Kind of selection algorithm: selected shape is a container of sub-shapes that must be named one by one.
More...
#include <Selector_Container.h>
| bool | select (const TopoDS_Shape theContext, const TopoDS_Shape theValue) |
| | Initializes the selection of this kind. More...
| virtual void | store () override |
| | Stores the name to the label and sub-labels tree. More...
| virtual bool | restore () override |
| | Restores the selected shape by the topological naming kept in the data structure Returns true if it can restore structure correctly. More...
| virtual TDF_Label | restoreByName (std::wstring theName, const TopAbs_ShapeEnum theShapeType, Selector_NameGenerator *theNameGenerator) override |
| | Restores the selected shape by the topological name string. More...
| virtual bool | solve (const TopoDS_Shape &theContext) override |
| | Updates the current shape by the stored topological name. More...
| virtual std::wstring | name (Selector_NameGenerator *theNameGenerator) override |
| | Returns the naming name of the selection. More...
| void | clearSubAlgos () |
| | Erases the sub-algorithms stored. More...
| TDF_Label | newSubLabel () |
| | Returns the next label for a new sub-selector created. More...
| bool | append (Selector_Algo *theAlgo, const bool theEraseIfNull=true) |
| | Appends a new algorithm to the list, erases list if it is null (failed) More...
| std::list< Selector_Algo * > & | list () |
| | Returns the stored list of sub-algorithms. More...
| TopoDS_Shape | value () |
| | Returns the current sub-shape value (null if can not resolve) More...
| void | setGeometricalNaming () |
| | Sets geometrical naming flag to true. More...
| static Selector_Algo * | select (const TopoDS_Shape theContext, const TopoDS_Shape theValue, const TDF_Label theAccess, const TDF_Label theBaseDocument, const bool theGeometricalNaming=false, const bool theUseNeighbors=true, const bool theUseIntersections=true, const bool theAlwaysGeometricalNaming=false) |
| | Initializes the selector structure on the label. More...
| static Selector_Algo * | restoreByName (TDF_Label theLab, TDF_Label theBaseDocLab, std::wstring theName, const TopAbs_ShapeEnum theShapeType, const bool theGeomNaming, Selector_NameGenerator *theNameGenerator, TDF_Label &theContextLab) |
| | Restores the selected sub-algorithm by the naming name. More...
| static Selector_Algo * | restoreByLab (TDF_Label theLab, TDF_Label theBaseDocLab) |
| | Restores sub-algorithm of a given type by the storage-label. More...
| static bool | sameGeometry (const TopoDS_Shape theShape1, const TopoDS_Shape theShape2) |
| | Returns true if the given shapes are based on the same geometry. More...
| static Selector_Algo * | relesectWithAllGeometry (Selector_Algo *theOldAlgo, const TopoDS_Shape theContext) |
| | Creates a new selection algorithm for selection of all topology based on the same geometry. More...
| void | store (const TopoDS_Shape theShape) |
| | Stores result of selection at the given label. More...
| const TDF_Label & | label () const |
| | Returns label where this algorithm is attached to, or just an access label to the document. More...
| void | storeBaseArray (const TDF_LabelList &theRef, const TDF_Label &theLast) |
| | Stores the array of references to theLab: references to elements of ref-list, then the last. More...
| bool | restoreBaseArray (TDF_LabelList &theRef, TDF_Label &theLast) |
| | Restores references to the labels: references to elements of ref-list, then the last. More...
| const TDF_Label & | baseDocument () const |
| | Returns an access-label of the document that may contain initial shapes. More...
| bool | geometricalNaming () const |
| | Returns the geometrical naming flag. More...
| bool | alwaysGeometricalNaming () const |
| | Returns always geometrical naming flag. More...
| bool | useNeighbors () const |
| | Returns use neighbors flag. More...
| bool | useIntersections () const |
| | Returns use intersections flag. More...
| void | storeType (const Selector_Type theType) |
| | Stores the type of an algorithm in the data tree (in myLab) More...
| bool | findNewVersion (const TopoDS_Shape &theContext, TopoDS_Shape &theResult) const |
| | Searches the newer version of the shape in the document if the base shape does not belong to context. More...
| static const Standard_GUID & | weakID () |
| | Returns GUID for the weak index (integer attribute) of the sub-shape. More...
| static const Standard_GUID & | shapeTypeID () |
| | Returns GUID for the type of the shape, stored in case it is intersection or container. More...
| static const std::wstring & | oldWeakNameID () |
| | old string identifier of the weak name in modification or intersection types of algorithm More...
| static const std::wstring & | oldPureWeakNameID () |
| | old string identifier of the pure weak name More...
| static const std::wstring & | weakNameID () |
| static const std::wstring & | pureWeakNameID () |
◆ Selector_Type
Type of a selector algorithm: on this type depends what is stored in this label and how to restore it on update.
| Enumerator |
| SELTYPE_CONTAINER | just a container of sub-elements, keeps the shape type of container
| SELTYPE_INTERSECT | sub-shape is intersection of higher level objects
| SELTYPE_PRIMITIVE | sub-shape found as a primitive on some label
| SELTYPE_MODIFICATION | modification of base shapes to the final label
| SELTYPE_FILTER_BY_NEIGHBOR | identification by neighbor shapes in context
| SELTYPE_WEAK_NAMING | pure weak naming by weak index in context
◆ select() [1/2]
| bool Selector_Container::select |
const TopoDS_Shape |
theContext, |
theValue |
◆ store() [1/2]
| void Selector_Container::store |
overridevirtual |
Implements Selector_Algo.
