GeomAPI_Ellipse Class Reference
Ellipse in 3D. More...
#include <GeomAPI_Ellipse.h>
Inheritance diagram for GeomAPI_Ellipse:
GEOMAPI_EXPORT GeomAPI_Ellipse ()
 Constructs an empty ellipse. More...
GEOMAPI_EXPORT GeomAPI_Ellipse (const std::shared_ptr< GeomAPI_Ax2 > &theAx2, double theMajorRadius, double theMinorRadius)
 Constructs an ellipse with major and minor radiuses, where theAx2 locates the ellipse and defines its orientation in 3D space such that:
. More...
GEOMAPI_EXPORT GeomAPI_Ellipse (std::shared_ptr< GeomAPI_Curve > theCurve)
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > center () const
 Returns center of the ellipse. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > firstFocus () const
 Returns first focus of the ellipse. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > secondFocus () const
 Returns second focus of the ellipse. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > normal () const
 Return orthogonal direction to the ellipse's plane. More...
GEOMAPI_EXPORT double minorRadius () const
 Returns minor radius of the ellipse. More...
GEOMAPI_EXPORT double majorRadius () const
 Returns major radius of the ellipse. More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > project (const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
 Project point on ellipse. More...
GEOMAPI_EXPORT const bool parameter (const std::shared_ptr< GeomAPI_Pnt > thePoint, const double theTolerance, double &theParameter) const
 Computes the parameter of a given point on an ellipse. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
Ellipse in 3D.
◆ GeomAPI_Ellipse() [1/2]
GEOMAPI_EXPORT GeomAPI_Ellipse::GeomAPI_Ellipse ( )
◆ GeomAPI_Ellipse() [2/2]
GeomAPI_Ellipse::GeomAPI_Ellipse ( const std::shared_ptr< GeomAPI_Ax2 > &  theAx2,
  • the center of the circle is the origin of theAx2;
  • the origin, "X Direction" and "Y Direction" of theAx2 define the plane of the circle;
  • theAx2 is the local coordinate system of the circle.
    Note: It is possible to create a circle where Radius is equal to 0.0. raised if Radius < 0.
◆ center()
std::shared_ptr< GeomAPI_Pnt > GeomAPI_Ellipse::center ( ) const
◆ firstFocus()
GeomPointPtr GeomAPI_Ellipse::firstFocus ( ) const
◆ secondFocus()
GeomPointPtr GeomAPI_Ellipse::secondFocus ( ) const
◆ normal()
std::shared_ptr< GeomAPI_Dir > GeomAPI_Ellipse::normal ( ) const
◆ minorRadius()
double GeomAPI_Ellipse::minorRadius ( ) const
◆ majorRadius()
double GeomAPI_Ellipse::majorRadius ( ) const
◆ project()
const std::shared_ptr< GeomAPI_Pnt > GeomAPI_Ellipse::project ( const std::shared_ptr< GeomAPI_Pnt > &  thePoint) const
◆ parameter()
const bool GeomAPI_Ellipse::parameter ( const std::shared_ptr< GeomAPI_Pnt >  thePoint,
double &  theParameter
The point must be located either on the circle itself or relatively to the latter at a distance less than the tolerance value. Return FALSE if the point is beyond the tolerance limit or if computation fails. Max Tolerance value is currently limited to 1.e-4
[in]thePointpoint of origin.
[in]theTolerancetolerance of computation.
[out]theParameterresulting parameter.
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
