Circle in 3D.
More...
#include <GeomAPI_Circ.h>
| GEOMAPI_EXPORT | GeomAPI_Circ (const std::shared_ptr< GeomAPI_Ax2 > theAx2, const double theRadius) |
| | Constructs a circle of radius Radius, where theAx2 locates the circle and defines its orientation in 3D space such that:
. More...
| GEOMAPI_EXPORT | GeomAPI_Circ (const std::shared_ptr< GeomAPI_Pnt > &theCenter, const std::shared_ptr< GeomAPI_Dir > &theDir, double theRadius) |
| | Creation of circle defined by center point, direction and circle radius. More...
| GEOMAPI_EXPORT | GeomAPI_Circ (const GeomCurvePtr &theCurve) |
| | Creation of circle defined by a curve. More...
| GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > | center () const |
| | Return center of the circle. More...
| GEOMAPI_EXPORT double | radius () const |
| | Return radius of the circle. More...
| GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > | normal () const |
| | Return orthogonal direction to the circle's plane. More...
| GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > | project (const std::shared_ptr< GeomAPI_Pnt > &thePoint) const |
| | Project point on circle. More...
| GEOMAPI_EXPORT const bool | parameter (const std::shared_ptr< GeomAPI_Pnt > thePoint, const double theTolerance, double &theParameter) const |
| | Computes the parameter of a given point on a circle. More...
| template<class T > |
| T * | implPtr () |
| | Returns the pointer to the impl. More...
| const T & | impl () const |
| | Returns the reference object of the impl. More...
| | Updates the impl (deletes the old one) More...
| | Returns true if the impl is empty. More...
◆ GeomAPI_Circ() [1/3]
| GeomAPI_Circ::GeomAPI_Circ |
const std::shared_ptr< GeomAPI_Ax2 > |
theAx2, |
const double |
theRadius |
- the center of the circle is the origin of theAx2;
- the origin, "X Direction" and "Y Direction" of theAx2 define the plane of the circle;
- theAx2 is the local coordinate system of the circle.
Note: It is possible to create a circle where Radius is equal to 0.0. raised if Radius < 0.
◆ GeomAPI_Circ() [2/3]
const std::shared_ptr< GeomAPI_Pnt > & |
theCenter, |
const std::shared_ptr< GeomAPI_Dir > & |
theDir, |
double |
theRadius |
◆ GeomAPI_Circ() [3/3]
const GeomCurvePtr & |
theCurve | ) |
◆ center()
| const std::shared_ptr< GeomAPI_Pnt > GeomAPI_Circ::center |
const |
◆ radius()
| double GeomAPI_Circ::radius |
const |
◆ normal()
| std::shared_ptr< GeomAPI_Dir > GeomAPI_Circ::normal |
const |
◆ project()
| const std::shared_ptr< GeomAPI_Pnt > GeomAPI_Circ::project |
thePoint | ) |
const |
◆ parameter()
| const bool GeomAPI_Circ::parameter |
thePoint, |
const double |
theTolerance, |
double & |
theParameter |
| const |
The point must be located either on the circle itself or relatively to the latter at a distance less than the tolerance value. Return FALSE if the point is beyond the tolerance limit or if computation fails. Max Tolerance value is currently limited to 1.e-4
- Parameters
| [in] | thePoint | point of origin. |
| [in] | theTolerance | tolerance of computation. |
| [out] | theParameter | resulting parameter. |
◆ implPtr() [1/2]
template<class T >
| T * GeomAPI_Interface::implPtr |
inlineinherited |
◆ implPtr() [2/2]
template<class T >
| const T * GeomAPI_Interface::implPtr |
const |
inlineinherited |
◆ impl()
template<class T >
| const T & GeomAPI_Interface::impl |
const |
inlineinherited |
◆ setImpl()
template<class T >
| void GeomAPI_Interface::setImpl |
T * |
theImpl | ) |
inlineinherited |
◆ empty()
| bool GeomAPI_Interface::empty |
const |
