SamplePanelPlugin_WidgetCreator Class Reference
Interface to WidgetCreator which can create specific widgets by type. More...
#include <SamplePanelPlugin_WidgetCreator.h>
Inheritance diagram for SamplePanelPlugin_WidgetCreator:
 SamplePanelPlugin_WidgetCreator ()
 Default constructor. More...
 ~SamplePanelPlugin_WidgetCreator ()
 Virtual destructor. More...
virtual void panelTypes (std::set< std::string > &theTypes)
 Returns a container of possible page types, which this creator can process. More...
virtual QWidget * createPanelByType (const std::string &theType, QWidget *theParent, const FeaturePtr &theFeature)
 Create panel control by its type. More...
virtual void pageTypes (std::set< std::string > &theTypes)
 Returns a container of possible page types, which this creator can process The default implementation is empty. More...
virtual void widgetTypes (std::set< std::string > &theTypes)
 Returns a container of possible widget types, which this creator can process. More...
virtual QWidget * createPanelByType (const std::string &theType, QWidget *theParent, const FeaturePtr &theFeature, Config_WidgetAPI *theWidgetApi=0)
virtual ModuleBase_PageBase * createPageByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi)
 Create page by its type The default implementation is empty. More...
virtual ModuleBase_ModelWidget * createWidgetByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi, ModuleBase_IWorkshop *theWorkshop)
 Create widget by its type The default implementation is empty. More...
◆ SamplePanelPlugin_WidgetCreator()
SamplePanelPlugin_WidgetCreator::SamplePanelPlugin_WidgetCreator ( )
◆ ~SamplePanelPlugin_WidgetCreator()
SamplePanelPlugin_WidgetCreator::~SamplePanelPlugin_WidgetCreator ( )
Virtual destructor.
◆ panelTypes()
void SamplePanelPlugin_WidgetCreator::panelTypes ( std::set< std::string > &  theTypes)
theTypesa list of type names
Reimplemented from ModuleBase_IWidgetCreator.
◆ createPanelByType() [1/2]
QWidget * SamplePanelPlugin_WidgetCreator::createPanelByType ( const std::string &  theType,
QWidget *  theParent,
const FeaturePtr &  theFeature
theTypea panel type
theParenta parent widget
theFeaturea feature to fill the panel
created widget or null
◆ pageTypes()
virtual void ModuleBase_IWidgetCreator::pageTypes ( std::set< std::string > &  theTypes)
inlinevirtualinherited
◆ widgetTypes()
virtual void ModuleBase_IWidgetCreator::widgetTypes ( std::set< std::string > &  theTypes)
Reimplemented in CollectionPlugin_WidgetCreator, ParametersPlugin_WidgetCreator, and SamplePanelPlugin_ModelWidgetCreator.
◆ createPanelByType() [2/2]
QWidget * ModuleBase_IWidgetCreator::createPanelByType ( const std::string &  theType,
const FeaturePtr &  theFeature,
Config_WidgetAPI *  theWidgetApi = 0
theTypea panel type
theFeaturea feature modified in the panel
theWidgetApia low-level API for reading xml definitions of widget
◆ createPageByType()
ModuleBase_PageBase * ModuleBase_IWidgetCreator::createPageByType ( const std::string &  theType,
theTypea type
theWidgetApia low-level API for reading xml definitions of widgets
◆ createWidgetByType()
ModuleBase_ModelWidget * ModuleBase_IWidgetCreator::createWidgetByType ( const std::string &  theType,
Config_WidgetAPI *  theWidgetApi,
ModuleBase_IWorkshop *  theWorkshop
theTypea type
theWorkshopa workshop class instance
Reimplemented in CollectionPlugin_WidgetCreator, SamplePanelPlugin_ModelWidgetCreator, and ParametersPlugin_WidgetCreator.
