Interface to WidgetCreator which can create specific widgets by type. More...
#include <ModuleBase_IWidgetCreator.h>
| ModuleBase_IWidgetCreator () | |
| ~ModuleBase_IWidgetCreator () | |
| Virtual destructor. More... | |
| virtual void | panelTypes (std::set< std::string > &) |
| Returns a container of possible page types, which this creator can process The default implementation is empty. More... | |
| virtual void | pageTypes (std::set< std::string > &theTypes) |
| virtual void | widgetTypes (std::set< std::string > &theTypes) |
| Returns a container of possible widget types, which this creator can process. More... | |
| virtual QWidget * | createPanelByType (const std::string &theType, QWidget *theParent, const FeaturePtr &theFeature, Config_WidgetAPI *theWidgetApi=0) |
| Create panel control by its type. More... | |
| virtual ModuleBase_PageBase * | createPageByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi) |
| Create page by its type The default implementation is empty. More... | |
| virtual ModuleBase_ModelWidget * | createWidgetByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi, ModuleBase_IWorkshop *theWorkshop) |
| Create widget by its type The default implementation is empty. More... | |
| ModuleBase_IWidgetCreator::ModuleBase_IWidgetCreator | ( | ) |
| ModuleBase_IWidgetCreator::~ModuleBase_IWidgetCreator | ( | ) |
Virtual destructor.
inlinevirtual |
| theTypes | a list of type names |
Reimplemented in SamplePanelPlugin_WidgetCreator.
inlinevirtual |
inlinevirtual |
Reimplemented in CollectionPlugin_WidgetCreator, ParametersPlugin_WidgetCreator, and SamplePanelPlugin_ModelWidgetCreator.
| theType | a panel type |
| theParent | a parent widget |
| theFeature | a feature modified in the panel |
| theWidgetApi | a low-level API for reading xml definitions of widget |
| theType | a type |
| theWidgetApi | a low-level API for reading xml definitions of widgets |
| theType | a type |
| theWorkshop | a workshop class instance |
Reimplemented in CollectionPlugin_WidgetCreator, SamplePanelPlugin_ModelWidgetCreator, and ParametersPlugin_WidgetCreator.
