Class for reading translations from TS files (an XML format). More...
| Config_TSReader (const std::string &theTSFile) | |
| Constructor. More... | |
| const Config_Translator::Translator & | translator () const |
| Returns content of TS file. More... | |
| const Config_Translator::Dictionary & | codecs () const |
| Returns codecs defined in TS files. More... | |
| CONFIG_EXPORT void | readAll () |
| CONFIG_EXPORT xmlNodePtr | findRoot (const std::string theDocumentPath="") |
| CONFIG_EXPORT const char * | encoding () const |
| static CONFIG_EXPORT std::string | resourcesConfigFile () |
| static CONFIG_EXPORT std::string | pluginConfigFile () |
| static CONFIG_EXPORT std::string | findConfigFile (const std::string theFileName, const int theFindIndex=0) |
| Checks all possible paths to configuration file given Uses theFindIndex if several solutions can be found (this is the number of solution to find) More... | |
| virtual void | processNode (xmlNodePtr theNode) |
| Overloaded method. Defines how to process each node. More... | |
| virtual void | cleanup (xmlNodePtr aNode) |
| virtual bool | processChildren (xmlNodePtr aNode) |
| Defines which nodes should be processed recursively. Virtual. The default impl is to read all nodes. More... | |
| void | readRecursively (xmlNodePtr theParent) |
| xmlNodePtr | node (void *theNode) |
| void* -> xmlNodePtr More... | |
| std::string | getNodeName (xmlNodePtr theNode) |
| Gets xml node name. More... | |
| void | storeAttribute (xmlNodePtr theNode, const char *theNodeAttribute, bool doClean=false) |
| Stores an attribute in internal map for later use. More... | |
| std::string | restoreAttribute (xmlNodePtr theNode, const char *theNodeAttribute) |
| Restores an attribute from internal map. More... | |
| std::string | restoreAttribute (const char *theNodeName, const char *theNodeAttribute) |
| bool | cleanupAttribute (xmlNodePtr theNode, const char *theNodeAttribute) |
| Cleanups attribute from cache. More... | |
| bool | cleanupAttribute (const char *theNodeName, const char *theNodeAttribute) |
Protected Attributes | |
| std::string | myDocumentPath |
| Path to the xml document. More... | |
| xmlDocPtr | myXmlDoc |
| Root of the xml document. More... | |
| std::string | myRootFileName |
| name of the root file More... | |
| std::map< std::string, std::string > | myCachedAttributes |
| A map to store all parent's attributes. More... | |
| bool | isFromMemory |
inline |
| theTSFile | name of TS file |
inline |
inline |
protectedvirtual |
Reimplemented from Config_XMLReader.
staticinherited |
Returns a path to resource files (created from ROOT_DIR environment variable)
staticinherited |
Returns a path to the plugins.xml file (created from ROOT_DIR environment variable)
Read all nodes in associated xml file, recursively if processChildren(xmlNode) is true for the xmlNode. For each read node the processNode will be called.
Returns xmlNodePtr to the root of reader's document or NULL if not found. If the path to the document to read is empty, uses myDocumentPath.
staticinherited |
protectedvirtualinherited |
This method gives an ability to finalize processing of a node, when reader is about to leave the node (node and all it's children are processed)
Reimplemented in Config_FeatureReader, and Config_ValidatorReader.
Reimplemented in Config_FeatureReader, Config_ModuleReader, Config_ValidatorReader, and Config_WidgetReader.
protectedinherited |
Calls processNode() for each child (for some - recursively) of the given node.
void* -> xmlNodePtr
Gets xml node name.
Key is "Node_Name:Node_Attribute" and value is getProperty(theNodeAttribute)
The key has from "Node_Name:Node_Attribute"
