BuildPlugin_ValidatorBaseForSolids Class Reference
A validator for selection base shapes for solid. More...
#include <BuildPlugin_Validators.h>
Inheritance diagram for BuildPlugin_ValidatorBaseForSolids:
virtual bool isValid (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< std::string > &theArguments, Events_InfoMessage &theError) const
 Returns true if attributes is ok. More...
virtual bool isNotObligatory (std::string theFeature, std::string theAttribute)
 Returns true if the attribute in feature is not obligatory for the feature execution. More...
Allows to select faces closed enough to create a solid.
◆ isValid()
bool BuildPlugin_ValidatorBaseForSolids::isValid ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::list< std::string > &  theArguments,
Events_InfoMessage &  theError
theFeaturethe checked feature.
theArgumentsarguments of the feature.
theErrorerror message.
remove objects of sub-type if objects of correct type is in List, in some cases : Solid builder: faces and shapes shells or solids seleted --> remove faces
Implements ModelAPI_FeatureValidator.
◆ isNotObligatory()
bool ModelAPI_FeatureValidator::isNotObligatory ( std::string  theFeature,