◆ restore()
| bool Selector_Container::restore |
overridevirtual |
◆ restoreByName() [1/2]
| TDF_Label Selector_Container::restoreByName |
std::wstring |
theName, |
const TopAbs_ShapeEnum |
theShapeType, |
Selector_NameGenerator * |
theNameGenerator |
overridevirtual |
Returns not empty label of the context.
◆ solve()
| bool Selector_Container::solve |
const TopoDS_Shape & |
theContext | ) |
overridevirtual |
◆ name()
◆ clearSubAlgos()
| void Selector_AlgoWithSubs::clearSubAlgos |
◆ newSubLabel()
| TDF_Label Selector_AlgoWithSubs::newSubLabel |
◆ append()
| bool Selector_AlgoWithSubs::append |
Selector_Algo * |
theAlgo, |
const bool |
theEraseIfNull = true |
◆ list()
◆ select() [2/2]
| Selector_Algo * Selector_Algo::select |
theContext, |
theValue, |
const TDF_Label |
theAccess, |
const TDF_Label |
theBaseDocument, |
const bool |
theGeometricalNaming = false, |
const bool |
theUseNeighbors = true, |
const bool |
theUseIntersections = true, |
const bool |
theAlwaysGeometricalNaming = false |
staticinherited |
Stores the name data to restore after modification.
- Parameters
| theContext | whole shape that contains the selected sub-shape |
| theValue | selected subshape |
| theGeometricalNaming | treats selection with equal surfaces as one |
| theUseNeighbors | enables searching algorithm by neighbors |
| theUseIntersections | enables searching algorithm by intersection of higher level shapes |
◆ store() [2/2]
| void Selector_Algo::store |
theShape | ) |
protectedinherited |
◆ restoreByName() [2/2]
| Selector_Algo * Selector_Algo::restoreByName |
TDF_Label |
theLab, |
TDF_Label |
theBaseDocLab, |
std::wstring |
theName, |
theShapeType, |
const bool |
theGeomNaming, |
theNameGenerator, |
TDF_Label & |
theContextLab |
staticinherited |
◆ value()
| TopoDS_Shape Selector_Algo::value |
◆ restoreByLab()
| Selector_Algo * Selector_Algo::restoreByLab |
TDF_Label |
theLab, |
TDF_Label |
theBaseDocLab |
staticinherited |
◆ sameGeometry()
| bool Selector_Algo::sameGeometry |
theShape1, |
theShape2 |
staticinherited |
◆ relesectWithAllGeometry()
◆ setGeometricalNaming()
| void Selector_Algo::setGeometricalNaming |
inlineinherited |
◆ label()
| const TDF_Label & Selector_Algo::label |
const |
inlineprotectedinherited |
◆ storeBaseArray()
| void Selector_Algo::storeBaseArray |
const TDF_LabelList & |
theRef, |
const TDF_Label & |
theLast |
◆ restoreBaseArray()
| bool Selector_Algo::restoreBaseArray |
TDF_LabelList & |
theRef, |
TDF_Label & |
theLast |
◆ baseDocument()
| const TDF_Label & Selector_Algo::baseDocument |
const |
◆ geometricalNaming()
| bool Selector_Algo::geometricalNaming |
const |
◆ alwaysGeometricalNaming()
| bool Selector_Algo::alwaysGeometricalNaming |
const |
◆ useNeighbors()
| bool Selector_Algo::useNeighbors |
const |
◆ useIntersections()
| bool Selector_Algo::useIntersections |
const |
◆ weakID()
| static const Standard_GUID & Selector_Algo::weakID |
inlinestaticprotectedinherited |
◆ shapeTypeID()
| static const Standard_GUID & Selector_Algo::shapeTypeID |
◆ oldWeakNameID()
| static const std::wstring & Selector_Algo::oldWeakNameID |
◆ oldPureWeakNameID()
| static const std::wstring & Selector_Algo::oldPureWeakNameID |
◆ weakNameID()
| static const std::wstring & Selector_Algo::weakNameID |
◆ pureWeakNameID()
| static const std::wstring & Selector_Algo::pureWeakNameID |
◆ storeType()
◆ findNewVersion()
| bool Selector_Algo::findNewVersion |
theContext, |
TopoDS_Shape & |
theResult |
| const |
Returns it in theResult (if any). Returns true is theResult is changed.
