ModuleBase_OperationFeature Class Reference
Base class for all operations. More...
#include <ModuleBase_OperationFeature.h>
Inheritance diagram for ModuleBase_OperationFeature:
Public Slots
virtual bool start ()
 Starts operation Public slot. More...
void abort ()
 Aborts operation Public slot. More...
bool commit ()
 Commits operation Public slot. More...
virtual void postpone ()
 Deactivates current operation which can be resumed later. More...
virtual void resume ()
 Resumes operation Public slot. More...
void onValuesChanged ()
 Changes the modified flag of the operation. More...
void onValueStateChanged (int thePreviousState)
 Changes the modified flag of the operation if the current state of the widget is modified. More...
Signals
void beforeStarted ()
 The operation is started. More...
void started ()
void beforeAborted ()
 The operation is aborted. More...
void aborted ()
void beforeCommitted ()
 The operation is committed. More...
void committed ()
void stopped ()
 The operation is aborted or committed. More...
void resumed ()
 The operation is resumed. More...
void postponed ()
 The operation is postponed. More...
 ModuleBase_OperationFeature (const QString &theId="", QObject *theParent=0)
virtual ~ModuleBase_OperationFeature ()
bool isEditOperation () const
 Returns True id the current operation is launched in editing mode. More...
void setEditOperation (const bool &isEditState)
 Change the operation mode from create to edit. More...
FeaturePtr feature () const
 Returns the operation feature. More...
virtual bool isValid () const
 Must return True if the operation's feature is valid. More...
void setFeature (FeaturePtr theFeature)
 Sets the operation feature. More...
virtual bool hasObject (ObjectPtr theObj) const
 Returns True if the current operation works with the given object (feature or result) More...
virtual bool isDisplayedOnStart (ObjectPtr theObject)
 Returns true if the object is displayed when the operation was started. More...
virtual void initSelection (const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &thePreSelected)
 Initialisation of operation with preliminary selection. More...
void setPreselection (const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &theValues)
 Fill internal map by preselection. More...
virtual void setPropertyPanel (ModuleBase_IPropertyPanel *theProp)
 Set property pane to the operation. More...
virtual ModuleBase_ModelWidget * activateByPreselection (const std::string &theGreedAttributeId)
 Activates widgets by preselection if it is accepted. More...
void setParentFeature (CompositeFeaturePtr theParent)
 If the operation works with feature which is sub-feature of another one then this variable has to be initialised by parent feature before operation feature creating. More...
CompositeFeaturePtr parentFeature () const
void setPreviousCurrentFeature (const FeaturePtr &theFeature)
 Stores the previous to the operation current feature. More...
FeaturePtr previousCurrentFeature ()
 Returns the previous to the operation current feature. More...
void setNeedToBeAborted (const bool theState)
 Set whether the operation should be aborted. More...
bool isNeedToBeAborted () const
 Returns valid state of the operation. More...
void openTransactionOnResume ()
 Call this function on launch of a nested operation when transaction has to be reopened on resume of main operation By default transaction is not reopened on resuming. More...
ModuleBase_OperationDescription * getDescription () const
 Returns the operation description /returns the instance of the description class. More...
const QStringList & grantedOperationIds () const
 Returns list of granted operation indices. More...
void setGrantedOperationIds (const QStringList &theList)
 Sets list of operation indices, which can be started without the current operation stop. More...
virtual bool isGranted (QString theId) const
 Must return true if this operation can be launched as nested for any current operation and it is not necessary to check this operation on validity. More...
 Returns True if data of its feature was modified during operation. More...
QString id () const
 Returns operations Id from it's description. More...
ModuleBase_IPropertyPanel * propertyPanel () const
QString helpFileName () const
void setHelpFileName (QString theName)
void setHideFacesVisible (bool isVisible)
bool isHideFacesVisible () const
static QString EditSuffix ()
 Appends to operation's history id, if it is an "edit" operation (myIsEditing == true) More...
 Displays the feature/results if it is hidden. It will be hided in stopOperation. More...
virtual void stopOperation ()
 Hide feature/results if they were hided on start. More...
virtual void resumeOperation ()
 Virtual method called after operation resume (see resume() method for more description) More...
virtual FeaturePtr createFeature (const bool theFlushMessage=true)
 Creates an operation new feature. More...
void clearPreselection ()
 Removes the preselection information and clears the map of preselection. More...
virtual void postponeOperation ()
 Implementation of specific steps on postpone operation. More...
 Virtual method called when operation aborted (see abort() method for more description) More...
