FiltersAPI_Feature Class Reference
Interface for the list of filters. More...
#include <FiltersAPI_Feature.h>
Inheritance diagram for FiltersAPI_Feature:
 FiltersAPI_Feature (const std::shared_ptr< ModelAPI_Feature > &theFeature)
virtual ~FiltersAPI_Feature ()
virtual std::string getID ()
void setFilters (const std::list< FilterAPIPtr > &theFilters)
 assign list of filters More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
◆ FiltersAPI_Feature()
FiltersAPI_Feature::FiltersAPI_Feature ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ~FiltersAPI_Feature()
FiltersAPI_Feature::~FiltersAPI_Feature ( )
◆ setFilters()
void FiltersAPI_Feature::setFilters ( const std::list< FilterAPIPtr > &  theFilters)
◆ dump()
void FiltersAPI_Feature::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
