SamplePanelPlugin_ModelWidgetCreator.h
20#ifndef SamplePanelPlugin_ModelWidgetCreator_H
21#define SamplePanelPlugin_ModelWidgetCreator_H
23#include "SamplePanelPlugin.h"
24
25#include <ModuleBase_IWidgetCreator.h>
26
27#include <string>
28#include <set>
32class QWidget;
33
39{
40public:
43
46
49 virtual void widgetTypes(std::set<std::string>& theTypes);
50
58 virtual ModuleBase_ModelWidget* createWidgetByType(const std::string& theType,
59 QWidget* theParent,
60 Config_WidgetAPI* theWidgetApi,
61 ModuleBase_IWorkshop* /*theWorkshop*/);
62private:
63 std::set<std::string> myModelWidgetTypes;
64};
65
66#endif
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
Interface to WidgetCreator which can create specific widgets by type.
Definition: ModuleBase_IWidgetCreator.h:48
Class which provides access to Workshop object services.
Definition: ModuleBase_IWorkshop.h:48
An abstract custom widget class.
Definition: ModuleBase_ModelWidget.h:60
Definition: SamplePanelPlugin_ModelWidgetCreator.h:39
virtual ModuleBase_ModelWidget * createWidgetByType(const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi, ModuleBase_IWorkshop *)
Create widget by its type The default implementation is empty.
Definition: SamplePanelPlugin_ModelWidgetCreator.cpp:36
virtual void widgetTypes(std::set< std::string > &theTypes)
Returns a container of possible widget types, which this creator can process.
Definition: SamplePanelPlugin_ModelWidgetCreator.cpp:31
~SamplePanelPlugin_ModelWidgetCreator()
Virtual destructor.
Definition: SamplePanelPlugin_ModelWidgetCreator.h:45
Default constructor.
Definition: SamplePanelPlugin_ModelWidgetCreator.cpp:25
