| def | __init__ (self, varPtr, isTemporaryVar=False) |
| def | __add__ (self, *args) |
| def | __iadd__ (self, *args) |
| def | __getitem__ (self, *args) |
| def | capitalize (self, *args) |
| def | center (self, *args) |
| def | count (self, *args) |
| def | decode (self, *args) |
| def | encode (self, *args) |
| def | endswith (self, *args) |
| def | expandtabs (self, *args) |
| def | find (self, *args) |
| def | format (self, *args) |
| def | index (self, *args) |
| def | isalnum (self, *args) |
| def | isalpha (self, *args) |
| def | isdigit (self, *args) |
| def | islower (self, *args) |
| def | isspace (self, *args) |
| def | istitle (self, *args) |
| def | isupper (self, *args) |
| def | join (self, *args) |
| def | ljust (self, *args) |
| def | lower (self, *args) |
| def | lstrip (self, *args) |
| def | partition (self, *args) |
| def | replace (self, *args) |
| def | rfind (self, *args) |
| def | rindex (self, *args) |
| def | rjust (self, *args) |
| def | rpartition (self, *args) |
| def | rsplit (self, *args) |
| def | rstrip (self, *args) |
| def | split (self, *args) |
| def | splitlines (self, *args) |
| def | startswith (self, *args) |
| def | strip (self, *args) |
| def | swapcase (self, *args) |
| def | title (self, *args) |
| def | translate (self, *args) |
| def | upper (self, *args) |
| def | zfill (self, *args) |
| def | __len__ (self) |
Private Attributes | |
| _wrapped_type | |
| def SalomeSDSClt.String.__init__ | ( | self, | |
| varPtr, | |||
isTemporaryVar = False |
Reimplemented from SalomeSDSClt.WrappedType.
| def SalomeSDSClt.String.__add__ | ( | self, | |
| * | args | ||
Reimplemented from SALOMEWrappedStdType.String.
References SalomeSDSClt.String.__add__(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.__add__(), and SalomeSDSClt.String.__iadd__().
| def SalomeSDSClt.String.__getitem__ | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.__getitem__(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.__getitem__().
| def SalomeSDSClt.String.__iadd__ | ( | self, | |
| * | args | ||
| def SalomeSDSClt.String.__len__ | ( | self | ) |
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
| def SalomeSDSClt.String.capitalize | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.capitalize(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.capitalize().
| def SalomeSDSClt.String.center | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.center(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.center().
| def SalomeSDSClt.String.count | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.count(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.count().
| def SalomeSDSClt.String.decode | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.decode(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.decode().
| def SalomeSDSClt.String.encode | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.encode(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.encode().
| def SalomeSDSClt.String.endswith | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.endswith(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.endswith().
| def SalomeSDSClt.String.expandtabs | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.expandtabs(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.expandtabs().
| def SalomeSDSClt.String.find | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.find(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.find().
| def SalomeSDSClt.String.format | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.format(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.format().
| def SalomeSDSClt.String.index | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.index(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.index().
| def SalomeSDSClt.String.isalnum | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.isalnum(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.isalnum().
| def SalomeSDSClt.String.isalpha | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.isalpha(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.isalpha().
| def SalomeSDSClt.String.isdigit | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.isdigit(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.isdigit().
| def SalomeSDSClt.String.islower | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.islower(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.islower().
| def SalomeSDSClt.String.isspace | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.isspace(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.isspace().
| def SalomeSDSClt.String.istitle | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.istitle(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.istitle().
| def SalomeSDSClt.String.isupper | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.isupper(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.isupper().
| def SalomeSDSClt.String.join | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.join(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.join().
| def SalomeSDSClt.String.ljust | ( | self, | |
| * | args | ||
References SalomeSDSClt.String.ljust(), SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), and SALOMEWrappedStdType.WrappedType.local_copy().
Referenced by SalomeSDSClt.String.ljust().
| def SalomeSDSClt.String.lower | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.lower().
Referenced by SalomeSDSClt.String.lower().
| def SalomeSDSClt.String.lstrip | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.lstrip().
Referenced by SalomeSDSClt.String.lstrip().
| def SalomeSDSClt.String.partition | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.partition().
Referenced by SalomeSDSClt.String.partition().
| def SalomeSDSClt.String.replace | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.replace().
Referenced by SalomeSDSClt.String.replace().
| def SalomeSDSClt.String.rfind | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.rfind().
Referenced by SalomeSDSClt.String.rfind().
| def SalomeSDSClt.String.rindex | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.rindex().
Referenced by SalomeSDSClt.String.rindex().
| def SalomeSDSClt.String.rjust | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.rjust().
Referenced by SalomeSDSClt.String.rjust().
| def SalomeSDSClt.String.rpartition | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.rpartition().
Referenced by SalomeSDSClt.String.rpartition().
| def SalomeSDSClt.String.rsplit | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.rsplit().
Referenced by SalomeSDSClt.String.rsplit().
| def SalomeSDSClt.String.rstrip | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.rstrip().
Referenced by SalomeSDSClt.String.rstrip().
| def SalomeSDSClt.String.split | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.split().
Referenced by SalomeSDSClt.String.split().
| def SalomeSDSClt.String.splitlines | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.splitlines().
Referenced by SalomeSDSClt.String.splitlines().
| def SalomeSDSClt.String.startswith | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.startswith().
Referenced by SalomeSDSClt.String.startswith().
| def SalomeSDSClt.String.strip | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.strip().
Referenced by SalomeSDSClt.String.strip().
| def SalomeSDSClt.String.swapcase | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.swapcase().
Referenced by SalomeSDSClt.String.swapcase().
| def SalomeSDSClt.String.title | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.title().
Referenced by SalomeSDSClt.String.title().
| def SalomeSDSClt.String.translate | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.translate().
Referenced by SalomeSDSClt.String.translate().
| def SalomeSDSClt.String.upper | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.upper().
Referenced by SalomeSDSClt.String.upper().
| def SalomeSDSClt.String.zfill | ( | self, | |
| * | args | ||
References SALOMEGlobalVarHelper.List.local_copy(), SALOMEGlobalVarHelper.Tuple.local_copy(), SALOMEGlobalVarHelper.Int.local_copy(), SALOMEGlobalVarHelper.Dict.local_copy(), SalomeSDSClt.WrappedType.local_copy(), SALOMEWrappedStdType.WrappedType.local_copy(), and SalomeSDSClt.String.zfill().
Referenced by SalomeSDSClt.String.zfill().
private |
Referenced by SalomeSDSClt.WrappedType.__reduce__().
