Model_Session Class Reference
Object that knows (from the initial XML file) which plugin contains which feature, loads and stores reference to loaded plugins by the feature functionality request. More...
#include <Model_Session.h>
Inheritance diagram for Model_Session:
virtual bool load (const char *theFileName)
 Loads the OCAF document from the file. More...
virtual bool save (const char *theFileName, std::list< std::string > &theResults, bool doBackup=false)
 Saves the OCAF document to the file. More...
virtual void closeAll ()
 Closes all documents. More...
virtual void startOperation (const std::string &theId="", const bool theAttachedToNested=false)
 Starts a new operation (opens a transaction) More...
virtual void finishOperation ()
 Finishes the previously started operation (closes the transaction) More...
 Aborts the operation. More...
virtual bool isOperation ()
 Returns true if operation has been started, but not yet finished or aborted. More...
virtual bool isModified ()
 Returns true if document was modified (since creation/opening) More...
virtual bool canUndo ()
 Returns True if there are available Undos. More...
virtual void undo ()
 Undoes last operation. More...
virtual bool canRedo ()
 Returns True if there are available Redos. More...
virtual void redo ()
 Redoes last operation. More...
virtual std::list< std::string > undoList ()
 Returns stack of performed operations. More...
virtual std::list< std::string > redoList ()
 Returns stack of rolled back operations. More...
virtual void clearUndoRedo ()
 Clears undo and redo lists of all documents in the session. More...
virtual std::shared_ptr< ModelAPI_Document > moduleDocument ()
 Returns the root document of the application (that may contains sub-documents) More...
virtual std::shared_ptr< ModelAPI_Document > document (int theDocID)
 Returns the document by ID, loads if not loaded yet. Returns null if no such document. More...
virtual bool hasModuleDocument ()
 Return true if root document has been already created. More...
virtual std::shared_ptr< ModelAPI_Document > activeDocument ()
 Returns the current document that used for current work in the application. More...
virtual void setActiveDocument (std::shared_ptr< ModelAPI_Document > theDoc, bool theSendSignal=true)
 Defines the current document that used for current work in the application. More...
virtual std::list< std::shared_ptr< ModelAPI_Document > > allOpenedDocuments ()
 Returns all the opened documents of the session (without postponed) More...
virtual bool isLoadByDemand (const std::wstring theDocID, const int theDocIndex)
 Returns true if document is not loaded yet. More...
virtual void registerPlugin (ModelAPI_Plugin *thePlugin)
 Registers the plugin that creates features. More...
virtual bool checkLicense (const std::string &thePluginName)
 Verifies the license for the plugin is valid. More...
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Processes the configuration file reading. More...
virtual std::shared_ptr< ModelAPI_Document > copy (std::shared_ptr< ModelAPI_Document > theSource, const int theDestID)
 Copies the document to the new one. More...
virtual ModelAPI_ValidatorsFactory * validators ()
 Returns the validators factory: the only one instance per application. More...
virtual ModelAPI_FiltersFactory * filters ()
 Returns the filters factory: the only one instance per application. More...
void setCheckTransactions (const bool theCheck)
 Sets the flag to check modifications outside the transaction or not. More...
 Model_Session ()
 Is called only once, on startup of the application. More...
virtual int transactionID ()
 Returns the global identifier of the current transaction (needed for the update algo) More...
virtual bool isAutoUpdateBlocked ()
 Returns true if auto-update in the application is blocked. More...
virtual void blockAutoUpdate (const bool theBlock)
 Set state of the auto-update of features result in the application. More...
virtual bool isLoading ()
 Returns true if a loading process is performed (so, no need to react on a new part creation) More...
virtual EVENTS_EXPORT bool groupMessages ()
 Listener that needs mostly grouped messages received returns true in this method. More...
static std::shared_ptr< ModelAPI_Session > get ()
 Returns the real implementation (the alone instance per application) of the plugin manager. More...
void LoadPluginsInfo ()
 Loads (if not done yet) the information about the features and plugins. More...
FeaturePtr createFeature (std::string theFeatureID, Model_Document *theDocOwner)
 Creates the feature object using plugins functionality. More...
ModelAPI_Plugin * getPlugin (const std::string &thePluginName)
 Get the plugin by name. If it is not loaded, load plugin. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
static void setSession (std::shared_ptr< ModelAPI_Session > theManager)
 Sets the session interface implementation (once per application launch) More...
bool myIsLoading
 keeps the state of the loading of the document More...
