ModuleBase_WidgetCreatorFactory Class Reference
A class for creation of widgets instances in for property panel using XML deskription of a feature. More...
#include <ModuleBase_WidgetCreatorFactory.h>
virtual ~ModuleBase_WidgetCreatorFactory ()
void registerCreator (const WidgetCreatorPtr &theCreator)
 The creator is added to the internal container to be used when the createWidgetByType is called. More...
bool hasPanelWidget (const std::string &theType)
 Returns true if there is a creator, which can make a panel by the type. More...
QWidget * createPanelByType (const std::string &theType, QWidget *theParent, const FeaturePtr &theFeature, Config_WidgetAPI *theWidgetApi=0)
 Create panel by its type. More...
bool hasPageWidget (const std::string &theType)
 Returns true if there is a creator, which can make a page by the type. More...
ModuleBase_PageBase * createPageByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi)
 Create page by its type. More...
ModuleBase_ModelWidget * createWidgetByType (const std::string &theType, QWidget *theParent, Config_WidgetAPI *theWidgetApi, ModuleBase_IWorkshop *theWorkshop)
 Create widget by its type. More...
static std::shared_ptr< ModuleBase_WidgetCreatorFactory > get ()
 Returns an singular instance of the class if it exists or create it. More...
◆ ~ModuleBase_WidgetCreatorFactory()
ModuleBase_WidgetCreatorFactory::~ModuleBase_WidgetCreatorFactory ( )
◆ get()
std::shared_ptr< ModuleBase_WidgetCreatorFactory > ModuleBase_WidgetCreatorFactory::get ( )
◆ registerCreator()
void ModuleBase_WidgetCreatorFactory::registerCreator ( const WidgetCreatorPtr &  theCreator)
theCreatora new widget creator
fill map of panels
fill map of widgets
fill map of pages
◆ hasPanelWidget()
bool ModuleBase_WidgetCreatorFactory::hasPanelWidget ( const std::string &  theType)
theTypea type
a boolean value
◆ createPanelByType()
QWidget * ModuleBase_WidgetCreatorFactory::createPanelByType ( const std::string &  theType,
QWidget *  theParent,
const FeaturePtr &  theFeature,
Config_WidgetAPI *  theWidgetApi = 0
theTypea type
theParenta parent widget
theFeaturea feature to fill the panel
theWidgetApithe widget configuration. The attribute of the model widget is obtained from XML
a created panel or null
◆ hasPageWidget()
bool ModuleBase_WidgetCreatorFactory::hasPageWidget ( const std::string &  theType)
theTypea type
a boolean value
◆ createPageByType()
ModuleBase_PageBase * ModuleBase_WidgetCreatorFactory::createPageByType ( const std::string &  theType,
theTypea type
a created page or null
◆ createWidgetByType()
ModuleBase_ModelWidget * ModuleBase_WidgetCreatorFactory::createWidgetByType ( const std::string &  theType,
Config_WidgetAPI *  theWidgetApi,
ModuleBase_IWorkshop *  theWorkshop
theTypea type
theWorkshopa workshop object instance
a created widget or null
