GeomAPI_Box Class Reference
Box in 3D. More...
#include <GeomAPI_Box.h>
Inheritance diagram for GeomAPI_Box:
GEOMAPI_EXPORT GeomAPI_Box (const std::shared_ptr< GeomAPI_Ax3 > &theCorner, const double theWidth, const double theDepth, const double theHeight)
 Creation of torus defined by center point, direction, major and minor radii. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Ax3 > axes () const
 Return axes of the box. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > corner () const
 Return base corner of the box. More...
GEOMAPI_EXPORT double width () const
 Return width of the box. More...
GEOMAPI_EXPORT double depth () const
 Return depth of the box. More...
GEOMAPI_EXPORT double height () const
 Return height of the box. More...
GEOMAPI_EXPORT bool isAxesAligned () const
 Return true is the box is aligned in main axes. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
Box in 3D.
◆ GeomAPI_Box()
GeomAPI_Box::GeomAPI_Box ( const std::shared_ptr< GeomAPI_Ax3 > &  theCorner,
◆ axes()
std::shared_ptr< GeomAPI_Ax3 > GeomAPI_Box::axes ( ) const
◆ corner()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Box::corner ( ) const
◆ width()
double GeomAPI_Box::width ( ) const
◆ depth()
double GeomAPI_Box::depth ( ) const
◆ height()
double GeomAPI_Box::height ( ) const
◆ isAxesAligned()
bool GeomAPI_Box::isAxesAligned ( ) const
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