Friends
class Model_Document
class Model_Objects
◆ Model_Session()
Model_Session::Model_Session ( )
◆ load()
bool Model_Session::load ( const char *  theFileName)
theFileNamefull name of the file to load
true if file was loaded successfully
Implements ModelAPI_Session.
◆ save()
bool Model_Session::save ( const char *  theFileName,
std::list< std::string > &  theResults,
bool  doBackup = false
theFileNamefull name of the file to store
theResultsthe result full file names that were stored by "save"
true if file was stored successfully
◆ closeAll()
void Model_Session::closeAll ( )
◆ startOperation()
void Model_Session::startOperation ( const std::string &  theId = "",
const bool  theAttachedToNested = false
theIdstring-identifier of the started transaction
theAttachedToNestedif it is true, it means that this transaction is attached to the nested where it is located and will be committed on the next commit with the nested
◆ finishOperation()
void Model_Session::finishOperation ( )
◆ abortOperation()
void Model_Session::abortOperation ( )
◆ isOperation()
bool Model_Session::isOperation ( )
◆ isModified()
bool Model_Session::isModified ( )
◆ canUndo()
bool Model_Session::canUndo ( )
◆ undo()
void Model_Session::undo ( )
◆ canRedo()
bool Model_Session::canRedo ( )
◆ redo()
void Model_Session::redo ( )
◆ undoList()
std::list< std::string > Model_Session::undoList ( )
◆ redoList()
std::list< std::string > Model_Session::redoList ( )
◆ clearUndoRedo()
void Model_Session::clearUndoRedo ( )
◆ moduleDocument()
std::shared_ptr< ModelAPI_Document > Model_Session::moduleDocument ( )
◆ document()
std::shared_ptr< ModelAPI_Document > Model_Session::document ( int  theDocID)
◆ hasModuleDocument()
bool Model_Session::hasModuleDocument ( )
◆ activeDocument()
std::shared_ptr< ModelAPI_Document > Model_Session::activeDocument ( )
◆ setActiveDocument()
void Model_Session::setActiveDocument ( std::shared_ptr< ModelAPI_Document >  theDoc,
bool  theSendSignal = true
◆ allOpenedDocuments()
std::list< std::shared_ptr< ModelAPI_Document > > Model_Session::allOpenedDocuments ( )
◆ isLoadByDemand()
bool Model_Session::isLoadByDemand ( const std::wstring  theDocID,
◆ registerPlugin()
void Model_Session::registerPlugin ( ModelAPI_Plugin *  thePlugin)
It is obligatory for each plugin to call this function on loading to be found by the plugin manager on call of the feature)
◆ checkLicense()
bool Model_Session::checkLicense ( const std::string &  thePluginName)
◆ processEvent()
void Model_Session::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
Implements Events_Listener.
◆ copy()
std::shared_ptr< ModelAPI_Document > Model_Session::copy ( std::shared_ptr< ModelAPI_Document >  theSource,
const int  theDestID
◆ validators()
ModelAPI_ValidatorsFactory * Model_Session::validators ( )
◆ filters()
ModelAPI_FiltersFactory * Model_Session::filters ( )
◆ setCheckTransactions()
void Model_Session::setCheckTransactions ( const bool  theCheck)
◆ transactionID()
int Model_Session::transactionID ( )
◆ isAutoUpdateBlocked()
bool Model_Session::isAutoUpdateBlocked ( )
◆ blockAutoUpdate()
void Model_Session::blockAutoUpdate ( const bool  theBlock)
◆ LoadPluginsInfo()
void Model_Session::LoadPluginsInfo ( )
◆ createFeature()
FeaturePtr Model_Session::createFeature ( std::string  theFeatureID,
Model_Document *  theDocOwner
◆ getPlugin()
ModelAPI_Plugin * Model_Session::getPlugin ( const std::string &  thePluginName)
◆ get()
std::shared_ptr< ModelAPI_Session > ModelAPI_Session::get ( )
◆ isLoading()
virtual bool ModelAPI_Session::isLoading ( )
inlinevirtualinherited
◆ setSession()
void ModelAPI_Session::setSession ( std::shared_ptr< ModelAPI_Session >  theManager)
staticprotectedinherited
◆ groupMessages()
virtual EVENTS_EXPORT bool Events_Listener::groupMessages ( )
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
◆ myIsLoading
bool ModelAPI_Session::myIsLoading
