PartSetAPI_Part Class Reference
Interface for Part feature. More...
#include <PartSetAPI_Part.h>
Inheritance diagram for PartSetAPI_Part:
 PartSetAPI_Part (const std::shared_ptr< ModelAPI_Feature > &theFeature)
virtual ~PartSetAPI_Part ()
virtual std::string getID ()
std::shared_ptr< ModelAPI_Document > document () const
 Return document. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
◆ PartSetAPI_Part()
PartSetAPI_Part::PartSetAPI_Part ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ~PartSetAPI_Part()
PartSetAPI_Part::~PartSetAPI_Part ( )
◆ document()
std::shared_ptr< ModelAPI_Document > PartSetAPI_Part::document ( ) const
Return document.
◆ dump()
void PartSetAPI_Part::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