 Virtual method called when operation committed (see commit() method for more description) More...
virtual void afterCommitOperation ()
 Virtual method called after operation committed (see commit() method for more description) More...
virtual bool canBeCommitted () const
 Verifies whether this operator can be committed. More...
FeaturePtr myFeature
 The operation feature to be handled. More...
std::set< ObjectPtr > myVisualizedObjects
 a list of hidden objects, which are displayed by operation start and should be hidden by operation stop More...
bool myIsEditing
 Editing feature flag. More...
bool myNeedToBeAborted
 State used only if the operation should not be committed. More...
QList< std::shared_ptr< ModuleBase_ViewerPrs > > myPreSelection
 List of pre-selected object. More...
CompositeFeaturePtr myParentFeature
FeaturePtr myPreviousCurrentFeature
 Last current feature before editing operation. More...
bool myRestartTransactionOnResume
Base class for all operations. If you perform an action it is reasonable to create operation intended for this. This is a base class for all operations which provides mechanism for correct starting operations, starting operations above already started ones, committing operations and so on. To create own operation it is reasonable to inherit it from this class and redefines virtual methods to provide own behavior Main virtual methods are
◆ ModuleBase_OperationFeature()
ModuleBase_OperationFeature::ModuleBase_OperationFeature ( const QString &  theId = "",
QObject *  theParent = 0
theIdthe operation identifier
theParentthe QObject parent
◆ ~ModuleBase_OperationFeature()
ModuleBase_OperationFeature::~ModuleBase_OperationFeature ( )
◆ EditSuffix()
static QString ModuleBase_OperationFeature::EditSuffix ( )
inlinestatic
◆ isEditOperation()
bool ModuleBase_OperationFeature::isEditOperation ( ) const
◆ setEditOperation()
void ModuleBase_OperationFeature::setEditOperation ( const bool &  isEditState)
The transaction and the operation name in the model history of transaction are the same. It updates the edit state in the widgets of property panel
isEditStateboolean state whether the operation should become editing or creating the new one is started
◆ feature()
FeaturePtr ModuleBase_OperationFeature::feature ( ) const
the feature
◆ isValid()
bool ModuleBase_OperationFeature::isValid ( ) const
Since IOperation does not have any feature returns false.
Reimplemented from ModuleBase_Operation.
◆ setFeature()
void ModuleBase_OperationFeature::setFeature ( FeaturePtr  theFeature)
◆ hasObject()
bool ModuleBase_OperationFeature::hasObject ( ObjectPtr  theObj) const
◆ isDisplayedOnStart()
bool ModuleBase_OperationFeature::isDisplayedOnStart ( ObjectPtr  theObject)
theObjecta feature or result of the operation feature
boolean value whether the object display state was changed
◆ initSelection()
void ModuleBase_OperationFeature::initSelection ( const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  thePreSelected)
thePreSelecteda container of selected presentations
filtering of selection is not necessary
◆ setPreselection()
void ModuleBase_OperationFeature::setPreselection ( const QList< std::shared_ptr< ModuleBase_ViewerPrs > > &  theValues)
theValuesa list of preselection
◆ setPropertyPanel()
void ModuleBase_OperationFeature::setPropertyPanel ( ModuleBase_IPropertyPanel *  theProp)
thePropa property panel instance
◆ activateByPreselection()
ModuleBase_ModelWidget * ModuleBase_OperationFeature::activateByPreselection ( const std::string &  theGreedAttributeId)
theGreedAttributeIda greed attribute id if there is in the current feature
last filled widget
◆ setParentFeature()
void ModuleBase_OperationFeature::setParentFeature ( CompositeFeaturePtr  theParent)
◆ parentFeature()
CompositeFeaturePtr ModuleBase_OperationFeature::parentFeature ( ) const
Installed parent feature (can be NULL)
◆ setPreviousCurrentFeature()
void ModuleBase_OperationFeature::setPreviousCurrentFeature ( const FeaturePtr &  theFeature)
theFeaturea feature
◆ previousCurrentFeature()
FeaturePtr ModuleBase_OperationFeature::previousCurrentFeature ( )
theFeature a feature
◆ setNeedToBeAborted()
void ModuleBase_OperationFeature::setNeedToBeAborted ( const bool  theState)
By default the state is false in operation
theStateabort state
◆ isNeedToBeAborted()
bool ModuleBase_OperationFeature::isNeedToBeAborted ( ) const
custom validity state (it is almost always true)
◆ openTransactionOnResume()
void ModuleBase_OperationFeature::openTransactionOnResume ( )
◆ start
bool ModuleBase_OperationFeature::start ( )
virtualslot
Verifies whether operation can be started and starts operation. This slot is not virtual and cannot be redefined. Redefine startOperation method to change behavior of operation. There is no point in using this method. It would be better to inherit own operator from base one and redefine startOperation method instead.
