20#ifndef ModelAPI_Result_H_
21#define ModelAPI_Result_H_
23#include "ModelAPI_Object.h"
28typedef std::list<std::shared_ptr<GeomAPI_Shape> > ListOfShape;
48 static const std::string MY_COLOR_ID(
"Color");
56 static const std::string MY_DEFLECTION_ID(
"Deflection");
57 return MY_DEFLECTION_ID;
64 static const std::string MY_TRANSPARENCY_ID(
"Transparency");
65 return MY_TRANSPARENCY_ID;
72 static const std::string MY_ISO_LINES_ID(
"Iso_lines");
73 return MY_ISO_LINES_ID;
80 static const std::string MY_SHOW_ISO_LINES_ID(
"Show_Iso_lines");
81 return MY_SHOW_ISO_LINES_ID;
88 static const std::string MY_SHOW_EDGES_DIRECTION_ID(
"Show_Edges_direction");
89 return MY_SHOW_EDGES_DIRECTION_ID;
96 static const std::string MY_BRING_TO_FRONT_ID(
"Bring_To_Front");
97 return MY_BRING_TO_FRONT_ID;
104 MODELAPI_EXPORT
virtual void setIsConcealed(
const bool theValue,
const bool theForced =
false);
112 MODELAPI_EXPORT
virtual bool setDisabled(std::shared_ptr<ModelAPI_Result> theThis,
125 MODELAPI_EXPORT
virtual std::shared_ptr<GeomAPI_Shape>
shape();
128 MODELAPI_EXPORT
virtual ListOfShape
129 vertices(
const bool theOnlyUnique =
false);
132 MODELAPI_EXPORT
virtual ListOfShape
133 edges(
false);
136 MODELAPI_EXPORT
virtual ListOfShape
137 wires(
false);
140 MODELAPI_EXPORT
virtual ListOfShape
141 faces(
false);
144 MODELAPI_EXPORT
virtual ListOfShape
145 shells(
false);
148 MODELAPI_EXPORT
virtual ListOfShape
149 solids(
false);
157 void showErrorMessage();
162 MODELAPI_EXPORT
virtual void init();
168typedef std::shared_ptr<ModelAPI_Result> ResultPtr;
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
The result of a feature.
Definition: ModelAPI_Result.h:37
virtual void init()
This method is called just after creation of the object: it must initialize all fields,...
Definition: ModelAPI_Result.cpp:197
virtual ListOfShape vertices(const bool theOnlyUnique=false)
Returns all the vertices of this result.
Definition: ModelAPI_Result.cpp:129
static const std::string & SHOW_ISO_LINES_ID()
Reference to the transparency of the result.
Definition: ModelAPI_Result.h:78
virtual ListOfShape edges(const bool theOnlyUnique=false)
Returns all the edges of this result.
Definition: ModelAPI_Result.cpp:139
virtual ListOfShape faces(const bool theOnlyUnique=false)
Returns all the faces of this result.
Definition: ModelAPI_Result.cpp:159
static const std::string & COLOR_ID()
Reference to the color of the result.
Definition: ModelAPI_Result.h:46
virtual bool isConcealed()
Returns true if the result is concealed from the data tree (referenced by other objects)
Definition: ModelAPI_Result.cpp:89
virtual bool isDisabled()
Returns the result is disabled or not.
Definition: ModelAPI_Result.cpp:81
virtual bool setDisabled(std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag)
Enables/disables the result.
Definition: ModelAPI_Result.cpp:57
virtual void initAttributes()
Request for initialization of data model of the result: adding all attributes.
Definition: ModelAPI_Result.cpp:42
virtual ~ModelAPI_Result()
To virtually destroy the fields of successors.
Definition: ModelAPI_Result.cpp:38
bool myIsDisabled
the result is disabled: removed for the user, but keeps the general info
Definition: ModelAPI_Result.h:40
static const std::string & BRING_TO_FRONT_ID()
Reference to the BringToFront flag of the result.
Definition: ModelAPI_Result.h:94
static const std::string & TRANSPARENCY_ID()
Definition: ModelAPI_Result.h:62
virtual void attributeChanged(const std::string &theID)
On change of attribute of the result update presentation of this result: for the current moment there...
Definition: ModelAPI_Result.cpp:189
virtual std::shared_ptr< GeomAPI_Shape > shape()
Returns the shape-result produced by this feature (or null if no shapes)
Definition: ModelAPI_Result.cpp:112
static const std::string & SHOW_EDGES_DIRECTION_ID()
Definition: ModelAPI_Result.h:86
virtual ListOfShape solids(const bool theOnlyUnique=false)
Returns all the solids of this result.
Definition: ModelAPI_Result.cpp:179
virtual ListOfShape wires(const bool theOnlyUnique=false)
Returns all the wires of this result.
Definition: ModelAPI_Result.cpp:149
static const std::string & ISO_LINES_ID()
Definition: ModelAPI_Result.h:70
static const std::string & DEFLECTION_ID()
Reference to the deflection of the result.
Definition: ModelAPI_Result.h:54
virtual ListOfShape shells(const bool theOnlyUnique=false)
Returns all the shells of this result.
Definition: ModelAPI_Result.cpp:169
virtual void setIsConcealed(const bool theValue, const bool theForced=false)
Sets the result as concealed in the data tree (referenced by other objects)
Definition: ModelAPI_Result.cpp:94
Manager of objects of the document.
Definition: Model_Objects.h:46
