ModelHighAPI_Dumper Class Referenceabstract
Dump engine for the model. More...
#include <ModelHighAPI_Dumper.h>
class  DumpStorage
 Storage for the dumped data. More...
class  DumpStorageBuffer
class  DumpStorageGeom
 Process selection attributes to be dumped by geometric properties. More...
class  DumpStorageWeak
 Process selection attributes to be dumped by weak naming. More...
typedef std::shared_ptr< DumpStorage > DumpStoragePtr
 ModelHighAPI_Dumper ()
 Default constructor. More...
void setIsMultiDump (const bool theValue)
 Sets multifile flag value. More...
virtual ~ModelHighAPI_Dumper ()
void addCustomStorage (const DumpStoragePtr &theStorage)
 Add custom storage to collect corresponding dump. More...
void clearCustomStorage ()
 Clear custom storages list. More...
bool process (const std::shared_ptr< ModelAPI_Document > &theDoc, const std::string &theFileName)
 Dump given document into the file. More...
void setDumpDir (const std::string &theDumpDir)
 Keep path to the true dumping directory. More...
std::string getDumpDir () const
 Return path to the true dumping directory. More...
void importModule (const std::string &theModuleName)
 Add module to list of imported modules. More...
const std::string & name (const EntityPtr &theEntity, bool theSaveNotDumped=true, bool theUseEntityName=false, bool theSetIsDumped=false)
 Returns name of specified entity. More...
const std::string & parentName (const FeaturePtr &theFeature)
 Returns name of parent composite feature for specified entity. More...
virtual void dumpParameter (const FeaturePtr &theFeature)=0
 Dump parameter feature only. More...
virtual void dumpFeature (const FeaturePtr &theFeature, const bool theForce=false)=0
 Dump given feature. More...
virtual void dumpFolder (const FolderPtr &theFolder)=0
 Dump folder. More...
void postpone (const EntityPtr &theEntity)
 Set feature postponed until all its dependencies are not dumped. More...
void doNotDumpFeature (const FeaturePtr &theFeature)
 Set a feature that should not be dumped anyway. More...
void dumpSubFeatureNameAndColor (const std::string theSubFeatureGet, const FeaturePtr &theSubFeature)
 Dump sub-feature name and color, without dumping feature creation. More...
virtual std::string attributeGetter (const FeaturePtr &theFeature, const std::string &theAttrName) const =0
 Return name of getter for corresponding attribute. More...
virtual std::string featureWrapper (const FeaturePtr &theFeature) const =0
 Return name of wrapper feature. More...
ModelHighAPI_Dumper & operator<< (const char theChar)
 Dump character. More...
ModelHighAPI_Dumper & operator<< (const char *theString)
 Dump string. More...
ModelHighAPI_Dumper & operator<< (const std::string &theString)
ModelHighAPI_Dumper & operator<< (const std::wstring &theString)
 Dump wstring. More...
ModelHighAPI_Dumper & operator<< (const bool theValue)
 Dump boolean. More...
ModelHighAPI_Dumper & operator<< (const int theValue)
 Dump integer. More...
ModelHighAPI_Dumper & operator<< (const double theValue)
 Dump real. More...
void newline ()
 Print std::endl from Python. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< GeomAPI_Pnt > &thePoint)
 Dump GeomAPI_Pnt in the following form: "GeomAPI_Pnt(X, Y, Z)". More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< GeomAPI_Dir > &theDir)
 Dump GeomAPI_Dir "GeomAPI_Dir(X, Y, Z)". More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< GeomDataAPI_Dir > &theDir)
 Dump GeomDataAPI_Dir in the following form: "X, Y, Z". More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< GeomDataAPI_Point > &thePoint)
 Dump GeomDataAPI_Point in the following form: "X, Y, Z". More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< GeomDataAPI_Point2D > &thePoint)
 Dump GeomDataAPI_Point2D in the following form: "X, Y". More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< GeomDataAPI_Point2DArray > &thePointArray)
 Dump GeomDataAPI_Point2DArray as a list of 2D points. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeBoolean > &theAttrBool)
 Dump AttributeBoolean. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeInteger > &theAttrInt)
 Dump AttributeInteger. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeIntArray > &theArray)
 Dump AttributeIntArray. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeDouble > &theAttrReal)
 Dump AttributeDouble. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeDoubleArray > &theArray)
 Dump AttributeDoubleArray. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeString > &theAttrStr)
 Dump AttributeString. More...
ModelHighAPI_Dumper & operator<< (const FeaturePtr &theEntity)
 Dump name of entity and remember to dump "setName" if the entity has user-defined name. More...
ModelHighAPI_Dumper & operator<< (const FolderPtr &theFolder)
ModelHighAPI_Dumper & operator<< (const ResultPtr &theResult)
 Dump result. More...
