20#ifndef SRC_MODELHIGHAPI_MODELHIGHAPI_SELECTION_H_
21#define SRC_MODELHIGHAPI_MODELHIGHAPI_SELECTION_H_
24#include "ModelHighAPI.h"
38typedef std::pair<std::shared_ptr<ModelAPI_Result>, std::shared_ptr<GeomAPI_Shape> >
40typedef std::pair<std::string, std::wstring> TypeSubShapeNamePair;
41typedef std::pair<std::string, std::shared_ptr<GeomAPI_Pnt> > TypeInnerPointPair;
42typedef std::pair<std::string, std::pair<std::wstring, int> > TypeWeakNamingPair;
53 VT_ResultSubShapePair,
54 VT_TypeSubShapeNamePair,
55 VT_TypeInnerPointPair,
68 const std::shared_ptr<GeomAPI_Shape>& theSubShape =
69 std::shared_ptr<GeomAPI_Shape>());
73 const std::wstring& theSubShapeName);
78 const std::shared_ptr<GeomAPI_Pnt>& theSubShapeInnerPoint);
83 const std::list<double>& theSubShapeInnerPoint);
89 const std::wstring& theContextName,
const int theIndex);
96 MODELHIGHAPI_EXPORT
97 void fillAttribute(
const std::shared_ptr<ModelAPI_AttributeSelection> & theAttribute)
const;
100 MODELHIGHAPI_EXPORT
101 void appendToList(
const std::shared_ptr<ModelAPI_AttributeSelectionList> & theAttribute,
const bool theIsIgnoreGroups =
false)
const;
129 void setName(
const std::wstring& theName);
133 std::wstring
name()
const;
137 void setColor(
int theRed = 0,
int theGreen = 0,
int theBlue = 0,
bool random =
false);
142 int theRed,
int theGreen,
int theBlue);
170 VariantType myVariantType;
171 ResultSubShapePair myResultSubShapePair;
172 TypeSubShapeNamePair myTypeSubShapeNamePair;
173 TypeInnerPointPair myTypeInnerPointPair;
174 TypeWeakNamingPair myWeakNamingPair;
175 std::shared_ptr<ModelAPI_FiltersFeature> myFilterFeature;
Definition: GeomAPI_Pnt.h:38
An interface for working with filters in the feature.
Definition: ModelAPI_FiltersFeature.h:33
The result of a feature.
Definition: ModelAPI_Result.h:37
void setName(const std::wstring &theName)
Shortcut for result()->data()->setName()
Definition: ModelHighAPI_Selection.cpp:193
int numberOfSubs() const
Returns the number of sub-elements.
Definition: ModelHighAPI_Selection.cpp:335
ModelHighAPI_Selection subResult(int theIndex) const
Returns the sub-result by zero-base index.
Definition: ModelHighAPI_Selection.cpp:347
virtual VariantType variantType() const
Definition: ModelHighAPI_Selection.cpp:147
std::wstring name() const
Shortcut for result()->data()->name()
Definition: ModelHighAPI_Selection.cpp:204
virtual ~ModelHighAPI_Selection()
Definition: ModelHighAPI_Selection.cpp:83
void setSubShapeColor(const ModelHighAPI_Selection &theShape, int theRed, int theGreen, int theBlue)
Change subShape' color.
Definition: ModelHighAPI_Selection.cpp:238
virtual TypeInnerPointPair typeInnerPointPair() const
Definition: ModelHighAPI_Selection.cpp:165
std::list< int > getSubShapeColor(const ModelHighAPI_Selection &theShape)
Get subShape' color.
Definition: ModelHighAPI_Selection.cpp:269
virtual TypeSubShapeNamePair typeSubShapeNamePair() const
Definition: ModelHighAPI_Selection.cpp:159
virtual std::string shapeType() const
Definition: ModelHighAPI_Selection.cpp:177
virtual void fillAttribute(const std::shared_ptr< ModelAPI_AttributeSelection > &theAttribute) const
Fill attribute values.
Definition: ModelHighAPI_Selection.cpp:88
virtual ResultSubShapePair resultSubShapePair() const
Definition: ModelHighAPI_Selection.cpp:153
virtual void appendToList(const std::shared_ptr< ModelAPI_AttributeSelectionList > &theAttribute, const bool theIsIgnoreGroups=false) const
Append to list attribute.
Definition: ModelHighAPI_Selection.cpp:118
void setDeflection(double theValue)
Change result's deflection.
Definition: ModelHighAPI_Selection.cpp:311
void setColor(int theRed=0, int theGreen=0, int theBlue=0, bool random=false)
Change result's color.
Definition: ModelHighAPI_Selection.cpp:214
void setTransparency(double theValue)
Change result's transparency.
Definition: ModelHighAPI_Selection.cpp:323
virtual TypeWeakNamingPair typeWeakNamingPair() const
Definition: ModelHighAPI_Selection.cpp:171
Default constructor with empty selection.
Definition: ModelHighAPI_Selection.cpp:35
