GeomAPI_ShapeExplorer Class Reference
This class is used to explore subshapes on shape. More...
#include <GeomAPI_ShapeExplorer.h>
Inheritance diagram for GeomAPI_ShapeExplorer:
GEOMAPI_EXPORT GeomAPI_ShapeExplorer ()
 Default constructor. Creates an empty explorer, becomes useful after Init. More...
GEOMAPI_EXPORT GeomAPI_ShapeExplorer (const std::shared_ptr< GeomAPI_Shape > &theShape, const GeomAPI_Shape::ShapeType toFind, const GeomAPI_Shape::ShapeType toAvoid=GeomAPI_Shape::SHAPE)
 Constructs an explorer to search on theShape, for shapes of type toFind, that are not part of a shape toAvoid. More...
GEOMAPI_EXPORT void init (const std::shared_ptr< GeomAPI_Shape > &theShape, const GeomAPI_Shape::ShapeType toFind, const GeomAPI_Shape::ShapeType toAvoid=GeomAPI_Shape::SHAPE)
 Resets this explorer. More...
GEOMAPI_EXPORT bool more () const
GEOMAPI_EXPORT void next ()
 Moves to the next Shape in the exploration or do nothing if there are no more shapes to explore. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > current ()
GEOMAPI_EXPORT void reinit ()
 Reinitialize the exploration with the original arguments. More...
GEOMAPI_EXPORT int depth () const
GEOMAPI_EXPORT void clear ()
 Clears the content of the explorer. It will return False on more(). More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_ShapeExplorer() [1/2]
GeomAPI_ShapeExplorer::GeomAPI_ShapeExplorer ( )
◆ GeomAPI_ShapeExplorer() [2/2]
GeomAPI_ShapeExplorer::GeomAPI_ShapeExplorer ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
const GeomAPI_Shape::ShapeType  toAvoid = GeomAPI_Shape::SHAPE
If the shape toAvoid is equal to GeomAPI_SHape::SHAPE, or if it is the same as, or less complex than the shape toFind it has no effect on the search.
[in]theShapeshape to explore.
[in]toFindshape type to find.
[in]toAvoidshape type to avoid.
◆ init()
void GeomAPI_ShapeExplorer::init ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
It is initialized to search on theShape, for shapes of type toFind, that are not part of a shape toAvoid. If the shape toAvoid is equal to GeomAPI_SHape::SHAPE, or if it is the same as, or less complex than the shape toFind it has no effect on the search.
◆ more()
bool GeomAPI_ShapeExplorer::more ( ) const
true if there are more shapes in the exploration.
◆ next()
void GeomAPI_ShapeExplorer::next ( )
◆ current()
std::shared_ptr< GeomAPI_Shape > GeomAPI_ShapeExplorer::current ( )
the current shape in the exploration or empty pointer if this explorer has no more shapes to explore.
◆ reinit()
void GeomAPI_ShapeExplorer::reinit ( )
◆ depth()
int GeomAPI_ShapeExplorer::depth ( ) const
the current depth of the exploration. 0 is the shape to explore itself.
◆ clear()
void GeomAPI_ShapeExplorer::clear ( )
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