ModelHighAPI_Dumper & operator<< (const std::list< ResultPtr > &theResults)
 Dump a list of results. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_Attribute > &theAttr)
 Dump Attribute. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_Object > &theObject)
 Dump Object. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeRefAttr > &theRefAttr)
 Dump AttributeRefAttr. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeRefAttrList > &theRefAttrList)
 Dump AttributeRefAttrList as follows: "[obj1, obj2, obj3, ...]". More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeRefList > &theRefList)
 Dump AttributeRefList as follows: "[obj1, obj2, obj3, ...]". More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeSelection > &theAttrSelect)
 Dump AttributeSelection. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeSelectionList > &theAttrSelList)
 Dump AttributeSelectionList. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeReference > &theReference)
 Dump AttributeReference. More...
ModelHighAPI_Dumper & operator<< (const std::shared_ptr< ModelAPI_AttributeStringArray > &theArray)
 Dump AttributeStringArray. More...
void clearNotDumped ()
 clear list of not dumped entities More...
bool isDumped (const EntityPtr &theEntity) const
 Check the entity is already dumped. More...
bool isDumped (const std::shared_ptr< ModelAPI_AttributeRefAttr > &theRefAttr) const
 Check theRefAttr is already dumped. More...
bool isDumped (const std::shared_ptr< ModelAPI_AttributeRefList > &theRefList) const
 Check all objects in theRefList are already dumped. More...
size_t indexOfFirstNotDumped (const std::shared_ptr< ModelAPI_AttributeRefList > &theRefList) const
 Returns the index of the first object in the list which is not dumped yet. More...
virtual void exportVariables () const
 Export variables names to another module (calls exportVariable implemented in python) More...
virtual void exportVariable (const std::string &, const std::string &) const
 Export one variable name to another module (implemented in python) More...
bool dumpCommentBeforeFeature (const FeaturePtr &theFeature) const
 Returns true if the special comment line to improve the readability should be printed before the feature of the given kind. More...
static void setInstance (ModelHighAPI_Dumper *theDumper)
 Sets instance of a dumper. More...
static ModelHighAPI_Dumper * getInstance ()
 Returns instance of a dumper. More...
void dumpEntitySetName ()
 Dump "setName" command if last entity had user-defined name. More...
std::set< EntityPtr > myNotDumpedEntities
 list of entities, used by other features but not dumped yet More...
Friends
class SketchAPI_Sketch
class ModelHighAPI_Folder
ModelHighAPI_Dumper & operator<< (ModelHighAPI_Dumper &theDumper, std::basic_ostream< char > &(*theEndl)(std::basic_ostream< char > &))
 Dump std::endl. More...
The dumper can be customized by the set of storages (DumpStorage), for example to identify dumped selected objects by their geometrical properties. By default, the dump is executed to store original names of the selected shapes.
◆ ModelHighAPI_Dumper()
ModelHighAPI_Dumper::ModelHighAPI_Dumper ( )
◆ ~ModelHighAPI_Dumper()
ModelHighAPI_Dumper::~ModelHighAPI_Dumper ( )
◆ setInstance()
void ModelHighAPI_Dumper::setInstance ( ModelHighAPI_Dumper *  theDumper)
◆ setIsMultiDump()
void ModelHighAPI_Dumper::setIsMultiDump ( const bool  theValue)
◆ getInstance()
ModelHighAPI_Dumper * ModelHighAPI_Dumper::getInstance ( )
◆ addCustomStorage()
void ModelHighAPI_Dumper::addCustomStorage ( const DumpStoragePtr &  theStorage)
◆ clearCustomStorage()
void ModelHighAPI_Dumper::clearCustomStorage ( )
◆ process()
bool ModelHighAPI_Dumper::process ( const std::shared_ptr< ModelAPI_Document > &  theDoc,
const std::string &  theFileName
true, if succeed
◆ setDumpDir()
void ModelHighAPI_Dumper::setDumpDir ( const std::string &  theDumpDir)
It is used to store image files or any other external files
theDumpDirpath to the true dumping directory
◆ getDumpDir()
std::string ModelHighAPI_Dumper::getDumpDir ( ) const
◆ importModule()
void ModelHighAPI_Dumper::importModule ( const std::string &  theModuleName)
theModuleNamename of the module to be imported
const std::string & ModelHighAPI_Dumper::name ( const EntityPtr &  theEntity,
bool  theSaveNotDumped = true,
bool  theUseEntityName = false,
bool  theSetIsDumped = false
theEntity[in] named entity
theSaveNotDumped[in] if true, the entity should be stored as not dumped (will be dumped automatically)
theUseEntityName[in] if true, the entity name should be used "as is" without changing default name
name of the entity
◆ parentName()
const std::string & ModelHighAPI_Dumper::parentName ( const FeaturePtr &  theFeature)
◆ dumpParameter()
virtual void ModelHighAPI_Dumper::dumpParameter ( const FeaturePtr &  theFeature)
pure virtual
◆ dumpFeature()
virtual void ModelHighAPI_Dumper::dumpFeature ( const FeaturePtr &  theFeature,
const bool  theForce = false
pure virtual
Dump given feature.
◆ dumpFolder()
virtual void ModelHighAPI_Dumper::dumpFolder ( const FolderPtr &  theFolder)
pure virtual
Dump folder.
◆ postpone()
void ModelHighAPI_Dumper::postpone ( const EntityPtr &  theEntity)
The name of the feature is stored anyway.
