ModuleBase_WidgetSelector.h
20#ifndef ModuleBase_WidgetSelector_H
21#define ModuleBase_WidgetSelector_H
23#include "ModuleBase.h"
24#include "ModuleBase_WidgetValidated.h"
25#include "ModuleBase_Definitions.h"
26
27#include <ModelAPI_Object.h>
28#include <ModelAPI_Attribute.h>
29#include <GeomAPI_Shape.h>
30
32class QWidget;
35class ModelAPI_Result;
36
43{
44Q_OBJECT
45 public:
46
52 const Config_WidgetAPI* theData);
53
55
59 virtual void selectionModes(int& theModuleSelectionModes, QIntList& theModes);
60
62 virtual bool isViewerSelector() { return true; }
63
65 virtual void updateSelectionModesAndFilters(bool toActivate);
66
70 virtual bool isValidSelectionCustom(const std::shared_ptr<ModuleBase_ViewerPrs>& thePrs);
71
74 virtual bool setSelectionCustom(const std::shared_ptr<ModuleBase_ViewerPrs>& thePrs);
75
77 virtual void deactivate();
78
82 virtual QList<std::shared_ptr<ModuleBase_ViewerPrs>> getAttributeSelection() const;
83
84 virtual bool isWholeResultAllowed() const;
85
86protected:
88 virtual bool processSelection();
89
92 virtual void updateOnSelectionChanged(const bool theDone);
93
95 // NDS: has body is temporary
96 virtual void updateFocus() {};
97
100 QIntList getShapeTypes() const;
101
104 virtual QIntList shapeTypes() const = 0;
105
107 // NDS: has body is temporary
108 virtual void updateSelectionName() {};
109
111 virtual void activateCustom();
112
119 bool acceptSubShape(const GeomShapePtr& theShape,
120 const std::shared_ptr<ModelAPI_Result>& theResult) const;
121
126 virtual void getGeomSelection(const std::shared_ptr<ModuleBase_ViewerPrs>& thePrs,
127 ObjectPtr& theObject,
128 GeomShapePtr& theShape);
129
130protected:
131 bool myIsPointsFiltering;
132};
133
134#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
The result of a feature.
Definition: ModelAPI_Result.h:37
Class which provides access to Workshop object services.
Definition: ModuleBase_IWorkshop.h:48
virtual void selectionModes(int &theModuleSelectionModes, QIntList &theModes)
Fills given container with selection modes if the widget has it.
Definition: ModuleBase_ModelWidget.cpp:116
The method called when widget is activated.
Definition: ModuleBase_ModelWidget.h:410
Returns true if envent is processed. It applies workshop selection for the widget attribute.
Definition: ModuleBase_ModelWidget.cpp:515
Presentation.
Definition: ModuleBase_ViewerPrs.h:37
Implementation of widget for selection.
Definition: ModuleBase_WidgetSelector.h:43
virtual QIntList shapeTypes() const =0
Returns a list of possible shape types.
Defines if it is supposed that the widget should interact with the viewer.
Definition: ModuleBase_WidgetSelector.h:62
Update focus after the attribute value change.
Definition: ModuleBase_WidgetSelector.h:96
Computes and updates name of selected object in the widget.
Definition: ModuleBase_WidgetSelector.h:108
Implementation of widget with validators and filters processing.
Definition: ModuleBase_WidgetValidated.h:54
virtual bool isValidSelectionCustom(const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)
Checks the widget validity.
Definition: ModuleBase_WidgetValidated.cpp:313
virtual bool setSelectionCustom(const std::shared_ptr< ModuleBase_ViewerPrs > &thePrs)=0
Fills the attribute with the value of the selected owner.
The method called when widget is deactivated.
Definition: ModuleBase_WidgetValidated.cpp:69
