SALOMEWrappedStdType.WrappedType Class Reference
Inheritance diagram for SALOMEWrappedStdType.WrappedType:
def ptr (self)
def local_copy (self)
def assign (self, elt)
 Here definition of an interface in python.
◆ assign()
def SALOMEWrappedStdType.WrappedType.assign (   self,
  elt
◆ local_copy()
def SALOMEWrappedStdType.WrappedType.local_copy (   self)
Reimplemented in SalomeSDSClt.WrappedType.
References SALOMEWrappedStdType._raiseNow().
Referenced by SalomeSDSClt.Float.__add__(), SalomeSDSClt.Int.__add__(), SalomeSDSClt.String.__add__(), SalomeSDSClt.Dict.__contains__(), SalomeSDSClt.Float.__floordiv__(), SalomeSDSClt.Int.__floordiv__(), SalomeSDSClt.String.__getitem__(), SalomeSDSClt.Float.__iadd__(), SalomeSDSClt.Int.__iadd__(), SalomeSDSClt.String.__iadd__(), SalomeSDSClt.Float.__ifloordiv__(), SalomeSDSClt.Int.__ifloordiv__(), SalomeSDSClt.Int.__imod__(), SalomeSDSClt.Float.__imul__(), SalomeSDSClt.Int.__imul__(), SalomeSDSClt.Float.__isub__(), SalomeSDSClt.Int.__isub__(), SalomeSDSClt.Float.__itruediv__(), SalomeSDSClt.Int.__itruediv__(), SALOMEGlobalVarHelper.Dict.__len__(), SalomeSDSClt.List.__len__(), SalomeSDSClt.Dict.__len__(), SalomeSDSClt.Tuple.__len__(), SalomeSDSClt.String.__len__(), SalomeSDSClt.Int.__mod__(), SalomeSDSClt.Float.__mul__(), SalomeSDSClt.Int.__mul__(), SalomeSDSClt.Float.__pow__(), SalomeSDSClt.Int.__pow__(), SALOMEGlobalVarHelper.List.__reduce__(), SALOMEGlobalVarHelper.Tuple.__reduce__(), SALOMEGlobalVarHelper.Int.__reduce__(), SALOMEGlobalVarHelper.Dict.__reduce__(), SalomeSDSClt.WrappedType.__reduce__(), SALOMEGlobalVarHelper.List.__repr__(), SALOMEGlobalVarHelper.Tuple.__repr__(), SALOMEGlobalVarHelper.Int.__repr__(), SALOMEGlobalVarHelper.Dict.__repr__(), SalomeSDSClt.WrappedType.__repr__(), SALOMEGlobalVarHelper.List.__str__(), SALOMEGlobalVarHelper.Tuple.__str__(), SALOMEGlobalVarHelper.Int.__str__(), SALOMEGlobalVarHelper.Dict.__str__(), SalomeSDSClt.WrappedType.__str__(), SalomeSDSClt.Float.__sub__(), SalomeSDSClt.Int.__sub__(), SalomeSDSClt.Float.__truediv__(), SalomeSDSClt.Int.__truediv__(), SalomeSDSClt.Float.as_integer_ratio(), SalomeSDSClt.Int.bit_length(), SalomeSDSClt.String.capitalize(), SalomeSDSClt.String.center(), SalomeSDSClt.Float.conjugate(), SalomeSDSClt.Int.conjugate(), SalomeSDSClt.Dict.copy(), SalomeSDSClt.List.count(), SalomeSDSClt.Tuple.count(), SalomeSDSClt.String.count(), SalomeSDSClt.String.decode(), SalomeSDSClt.Int.denominator(), SalomeSDSClt.String.encode(), SalomeSDSClt.String.endswith(), SalomeSDSClt.String.expandtabs(), SalomeSDSClt.String.find(), SalomeSDSClt.String.format(), SalomeSDSClt.Float.fromhex(), SalomeSDSClt.Dict.has_key(), SalomeSDSClt.Float.hex(), SalomeSDSClt.Float.imag(), SalomeSDSClt.Int.imag(), SalomeSDSClt.List.index(), SalomeSDSClt.Tuple.index(), SalomeSDSClt.String.index(), SalomeSDSClt.Float.is_integer(), SalomeSDSClt.String.isalnum(), SalomeSDSClt.String.isalpha(), SalomeSDSClt.String.isdigit(), SalomeSDSClt.String.islower(), SalomeSDSClt.String.isspace(), SalomeSDSClt.String.istitle(), SalomeSDSClt.String.isupper(), SalomeSDSClt.String.join(), SalomeSDSClt.Dict.keys(), SalomeSDSClt.String.ljust(), SalomeSDSClt.String.lower(), SalomeSDSClt.String.lstrip(), SalomeSDSClt.Int.numerator(), SalomeSDSClt.String.partition(), SalomeSDSClt.Float.real(), SalomeSDSClt.Int.real(), SalomeSDSClt.String.replace(), SalomeSDSClt.String.rfind(), SalomeSDSClt.String.rindex(), SalomeSDSClt.String.rjust(), SalomeSDSClt.String.rpartition(), SalomeSDSClt.String.rsplit(), SalomeSDSClt.String.rstrip(), SalomeSDSClt.String.split(), SalomeSDSClt.String.splitlines(), SalomeSDSClt.String.startswith(), SalomeSDSClt.String.strip(), SalomeSDSClt.String.swapcase(), SalomeSDSClt.String.title(), SalomeSDSClt.String.translate(), SalomeSDSClt.String.upper(), and SalomeSDSClt.String.zfill().
◆ ptr()
def SALOMEWrappedStdType.WrappedType.ptr (   self)