◆ doNotDumpFeature()
void ModelHighAPI_Dumper::doNotDumpFeature ( const FeaturePtr &  theFeature)
◆ dumpSubFeatureNameAndColor()
void ModelHighAPI_Dumper::dumpSubFeatureNameAndColor ( const std::string  theSubFeatureGet,
const FeaturePtr &  theSubFeature
Used for features which creates sub-features in their execute method.
theSubFeatureGet[in] method for getting sub-feature (e.g. "Feature_1.subFeature(0)")
theSubFeature[in] sub-feature
◆ attributeGetter()
virtual std::string ModelHighAPI_Dumper::attributeGetter ( const FeaturePtr &  theFeature,
const std::string &  theAttrName
pure virtual
◆ featureWrapper()
virtual std::string ModelHighAPI_Dumper::featureWrapper ( const FeaturePtr &  theFeature) const
pure virtual
◆ operator<<() [1/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const char  theChar)
Dump character.
◆ operator<<() [2/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const char *  theString)
Dump string.
◆ operator<<() [3/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::string &  theString)
Dump string.
◆ operator<<() [4/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::wstring &  theString)
Dump wstring.
◆ operator<<() [5/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const bool  theValue)
Dump boolean.
◆ operator<<() [6/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const int  theValue)
Dump integer.
◆ operator<<() [7/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const double  theValue)
Dump real.
◆ newline()
void ModelHighAPI_Dumper::newline ( )
◆ operator<<() [8/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint)
◆ operator<<() [9/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< GeomAPI_Dir > &  theDir)
◆ operator<<() [10/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< GeomDataAPI_Dir > &  theDir)
◆ operator<<() [11/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< GeomDataAPI_Point > &  thePoint)
◆ operator<<() [12/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< GeomDataAPI_Point2D > &  thePoint)
◆ operator<<() [13/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< GeomDataAPI_Point2DArray > &  thePointArray)
◆ operator<<() [14/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeBoolean > &  theAttrBool)
◆ operator<<() [15/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeInteger > &  theAttrInt)
◆ operator<<() [16/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeIntArray > &  theArray)
◆ operator<<() [17/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeDouble > &  theAttrReal)
◆ operator<<() [18/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeDoubleArray > &  theArray)
◆ operator<<() [19/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeString > &  theAttrStr)
◆ operator<<() [20/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const FeaturePtr &  theEntity)
◆ operator<<() [21/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const FolderPtr &  theFolder)
Dump folder.
◆ operator<<() [22/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const ResultPtr &  theResult)
Dump result.
◆ operator<<() [23/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::list< ResultPtr > &  theResults)
◆ operator<<() [24/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_Attribute > &  theAttr)
Dump Attribute.
◆ operator<<() [25/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_Object > &  theObject)
Dump Object.
◆ operator<<() [26/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeRefAttr > &  theRefAttr)
◆ operator<<() [27/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeRefAttrList > &  theRefAttrList)
◆ operator<<() [28/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeRefList > &  theRefList)
◆ operator<<() [29/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeSelection > &  theAttrSelect)
◆ operator<<() [30/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeSelectionList > &  theAttrSelList)
◆ operator<<() [31/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeReference > &  theReference)
◆ operator<<() [32/32]
ModelHighAPI_Dumper & ModelHighAPI_Dumper::operator<< ( const std::shared_ptr< ModelAPI_AttributeStringArray > &  theArray)
◆ clearNotDumped()
void ModelHighAPI_Dumper::clearNotDumped ( )
◆ isDumped() [1/3]
bool ModelHighAPI_Dumper::isDumped ( const EntityPtr &  theEntity) const
◆ isDumped() [2/3]
bool ModelHighAPI_Dumper::isDumped ( const std::shared_ptr< ModelAPI_AttributeRefAttr > &  theRefAttr) const
◆ isDumped() [3/3]
bool ModelHighAPI_Dumper::isDumped ( const std::shared_ptr< ModelAPI_AttributeRefList > &  theRefList) const
◆ indexOfFirstNotDumped()
size_t ModelHighAPI_Dumper::indexOfFirstNotDumped ( const std::shared_ptr< ModelAPI_AttributeRefList > &  theRefList) const
◆ exportVariables()
void ModelHighAPI_Dumper::exportVariables ( ) const
◆ exportVariable()
virtual void ModelHighAPI_Dumper::exportVariable ( const std::string &  ,
const std::string &
◆ dumpCommentBeforeFeature()
bool ModelHighAPI_Dumper::dumpCommentBeforeFeature ( const FeaturePtr &  theFeature) const
◆ dumpEntitySetName()
void ModelHighAPI_Dumper::dumpEntitySetName ( )
◆ operator<<
ModelHighAPI_Dumper & operator<< ( ModelHighAPI_Dumper &  theDumper,
std::basic_ostream< char > &(*)(std::basic_ostream< char > &)  theEndl
friend
Dump std::endl.
◆ myNotDumpedEntities
std::set<EntityPtr> ModelHighAPI_Dumper::myNotDumpedEntities
