GeomAPI_DataMapOfShapeMapOfShapes Class Reference
DataMap of Shape - Map of Shapes defined by TopoDS_Shapes. More...
#include <GeomAPI_DataMapOfShapeMapOfShapes.h>
Inheritance diagram for GeomAPI_DataMapOfShapeMapOfShapes:
class  iterator
typedef iterator const_iterator
GEOMAPI_EXPORT GeomAPI_DataMapOfShapeMapOfShapes ()
 Constructor.Creates empty map. More...
GEOMAPI_EXPORT bool bind (const std::shared_ptr< GeomAPI_Shape > theKey, const ListOfShape &theItems)
 Binds list of shapes to the key shape. More...
GEOMAPI_EXPORT bool add (const std::shared_ptr< GeomAPI_Shape > theKey, const std::shared_ptr< GeomAPI_Shape > theItem)
 Adds item to the map bounded to the key. More...
GEOMAPI_EXPORT bool isBound (const std::shared_ptr< GeomAPI_Shape > theKey) const
GEOMAPI_EXPORT bool find (const std::shared_ptr< GeomAPI_Shape > theKey, ListOfShape &theItems) const
GEOMAPI_EXPORT bool unBind (const std::shared_ptr< GeomAPI_Shape > theKey)
 Undinds shapes from theKey. More...
GEOMAPI_EXPORT void clear ()
 Clears map. More...
GEOMAPI_EXPORT int size () const
GEOMAPI_EXPORT iterator begin ()
GEOMAPI_EXPORT const_iterator begin () const
GEOMAPI_EXPORT iterator end ()
GEOMAPI_EXPORT const_iterator end () const
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_DataMapOfShapeMapOfShapes()
GeomAPI_DataMapOfShapeMapOfShapes::GeomAPI_DataMapOfShapeMapOfShapes ( )
◆ bind()
bool GeomAPI_DataMapOfShapeMapOfShapes::bind ( const std::shared_ptr< GeomAPI_Shape >  theKey,
const ListOfShape &  theItems
[in]theKeykey shape.
[in]theItemslist of shapes. If shapes have duplications in list only one will be stored.
true if items bound successfully.
◆ add()
bool GeomAPI_DataMapOfShapeMapOfShapes::add ( const std::shared_ptr< GeomAPI_Shape >  theKey,
[in]theItemitem shape.
true if item bounded successfully. False if it is already bound.
◆ isBound()
bool GeomAPI_DataMapOfShapeMapOfShapes::isBound ( const std::shared_ptr< GeomAPI_Shape >  theKey) const
true if theKey is stored in the map.
◆ find()
bool GeomAPI_DataMapOfShapeMapOfShapes::find ( const std::shared_ptr< GeomAPI_Shape >  theKey,
list of shapes bounded to theKey.
◆ unBind()
bool GeomAPI_DataMapOfShapeMapOfShapes::unBind ( const std::shared_ptr< GeomAPI_Shape >  theKey)
◆ clear()
void GeomAPI_DataMapOfShapeMapOfShapes::clear ( )
Clears map.
◆ size()
int GeomAPI_DataMapOfShapeMapOfShapes::size ( ) const
size of map.
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
