Public Types | |
| enum | Selector_Type { SELTYPE_CONTAINER , SELTYPE_INTERSECT , SELTYPE_PRIMITIVE , SELTYPE_MODIFICATION , SELTYPE_FILTER_BY_NEIGHBOR , SELTYPE_WEAK_NAMING } |
| Type of a selector algorithm: on this type depends what is stored in this label and how to restore it on update. More... | |
| Selector_Algo () | |
| Initializes the algorithm. More... | |
| virtual void | store ()=0 |
| Stores the name to the label and sub-labels tree. More... | |
| virtual bool | restore ()=0 |
| Restores the selected shape by the topological naming kept in the data structure Returns true if it can restore structure correctly. More... | |
| virtual TDF_Label | restoreByName (std::wstring theName, const TopAbs_ShapeEnum theShapeType, Selector_NameGenerator *theNameGenerator)=0 |
| Restores the selected shape by the topological name string. More... | |
| virtual bool | solve (const TopoDS_Shape &theContext)=0 |
| Updates the current shape by the stored topological name. More... | |
| virtual std::wstring | name (Selector_NameGenerator *theNameGenerator)=0 |
| Returns the naming name of the selection. More... | |
| TopoDS_Shape | value () |
| Returns the current sub-shape value (null if can not resolve) More... | |
| void | setGeometricalNaming () |
| Sets geometrical naming flag to true. More... | |
| static Selector_Algo * | select (const TopoDS_Shape theContext, const TopoDS_Shape theValue, const TDF_Label theAccess, const TDF_Label theBaseDocument, const bool theGeometricalNaming=false, const bool theUseNeighbors=true, const bool theUseIntersections=true, const bool theAlwaysGeometricalNaming=false) |
| Initializes the selector structure on the label. More... | |
| static Selector_Algo * | restoreByLab (TDF_Label theLab, TDF_Label theBaseDocLab) |
| Restores sub-algorithm of a given type by the storage-label. More... | |
| static Selector_Algo * | restoreByName (TDF_Label theLab, TDF_Label theBaseDocLab, std::wstring theName, const TopAbs_ShapeEnum theShapeType, const bool theGeomNaming, Selector_NameGenerator *theNameGenerator, TDF_Label &theContextLab) |
| Restores the selected sub-algorithm by the naming name. More... | |
| static bool | sameGeometry (const TopoDS_Shape theShape1, const TopoDS_Shape theShape2) |
| Returns true if the given shapes are based on the same geometry. More... | |
| static Selector_Algo * | relesectWithAllGeometry (Selector_Algo *theOldAlgo, const TopoDS_Shape theContext) |
| Creates a new selection algorithm for selection of all topology based on the same geometry. More... | |
| const TDF_Label & | label () const |
| Returns label where this algorithm is attached to, or just an access label to the document. More... | |
| void | storeBaseArray (const TDF_LabelList &theRef, const TDF_Label &theLast) |
| Stores the array of references to theLab: references to elements of ref-list, then the last. More... | |
| bool | restoreBaseArray (TDF_LabelList &theRef, TDF_Label &theLast) |
| Restores references to the labels: references to elements of ref-list, then the last. More... | |
| void | store (const TopoDS_Shape theShape) |
| Stores result of selection at the given label. More... | |
| const TDF_Label & | baseDocument () const |
| Returns an access-label of the document that may contain initial shapes. More... | |
| bool | geometricalNaming () const |
| Returns the geometrical naming flag. More... | |
| bool | alwaysGeometricalNaming () const |
| Returns always geometrical naming flag. More... | |
| bool | useNeighbors () const |
| Returns use neighbors flag. More... | |
| bool | useIntersections () const |
| Returns use intersections flag. More... | |
| void | storeType (const Selector_Type theType) |
| Stores the type of an algorithm in the data tree (in myLab) More... | |
| bool | findNewVersion (const TopoDS_Shape &theContext, TopoDS_Shape &theResult) const |
| Searches the newer version of the shape in the document if the base shape does not belong to context. More... | |
Static Protected Member Functions | |
| static const Standard_GUID & | weakID () |
| Returns GUID for the weak index (integer attribute) of the sub-shape. More... | |
| static const Standard_GUID & | shapeTypeID () |
| Returns GUID for the type of the shape, stored in case it is intersection or container. More... | |
| static const std::wstring & | oldWeakNameID () |
| old string identifier of the weak name in modification or intersection types of algorithm More... | |
| static const std::wstring & | oldPureWeakNameID () |
| old string identifier of the pure weak name More... | |
| static const std::wstring & | weakNameID () |
| static const std::wstring & | pureWeakNameID () |
| Selector_Algo::Selector_Algo | ( | ) |
static |
Stores the name data to restore after modification.
| theContext | whole shape that contains the selected sub-shape |
| theValue | selected subshape |
| theGeometricalNaming | treats selection with equal surfaces as one |
| theUseNeighbors | enables searching algorithm by neighbors |
| theUseIntersections | enables searching algorithm by intersection of higher level shapes |
pure virtual |
Implemented in Selector_Container, Selector_FilterByNeighbors, Selector_Intersect, Selector_Modify, Selector_Primitive, and Selector_WeakName.
pure virtual |
pure virtual |
Returns not empty label of the context.
pure virtual |
pure virtual |
| TopoDS_Shape Selector_Algo::value | ( | ) |
static |
static |
static |
static |
inline |
inlineprotected |
protected |
protected |
protected |
inlineprotected |
inlineprotected |
inlineprotected |
inlineprotected |
inlineprotected |
inlinestaticprotected |
protected |
protected |
Returns it in theResult (if any). Returns true is theResult is changed.