true if the start is successful
◆ abort
void ModuleBase_OperationFeature::abort ( )
slot
Aborts operation. This slot is not virtual and cannot be redefined. Redefine abortOperation method to change behavior of operation instead
◆ commit
bool ModuleBase_OperationFeature::commit ( )
slot
Commits operation. This slot is not virtual and cannot be redefined. Redefine commitOperation method to change behavior of operation instead
◆ startOperation()
void ModuleBase_OperationFeature::startOperation ( )
◆ stopOperation()
void ModuleBase_OperationFeature::stopOperation ( )
◆ resumeOperation()
void ModuleBase_OperationFeature::resumeOperation ( )
◆ createFeature()
FeaturePtr ModuleBase_OperationFeature::createFeature ( const bool  theFlushMessage = true)
theFlushMessagethe flag whether the create message should be flushed
the created feature
◆ clearPreselection()
void ModuleBase_OperationFeature::clearPreselection ( )
◆ getDescription()
ModuleBase_OperationDescription * ModuleBase_Operation::getDescription ( ) const
◆ grantedOperationIds()
const QStringList & ModuleBase_Operation::grantedOperationIds ( ) const
◆ setGrantedOperationIds()
void ModuleBase_Operation::setGrantedOperationIds ( const QStringList &  theList)
theListan ids
◆ isGranted()
bool ModuleBase_Operation::isGranted ( QString  theId) const
By default the operation is not granted. The method has to be redefined for granted operations.
◆ isModified()
bool ModuleBase_Operation::isModified ( ) const
◆ id()
QString ModuleBase_Operation::id ( ) const
◆ propertyPanel()
ModuleBase_IPropertyPanel * ModuleBase_Operation::propertyPanel ( ) const
Currently installed property panel
◆ beforeStarted
void ModuleBase_Operation::beforeStarted ( )
signalinherited
◆ started
void ModuleBase_Operation::started ( )
signalinherited
◆ beforeAborted
void ModuleBase_Operation::beforeAborted ( )
signalinherited
◆ aborted
void ModuleBase_Operation::aborted ( )
signalinherited
◆ beforeCommitted
void ModuleBase_Operation::beforeCommitted ( )
signalinherited
◆ committed
void ModuleBase_Operation::committed ( )
signalinherited
◆ stopped
void ModuleBase_Operation::stopped ( )
signalinherited
◆ resumed
void ModuleBase_Operation::resumed ( )
signalinherited
◆ postponed
void ModuleBase_Operation::postponed ( )
signalinherited
◆ postpone
void ModuleBase_Operation::postpone ( )
virtualslotinherited
◆ resume
void ModuleBase_Operation::resume ( )
◆ onValuesChanged
void ModuleBase_Operation::onValuesChanged ( )
slotinherited
◆ onValueStateChanged
void ModuleBase_Operation::onValueStateChanged ( int  thePreviousState)
slotinherited
thePreviousStatethe previous value state of the widget
◆ postponeOperation()
virtual void ModuleBase_Operation::postponeOperation ( )
◆ abortOperation()
virtual void ModuleBase_Operation::abortOperation ( )
◆ commitOperation()
virtual void ModuleBase_Operation::commitOperation ( )
◆ afterCommitOperation()
virtual void ModuleBase_Operation::afterCommitOperation ( )
◆ canBeCommitted()
bool ModuleBase_Operation::canBeCommitted ( ) const
Returns TRUE if current operation can be committed, e.g. all parameters are filled
◆ myFeature
FeaturePtr ModuleBase_OperationFeature::myFeature
◆ myVisualizedObjects
std::set<ObjectPtr> ModuleBase_OperationFeature::myVisualizedObjects
◆ myIsEditing
bool ModuleBase_OperationFeature::myIsEditing
◆ myNeedToBeAborted
bool ModuleBase_OperationFeature::myNeedToBeAborted
◆ myPreSelection
QList<std::shared_ptr<ModuleBase_ViewerPrs> > ModuleBase_OperationFeature::myPreSelection
◆ myParentFeature
CompositeFeaturePtr ModuleBase_OperationFeature::myParentFeature
◆ myPreviousCurrentFeature
FeaturePtr ModuleBase_OperationFeature::myPreviousCurrentFeature
It is cashed when Edit operation is started in order to restore the document current feature on commit/abort this operation.
