Allows to create vertex-shapes by different parameters. More...
#include <GeomAlgoAPI_PointBuilder.h>
| static std::shared_ptr< GeomAPI_Vertex > | vertex (const std::shared_ptr< GeomAPI_Pnt > thePoint) |
| Creates a vertex by point. More... | |
| static std::shared_ptr< GeomAPI_Vertex > | vertex (const double theX, const double theY, const double theZ) |
| Creates a vertex by point coordinates. More... | |
| static std::shared_ptr< GeomAPI_Vertex > | vertexOnEdge (const std::shared_ptr< GeomAPI_Edge > theEdge, const double theValue, const bool theIsPercent=false, const bool theIsReverse=false) |
| Creates vertex by edge and distance on it. More... | |
| static std::shared_ptr< GeomAPI_Vertex > | vertexByProjection (const std::shared_ptr< GeomAPI_Vertex > theVertex, const std::shared_ptr< GeomAPI_Edge > theEdge) |
| Creates vertex by projection another vertex on edge. More... | |
| static std::shared_ptr< GeomAPI_Vertex > | vertexByProjection (const std::shared_ptr< GeomAPI_Vertex > theVertex, const std::shared_ptr< GeomAPI_Face > theFace) |
| Creates vertex by projection another vertex on plane. More... | |
| static std::shared_ptr< GeomAPI_Vertex > | vertexByIntersection (const std::shared_ptr< GeomAPI_Edge > theEdge1, const std::shared_ptr< GeomAPI_Edge > theEdge2) |
| Creates vertex by intersection two coplanar lines. More... | |
| static std::shared_ptr< GeomAPI_Pnt > | point (const std::shared_ptr< GeomAPI_Shape > theVertex) |
| Return point by shape vertex. More... | |
static |
static |
static |
| [in] | theEdge | edge. |
| [in] | theValue | distance value. |
| [in] | theIsPercent | if true theValue will be treated as a percentage of theEdge total length. |
| [in] | theIsReverse | if true the distance will be measured from the edge end point. |
static |
| [in] | theVertex | vertex to project. |
| [in] | theEdge | edge for projection. |
static |
| [in] | theFace | face for projection. Should be planar. |
static |
| [in] | theEdge1 | first linear edge. |
| [in] | theEdge2 | second linear edge. |
static |
