GDMLAPI_ConeSegment Class Reference
Inheritance diagram for GDMLAPI_ConeSegment:
 GDMLAPI_ConeSegment (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 GDMLAPI_ConeSegment (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Double &theRMin1, const ModelHighAPI_Double &theRMax1, const ModelHighAPI_Double &theRMin2, const ModelHighAPI_Double &theRMax2, const ModelHighAPI_Double &theZ, const ModelHighAPI_Double &theStartPhi, const ModelHighAPI_Double &theDeltaPhi)
virtual ~GDMLAPI_ConeSegment ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmin1 () const
 Inner radius at base of cone. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmax1 () const
 Outer radius at base of cone. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmin2 () const
 Inner radius at top of cone. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > rmax2 () const
 Outer radius at top of cone. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > z () const
 Height of the cone segment. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > startphi () const
 Start angle of the segment. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > deltaphi () const
 Angle of the segment. More...
void setAttributes (const ModelHighAPI_Double &theRMin1, const ModelHighAPI_Double &theRMax1, const ModelHighAPI_Double &theRMin2, const ModelHighAPI_Double &theRMax2, const ModelHighAPI_Double &theZ, const ModelHighAPI_Double &theStartPhi, const ModelHighAPI_Double &theDeltaPhi)
 Set dimensions. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeDouble > myrmin1
std::shared_ptr< ModelAPI_AttributeDouble > myrmax1
std::shared_ptr< ModelAPI_AttributeDouble > myrmin2
std::shared_ptr< ModelAPI_AttributeDouble > myrmax2
std::shared_ptr< ModelAPI_AttributeDouble > myz
std::shared_ptr< ModelAPI_AttributeDouble > mystartphi
std::shared_ptr< ModelAPI_AttributeDouble > mydeltaphi
◆ GDMLAPI_ConeSegment() [1/2]
GDMLAPI_ConeSegment::GDMLAPI_ConeSegment ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ GDMLAPI_ConeSegment() [2/2]
GDMLAPI_ConeSegment::GDMLAPI_ConeSegment ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Double &  theRMin1,
const ModelHighAPI_Double &  theRMax1,
const ModelHighAPI_Double &  theRMin2,
const ModelHighAPI_Double &  theRMax2,
const ModelHighAPI_Double &  theZ,
const ModelHighAPI_Double &  theStartPhi,
const ModelHighAPI_Double &  theDeltaPhi
explicit
◆ ~GDMLAPI_ConeSegment()
GDMLAPI_ConeSegment::~GDMLAPI_ConeSegment ( )
◆ rmin1()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_ConeSegment::rmin1 ( ) const
◆ rmax1()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_ConeSegment::rmax1 ( ) const
◆ rmin2()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_ConeSegment::rmin2 ( ) const
◆ rmax2()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_ConeSegment::rmax2 ( ) const
◆ z()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_ConeSegment::z ( ) const
◆ startphi()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_ConeSegment::startphi ( ) const
◆ deltaphi()
virtual std::shared_ptr< ModelAPI_AttributeDouble > GDMLAPI_ConeSegment::deltaphi ( ) const
◆ setAttributes()
void GDMLAPI_ConeSegment::setAttributes ( const ModelHighAPI_Double &  theRMin1,
Set dimensions.
◆ dump()
void GDMLAPI_ConeSegment::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
