarHelper.Int.__isub__(), SALOMEGlobalVarHelper.List.__setitem__(), SALOMEGlobalVarHelper.Tuple.__setitem__(), SALOMEGlobalVarHelper.Dict.__setitem__(), SalomeSDSClt.List.__setitem__(), SalomeSDSClt.Dict.__setitem__(), SALOMEGlobalVarHelper.List.append(), SalomeSDSClt.List.append(), SALOMEGlobalVarHelper.List.assign(), SALOMEGlobalVarHelper.Tuple.assign(), SALOMEGlobalVarHelper.Int.assign(), SALOMEGlobalVarHelper.Dict.assign(), SalomeSDSClt.WrappedType.assign(), SalomeSDSClt.Dict.clear(), SalomeSDSClt.List.extend(), SalomeSDSClt.Dict.get(), SalomeSDSClt.List.insert(), SalomeSDSClt.InvokatorPossibleStyle.invokePythonMethodOn(), SalomeSDSClt.Dict.items(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SalomeSDSClt.List.pop(), SalomeSDSClt.Dict.pop(), SalomeSDSClt.Dict.popitem(), SalomeSDSClt.InvokatorStyle.ptr(), SalomeSDSClt.WrappedType.ptr(), SalomeSDSClt.List.remove(), SalomeSDSClt.List.reverse(), SalomeSDSClt.Dict.setdefault(), SalomeSDSClt.List.sort(), SalomeSDSClt.Dict.update(), and SalomeSDSClt.Dict.values().
