ModelAPI_Session Class Referenceabstract
Object that knows (from the initial XML file) which plugin contains which feature, loads and stores reference to loaded plugins by the feature functionality request. More...
#include <ModelAPI_Session.h>
Inheritance diagram for ModelAPI_Session:
virtual bool load (const char *theFileName)=0
 Loads the OCAF document from the file. More...
virtual bool isLoading ()
 Returns true if a loading process is performed (so, no need to react on a new part creation) More...
virtual bool save (const char *theFileName, std::list< std::string > &theResults, bool isBackup=false)=0
 Saves the OCAF document to the file. More...
virtual void closeAll ()=0
 Closes all documents. More...
virtual void startOperation (const std::string &theId="", const bool theAttachedToNested=false)=0
 Starts a new operation (opens a transaction) More...
virtual void finishOperation ()=0
 Finishes the previously started operation (closes the transaction) More...
virtual void abortOperation ()=0
 Aborts the operation. More...
virtual bool isOperation ()=0
 Returns true if operation has been started, but not yet finished or aborted. More...
virtual bool isModified ()=0
 Returns true if document was modified (since creation/opening) More...
virtual bool canUndo ()=0
 Returns True if there are available Undos. More...
virtual void undo ()=0
 Undoes last operation. More...
virtual bool canRedo ()=0
 Returns True if there are available Redos. More...
virtual void redo ()=0
 Redoes last operation. More...
virtual std::list< std::string > undoList ()=0
 Returns stack of performed operations (from last to first) More...
virtual std::list< std::string > redoList ()=0
 Returns stack of rolled back operations (from last rolled back to first) More...
virtual void clearUndoRedo ()=0
 Clears undo and redo lists of all documents in the session. More...
virtual void registerPlugin (ModelAPI_Plugin *thePlugin)=0
 Registers the plugin that creates features. More...
virtual bool checkLicense (const std::string &thePluginName)=0
 Verifies the license for the plugin is valid. More...
virtual std::shared_ptr< ModelAPI_Document > moduleDocument ()=0
 Returns the root document of the application (that may contains sub-documents) More...
virtual std::shared_ptr< ModelAPI_Document > document (int theDocID)=0
 Returns the document by ID. Returns null if no such document. More...
virtual bool hasModuleDocument ()=0
 Return true if root document has been already created. More...
virtual std::shared_ptr< ModelAPI_Document > activeDocument ()=0
 Returns the current document that used for current work in the application. More...
virtual void setActiveDocument (std::shared_ptr< ModelAPI_Document > theDoc, bool theSendSignal=true)=0
 Defines the current document that used for current work in the application. More...
virtual std::list< std::shared_ptr< ModelAPI_Document > > allOpenedDocuments ()=0
 Returns all the opened documents of the session (without postponed) More...
virtual bool isLoadByDemand (const std::wstring theDocID, const int theDocIndex)=0
 Returns true if document is not loaded yet. More...
virtual std::shared_ptr< ModelAPI_Document > copy (std::shared_ptr< ModelAPI_Document > theSource, const int theDestID)=0
 Copies the document to the new one with the given id. More...
virtual ModelAPI_ValidatorsFactory * validators ()=0
 Returns the validators factory: the only one instance per application. More...
virtual ModelAPI_FiltersFactory * filters ()=0
 Returns the filters factory: the only one instance per application. More...
virtual ~ModelAPI_Session ()
 To virtually destroy the fields of successors. More...
virtual int transactionID ()=0
 Returns the global identifier of the current transaction (needed for the update algo) More...
virtual bool isAutoUpdateBlocked ()=0
 Returns true if auto-update in the application is blocked. More...
virtual void blockAutoUpdate (const bool theBlock)=0
 Set state of the auto-update of features result in the application. More...
static std::shared_ptr< ModelAPI_Session > get ()
 Returns the real implementation (the alone instance per application) of the plugin manager. More...
static void setSession (std::shared_ptr< ModelAPI_Session > theManager)
 Sets the session interface implementation (once per application launch) More...
bool myIsLoading
 keeps the state of the loading of the document More...
◆ ~ModelAPI_Session()
virtual ModelAPI_Session::~ModelAPI_Session ( )
◆ get()
std::shared_ptr< ModelAPI_Session > ModelAPI_Session::get ( )
◆ load()
virtual bool ModelAPI_Session::load ( const char *  theFileName)
pure virtual
theFileNamefull name of the file to load
true if file was loaded successfully
Implemented in Model_Session.
