CollectionPlugin_WidgetCreator Class Reference
Interface to WidgetCreator which can create specific widgets by type. More...
#include <CollectionPlugin_WidgetCreator.h>
Inheritance diagram for CollectionPlugin_WidgetCreator:
 CollectionPlugin_WidgetCreator ()
 Default constructor. More...
 ~CollectionPlugin_WidgetCreator ()
 Virtual destructor. More...
virtual void widgetTypes (std::set< std::string > &theTypes)
 Returns a container of possible page types, which this creator can process. More...
virtual ModuleBase_ModelWidget * createWidgetByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi, ModuleBase_IWorkshop *)
 Create widget by its type The default implementation is empty. More...
virtual void panelTypes (std::set< std::string > &)
 Returns a container of possible page types, which this creator can process The default implementation is empty. More...
virtual void pageTypes (std::set< std::string > &theTypes)
virtual QWidget * createPanelByType (const std::string &theType, QWidget *theParent, const FeaturePtr &theFeature, Config_WidgetAPI *theWidgetApi=0)
 Create panel control by its type. More...
virtual ModuleBase_PageBase * createPageByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi)
 Create page by its type The default implementation is empty. More...
◆ CollectionPlugin_WidgetCreator()
CollectionPlugin_WidgetCreator::CollectionPlugin_WidgetCreator ( )
◆ ~CollectionPlugin_WidgetCreator()
CollectionPlugin_WidgetCreator::~CollectionPlugin_WidgetCreator ( )
Virtual destructor.
◆ widgetTypes()
void CollectionPlugin_WidgetCreator::widgetTypes ( std::set< std::string > &  theTypes)
theTypesa list of type names
Reimplemented from ModuleBase_IWidgetCreator.
◆ createWidgetByType()
ModuleBase_ModelWidget * CollectionPlugin_WidgetCreator::createWidgetByType ( const std::string &  theType,
QWidget *  theParent,
Config_WidgetAPI *  theWidgetApi,
ModuleBase_IWorkshop *  theWorkshop
theTypea type
theParenta parent widget
theDataa low-level API for reading xml definitions of widgets
theWorkshopa current workshop
a created model widget or null
◆ panelTypes()
virtual void ModuleBase_IWidgetCreator::panelTypes ( std::set< std::string > &  )
inlinevirtualinherited
Reimplemented in SamplePanelPlugin_WidgetCreator.
◆ pageTypes()
virtual void ModuleBase_IWidgetCreator::pageTypes ( std::set< std::string > &  theTypes)
◆ createPanelByType()
QWidget * ModuleBase_IWidgetCreator::createPanelByType ( const std::string &  theType,
const FeaturePtr &  theFeature,
Config_WidgetAPI *  theWidgetApi = 0
theTypea panel type
theFeaturea feature modified in the panel
theWidgetApia low-level API for reading xml definitions of widget
created widget or null
◆ createPageByType()
ModuleBase_PageBase * ModuleBase_IWidgetCreator::createPageByType ( const std::string &  theType,
theTypea type
theWidgetApia low-level API for reading xml definitions of widgets
