ModuleBase_WidgetFeatureSelector.h
20#ifndef ModuleBase_WidgetFeatureSelector_H
21#define ModuleBase_WidgetFeatureSelector_H
23#include "ModuleBase.h"
24#include "ModuleBase_WidgetSelector.h"
27class QWidget;
28class QLabel;
29class QLineEdit;
30
48{
49Q_OBJECT
50 public:
51
57 const Config_WidgetAPI* theData);
58
60
67 virtual bool setSelection(QList<std::shared_ptr<ModuleBase_ViewerPrs>>& theValues,
68 const bool theToValidate);
69
73 virtual void selectionModes(int& theModuleSelectionModes, QIntList& theModes);
74
77 virtual QList<QWidget*> getControls() const;
78
81 virtual bool setSelectionCustom(const std::shared_ptr<ModuleBase_ViewerPrs>& thePrs);
82
83protected:
85 virtual void activateCustom();
86
89 virtual bool storeValueCustom();
90
91 virtual bool restoreValueCustom();
92
94 virtual void updateSelectionName();
95
96 // Update focus after the attribute value change
97 virtual void updateFocus();
98
102 virtual bool isValidInFilters(const std::shared_ptr<ModuleBase_ViewerPrs>& thePrs);
103
106 virtual void updateOnSelectionChanged(const bool theDone);
107
108protected:
110 virtual bool processSelection();
111
112 //----------- Class members -------------
113protected:
116
119};
120
121#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
Class which provides access to Workshop object services.
Definition: ModuleBase_IWorkshop.h:48
virtual void selectionModes(int &theModuleSelectionModes, QIntList &theModes)
Fills given container with selection modes if the widget has it.
Definition: ModuleBase_ModelWidget.cpp:116
The method called when widget is activated.
Definition: ModuleBase_ModelWidget.h:410
virtual QList< QWidget * > getControls() const =0
Returns list of widget controls.
Returns true if envent is processed. It applies workshop selection for the widget attribute.
Definition: ModuleBase_ModelWidget.cpp:515
virtual bool storeValueCustom()=0
Saves the internal parameters to the given feature.
virtual bool restoreValueCustom()=0
Restore value from attribute data to the widget's control.
virtual bool setSelection(QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues, const bool theToValidate)
Set the given wrapped value to the current widget This value should be processed in the widget accord...
Definition: ModuleBase_ModelWidget.h:163
Implementation of widget for feature selection.
Definition: ModuleBase_WidgetFeatureSelector.h:48
QLabel * myLabel
Label of the widget.
Definition: ModuleBase_WidgetFeatureSelector.h:115
QLineEdit * myTextLine
Input control of the widget.
Definition: ModuleBase_WidgetFeatureSelector.h:118
Implementation of widget with validators and filters processing.
Definition: ModuleBase_WidgetValidated.h:54
virtual bool setSelectionCustom(const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)=0
Fills the attribute with the value of the selected owner.
virtual bool isValidInFilters(const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
Checks whether all active viewer filters validate the presentation.
Definition: ModuleBase_WidgetValidated.cpp:125