◆ isLoading()
virtual bool ModelAPI_Session::isLoading ( )
◆ save()
virtual bool ModelAPI_Session::save ( const char *  theFileName,
std::list< std::string > &  theResults,
bool  isBackup = false
pure virtual
theFileNamefull name of the file to store
theResultsthe result full file names that were stored by "save"
true if file was stored successfully
◆ closeAll()
virtual void ModelAPI_Session::closeAll ( )
pure virtual
◆ startOperation()
virtual void ModelAPI_Session::startOperation ( const std::string &  theId = "",
const bool  theAttachedToNested = false
pure virtual
theIdof operation for history (optional)
theAttachedToNestedif it is true, it means that this transaction is attached to the nested where it is located and will be committed on the next commit with the nested
◆ finishOperation()
virtual void ModelAPI_Session::finishOperation ( )
pure virtual
◆ abortOperation()
virtual void ModelAPI_Session::abortOperation ( )
pure virtual
◆ isOperation()
virtual bool ModelAPI_Session::isOperation ( )
pure virtual
◆ isModified()
virtual bool ModelAPI_Session::isModified ( )
pure virtual
◆ canUndo()
virtual bool ModelAPI_Session::canUndo ( )
pure virtual
◆ undo()
virtual void ModelAPI_Session::undo ( )
pure virtual
◆ canRedo()
virtual bool ModelAPI_Session::canRedo ( )
pure virtual
◆ redo()
virtual void ModelAPI_Session::redo ( )
pure virtual
◆ undoList()
virtual std::list< std::string > ModelAPI_Session::undoList ( )
pure virtual
◆ redoList()
virtual std::list< std::string > ModelAPI_Session::redoList ( )
pure virtual
◆ clearUndoRedo()
virtual void ModelAPI_Session::clearUndoRedo ( )
pure virtual
◆ registerPlugin()
virtual void ModelAPI_Session::registerPlugin ( ModelAPI_Plugin *  thePlugin)
pure virtual
It is obligatory for each plugin to call this function on loading to be found by the plugin manager on call of the feature)
◆ checkLicense()
virtual bool ModelAPI_Session::checkLicense ( const std::string &  thePluginName)
pure virtual
◆ moduleDocument()
virtual std::shared_ptr< ModelAPI_Document > ModelAPI_Session::moduleDocument ( )
pure virtual
◆ document()
virtual std::shared_ptr< ModelAPI_Document > ModelAPI_Session::document ( int  theDocID)
pure virtual
◆ hasModuleDocument()
virtual bool ModelAPI_Session::hasModuleDocument ( )
pure virtual
◆ activeDocument()
virtual std::shared_ptr< ModelAPI_Document > ModelAPI_Session::activeDocument ( )
pure virtual
◆ setActiveDocument()
virtual void ModelAPI_Session::setActiveDocument ( std::shared_ptr< ModelAPI_Document >  theDoc,
bool  theSendSignal = true
pure virtual
◆ allOpenedDocuments()
virtual std::list< std::shared_ptr< ModelAPI_Document > > ModelAPI_Session::allOpenedDocuments ( )
pure virtual
◆ isLoadByDemand()
virtual bool ModelAPI_Session::isLoadByDemand ( const std::wstring  theDocID,
pure virtual
◆ copy()
virtual std::shared_ptr< ModelAPI_Document > ModelAPI_Session::copy ( std::shared_ptr< ModelAPI_Document >  theSource,
const int  theDestID
pure virtual
◆ validators()
virtual ModelAPI_ValidatorsFactory * ModelAPI_Session::validators ( )
pure virtual
◆ filters()
virtual ModelAPI_FiltersFactory * ModelAPI_Session::filters ( )
pure virtual
◆ transactionID()
virtual int ModelAPI_Session::transactionID ( )
pure virtual
◆ isAutoUpdateBlocked()
virtual bool ModelAPI_Session::isAutoUpdateBlocked ( )
pure virtual
◆ blockAutoUpdate()
virtual void ModelAPI_Session::blockAutoUpdate ( const bool  theBlock)
pure virtual
◆ setSession()
void ModelAPI_Session::setSession ( std::shared_ptr< ModelAPI_Session >  theManager)
staticprotected
◆ myIsLoading
bool ModelAPI_Session::myIsLoading
