| FeaturesAPI_BoundingBox (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_BoundingBox (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theObject) | |
| virtual | ~FeaturesAPI_BoundingBox () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | objectSelected () const |
| object selected More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | myobjectSelected |
explicit |
inlinevirtual |
object selected
protectedinherited |
